Question about Refrigerators
Wiring diagram for thermo king street boss
I have brough removed box but no one kept track of wires i have control box and fitted 2 horse motor pump turns gets cool but 3 wires left over
    Scholar:
  • 152 Answers
Need the model number for this one
Posted on May 10, 2009
What does LD code mean on my whirlpool cabrio washer mean?
Ld flashes when the water level does not change after the drain pump is on.
Is the drain hose or the drain pump clogged?
Is the drain hose height greater than 96? ?
Is the pump running? If not, see TEST #7.
TEST #7 Drain/Recirculation
Perform the following checks if washer fails to drain or recirculate.
1. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P4 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1. If resistance values are good, go to step 7. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem exists in the motor winding or in the connection between the machine/motor control and the motor. Go to step 5.
5. Tilt machine forward to access the bottom of the machine and the pumps. See Figure 1, page 6-13.
6. Check the resistance at the pump motor. Remove the connector at the motor and take measurements across pump terminals. Measurements should be as shown in the wiring diagram. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the pump motor. If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/ motor control. Repair or replace the lower wiring harness. If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check the pump and tub sump for foreign objects before replacing pump.
7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
8. If the Manual: Pumps test failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Manual: Pump test.
Aug 20, 2014 | Whirlpool Washing Machines
Can a tork timer 1101 be used to control a 240 volt pool pump motor by controlling only 1 lead of the motor thus having the other lead hot all the time?
Yes: 240 volt can be controlled by turning off 1 hot leg of 240V circuit.
But the tork 101 clock motor still requires 120Volts (unless you buy a tork 240volt 201 clock motor to replace the 120volt 101)
Copy following links for handy resource and wiring diagram:
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
http://waterheatertimer.org/images/Tork-1101-wired-to-control-240.jpg
In the wiring diagram above, it shows white neutral wire running to Tork 1101 timer terminal 2. Bring this white neutral wire from any nearby 120volt outlet.
In event that you do not have this white neutral wire, you can connect ground wire to terminal 2 and that will give 120volts to the 101 clock motor.
Completing circuit to clock motor using ground wire is violation of national electric code for many reasons, however the tiny clock motor only draws 3 watts, and you will remember to bring a white neutral wire to this timer at later date so you can sleep better at night.
Additional resources:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-12.jpg
Gene
h
Aug 27, 2013 | Hardware & Accessories
IR MODEL 2475 COMPRESSOR 7.5 HP, MOTOR WILL NOT START COMPRESSOR AND HUMS, CAN TURN PUMP AND MOTOR BY HAND, MOTOR WILL START SLOWLY WITH DRIVE BELT DISCONNECTED
The WEG 7.5 hp motors often blow the start capacitors. The box on top of the motor has 4 caps in it. 2 start and 2 run caps. Mark the cap wiring or make you a diagram to have at replacement time. Remove one or both of the caps. It is easier to remove two wires and pull the start caps out as a set. They are the black, large ones. I think they are 286 Micro farad caps. To get identical caps you may have to order from IR. If you can find a WEG motor shop they may have them. I usually go to grainger or my local motor shop to purchase. The ones here will be larger in size but can be fitted into the box on the motor. Also inspect the wiring in the box. I have found some wires with insulation gone. This may have caused your problem or a problem latter down the road.
Aug 31, 2011 | Ingersoll Rand Air Tools & Compressors
The dl. Code comes on
DL = Long Drain Ld flashes when the water level does not change after the drain pump is on.
Dec 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Maytag Bravos quiet series 300 washing machine stopped. Won't drain. A message Ld shows. Not sure what to do
Hi and welcome to FixYa, I am Kelly.
My response is very long and will be in 2 parts this is PART 1
Here is what the service manual says about Ld:
"Ld" (Washer is taking too long to drain
water from the wash tub)
Check the following:
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See
"Connect the Drain Hose," page 2-5. Press
PAUSE/CANCEL to clear display
Also:
Is the drain hose clogged, or the end of
the drain hose more than 96? (244 cm)
above the floor?
See "Drain System," page 2-3.
6. To remove the drain pump: (there are 2 pumps... the drain pump is on the left)
a) Loosen the clamps and pull the inlet
and outlet drain hoses off the pump.
Note that there is a tab on the outlet
connector that fits into a slot in the
hose.
b) Remove the three 5/16? hex-head
screws from the drain pump and remove
the pump from the tub.
Check the pump inlet and the tub outlet for obstructions.
Pump electrical winding resistance test:
-Disconnect the wire connector from the
drain pump terminals.
- Set the ohmmeter to the R x 1 scale.
- Touch the ohmmeter test leads to each
of the drain pump terminals. The meter
should indicate between 10.5 and 14 ?.
----Due to the design of the machine the 2 wires going to the drain pump have be notorous for backing out of the plastic connector. Check the connector of the pump for loose terminal connections. --
From the Ld troubleshooting steps / procedure:
Long Drain
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96? ?
• Is the pressure hose connection from the tub to the machine/motor control pinched or plugged?
• Is the pump running? If not, see TEST #7.
TEST 7
test.
control.
repeat step 1.
pump motor.
Unplug the washer or disconnect power.Replace the machine/motor control assembly.
Nov 21, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
How to wire in a king tour pack on a street glide 2008
If you are not sure what wires go where ,don't risk a meltdown seek advice from someone who fits or has knowledge of fitting tour packs .
Mar 12, 2010 | 2008 Harley Davidson FLHX Street Glide
Thermo wires came loose
The panel on the side has screws in it. Remove them and remove the panel. Then to get to the control panel, you have to remove the innet sheet metal panel.
Best regards, W/D
Aug 19, 2009 | Weather King 10AJA2501AH Air Conditioner
I keep getting an Ld code on my cabrio. It always has 14 minutes left. I even unplugged and replugged it, and it goes right back to the code. I had to have a new computer board put into it less than a year...
Long Drain Ld flashes when the water level does not change after the drain pump is on. • Is the drain hose or the drain pump clogged? • Is the drain hose height greater than 96˝ ? • Is the pump running? If not, see TEST #7.
TEST #7 Drain/Recirculation Perform the following checks if washer fails to drain or recirculate. 1. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies. 3. Visually check that the P4 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1. 4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1. If resistance values are good, go to step 7. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem exists in the motor winding or in the connection between the machine/motor control and the motor. Go to step 5. 5. Tilt machine forward to access the bottom of the machine and the pumps. 6. Check the resistance at the pump motor. Remove the connector at the motor and take measurements across pump terminals. Measurements should be as shown in the wiring diagram. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the pump motor. If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/ motor control. Repair or replace the lower wiring harness. If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check the pump and tub sump for foreign objects before replacing pump. 7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 8. If the Manual: Pumps test failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Manual: Pump test.
Jun 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore oasis he top loader shows LD error code. got back panel off, now what?
TEST #7 Drain/Recirculation Perform the following checks if washer fails to drain or recirculate. 1. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies. 3. Visually check that the P4 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1. 4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1. If resistance values are good, go to step 7. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem exists in the motor winding or in the connection between the machine/motor control and the motor. Go to step 5. 5. Tilt machine forward to access the bottom of the machine and the pumps 6. Check the resistance at the pump motor. Remove the connector at the motor and take measurements across pump terminals. Measurements should be as shown in the wiring diagram. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the pump motor. If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/ motor control. Repair or replace the lower wiring harness. If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check the pump and tub sump for foreign objects before replacing pump. 7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 8. If the Manual: Pumps test failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Manual: Pump test.
Jun 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Refrigerators Logo
1,019 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
