Question about Samsung CoolTech Plus / Basic Bottom Mount Refrigerator SR-L676EV
Door alarm goes off every 4 minutes (plays music}
The door alarm goes off every 4 minutes and the temp is up to 9 degrees
  • 3 more comments
  • crispham Mar 14, 2008
    I Have similar problem with samsung refrigerator RB1855SL, door alarm goes off every 60 seconds for no apparent reason all doors closed, we tried reseting it by unplugging it for 15 min as suggested by samsung customer service, but to no avail, and the temperature of the fridge is unresponsive stays at 9 degrees, i called them again and they said that was the only solution they could suggest..
  • svenrene Jun 27, 2008
    Got a Samsung side by side fridge/freezer. the fridge dooralarm goes off for no reason sometimes and the fridge temperatur drops after. Sometimes it s good for a week and all of a sudden it starts for no apparent reason ? Turned it off but still does it.
  • dncc74 Jun 29, 2008
    I have the same problem with my RB1855SL .. any help ?
  • charleyw Aug 13, 2008
    I have the same problem! I have the SR-L677EV
  • hosingrecord Jan 17, 2009
    My fridge has just started to give the 'The door is open' bleeps every 2 mins or so. I have just tried the 15 minute switch-off but no joy. It is beginning to grate terribl too. On a happier note, the weather where i am means the milk will stay nice and cold on the windowsill!
I'm got a Samsung RSH1DTMH side by side and its doing the same thing. it seems to be once a week. Last night i opened it to get a drink about 23:30, and then dealt with the alarm, reset 10-15 minutes until 01:30 and then said "F-it" at that point i didnt care if i lost everything i n it. it stayed at -25 in freezer all night, +7 (set to +3) in fridge all lights on, normal operation noises. WHAT THE F GIVES SAMSUNGGGGGGG
Posted on Nov 08, 2008
  • Cali Tex
    Cali Tex Oct 30, 2015
    Did you figure out how to stop it?
You probably find its an over temp alarm warning.need to check further
Posted on Oct 12, 2007
Fridge now constantly CYCLES ON AND OFF for 10 to 15 minutes
Perhaps calling in a refrigerator repair man so he can check the freon as that is what causes them to run alot more than normal
Jun 03, 2016 | Westinghouse Refrigerators
High temp alarm
Good Afternoon Friend,
I see that you have the High Temp alarm going off on your Frigidaire refrigerator. First, you will want to press the Alarm Off button to turn the alarm off. Next, you will want to press and hold the Factory Default button to put the temperatures at 0 degrees for the freezer and 37 degrees for the refrigerator. Wait 24 hours for the temperatures to stabilize. If you are still having trouble with the alarm going off, reset your appliance by either unplugging it or shutting the power off at your homes circuit breaker for 2-3 minutes. When power is restored, you will need to press the alarm off button. If the High temp alarm is still going off, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
May 15, 2014 | Frigidaire Refrigerators
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
To create an alarm follow the steps below:
  1. While in standby mode, press the Menu / OK button
  2. Select Tools
  3. Select Alarm Clock (9)
  4. Highlight the desired Alarm, using the navigation keys, from the following:
    • Alarm #1
    • Alarm #2
    • Alarm #3
  5. Press the Menu / OK button
  6. Set alarm to On, using the navigation keys
  7. Set alarm time, using the keypad
  8. Select either A for AM or P for PM, using the navigation keys
  9. Press Menu / OK button to choose the Ringer Type from the following:
    • Single Tones (1)
      • Tone 1 through Tone 9
    • Ring Tones (2)
      • Ring Tone 1 through Ring Tone 15
    • Melodies (3)
      • Ball (1)
      • Caribbean Cruise (2)
      • Chorus of Clocks (3)
      • Right Here (4)
      • Guitar Man (5)
      • Latin Lady (6)
      • Minuett (7)
      • Mixed up World (8)
      • Pressure (9)
      • Simply Blue (10)
    • My Content (4), for previously downloaded music
  10. Select desired Repeat frequency, using the navigation keys, from the following:
    • Daily
    • Once
    • Mon to Fri
    • Sat & Sun
  11. Select the Snooze Interval, using the navigation keys, from the following:
    • 5 Minutes
    • 10 Minutes
    • 15 Minutes
    • 20 Minutes
  12. Press the left soft key for Done to save the alarm changes
Dec 16, 2009 | Samsung SPH-M500 Cellular Phone
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Aug 06, 2009 | Frigidaire Upright Freezer FFU12F2H
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refridgerator not staying cool
Is the cooling fan in the back working? Does the center of fridge where your doors meet feel really hot?
Mar 28, 2017 | Refrigerators
2004 Saab 9-3 Cascading electrical problems
Did you sovle your problem? then how?
Oct 20, 2008 | 2004 Saab 9-3
Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
Jun 15, 2008 | Frigidaire Freezers
Refrigerators Logo
1,633 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
