Wont pick up bobbin thread
SOURCE: needle wont pick up the bobbin thread
Can not do by yourself. Mine did the same thing after just having it 3 weeks and I had to take in to authorized Singer Dealer to repair. Now without machine for several weeks and probaly out alot of money for repair. Should have got a Brother!! Hope you have better luck than me.
SOURCE: machine will not pick up bobbin thread
Sounds like your needle is in too far and it not allowing the needle to go down far enough to pick up the thread.
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
