Question about Haier 5200 BTU Window Air Conditioner White
IS THERE SUBPOST TO BE STYROFOAM INSIDE THE AIR CONDITION UNIT
HAIER 5200 BTU WINDOW UNIT IS THERE SUBPOST TO BE STYROFOAM INSIDE THE AIR CONDITION UNIT.
  • Samuel Charles Spriggs May 11, 2010
    I've never seen styrofoam in a window A/C unit, but who knows.
    Where is the styrofoam? Do you suspect the styrofoam is causing a problem?
  • 478 Answers
Yes, they mostly juust use it for air flow
Posted on May 10, 2009
Its suppose to have some styro foam inside? or its suppose to be out?
Most window A/C units have styrofoam lining the air vent. Unless the manual says to remove a piece of foam when unpacking the unit, leave it there.
Jul 30, 2012 | Kenmore Model 253.70181 Window Air...
I HAVE STYROFOAM INSIDE THE AIR CONDITION DO I NEED TO REMOVE IT
Is it packing or is it insulation? If packing, as in you just bought this unit and have never used it, remove it.
Aug 05, 2011 | Haier ESA3109 WallWindow Air Conditioner
My haier air condition doesn't have anything on vent to get cool air\r\ni believe it had styrofoam which got thrown away because we though it wasn't needed
I don't think a piece of thrown away Styrofoam is the problem. I'm more concerned that you may have also thrown the Owner's Manual away too. You said, "there's nothing on the front to get cool air in." Are you saying, that the front of the unit that has fixed louvers at the bottom and adjustable louvers at the top is missing? Because that's where the cool air comes out thru the adjustable louvers), when the unit is in operation. If the entire front of the unit is missing and the unit is brand new, you need to contact retailer you purchased it from ASAP.
I hope this helps and thank you for choosing FixYa.
Jul 29, 2011 | Haier HWR08XC7 Air Conditioner
Frigidaire window air condition unit
Hello,Lilo The styrofoam pack MUST stay in place.When in operation the air tempature is so cold the unit will condensate(create water)if not insluated.Your unit would LEAK all over the place.The blower fan is a PLASTIC composit and should not rust.
Apr 24, 2010 | Frigidaire FAC126P1 wall/window Air...
My haier 5200 btu window ac is making funny nosies from the fan like its hitting something I have tryed to wash the outside of it but its still making noises
If you remove the unit from it's housing by sliding out, you can run it while it is out. This will enable you to see exactly where the sound is coming from. Very often it is because the unit is slightly out of alignment with the outer housing. This can be fixed with a spacer.
Oct 20, 2009 | Haier Mechanical Air Conditioner HWF05XC7
IS THERE SUBPOST TO BE STYROFOAM INSIDE THE AIR CONDITION, IT IS BEHIND THE FAN WHEEL, AND ON BOTH SIDES INSIDE UNIT WATER RUNS OUT THE FRONT, NOW UNIT DOES NOT TRUN ON. THANKS, DEE
Yes to the Styrofoam , If there is water running out the front of the system your drain is blocked and or the system  needs to be removed to inspect the drain tray and clean out if required.(serviced). As for it not turning on , check that the fuse isn't blown as the water may have shorted the controls wires and blown the fuse
May 10, 2009 | Haier 5200 BTU Window Air Conditioner...
My Haier 5,200-BTU Window Air Conditioner keeps freezing up. how do I remedied this?
You need to clean the unit outside(take it out of the window) with a water hose because it is dirty inside( you have to remove screws on cover and take cover off), be sure to cover the electronic control board with plastic so you don't get it wet.Clean fins on front and back with water hose and inside .
Sep 02, 2008 | Haier hwr10xc6 Air Conditioner
Styrofoam inside of my Haier HWF05XC7
It should remain there it is the insulation seperating the condensing side from the evaporating side you may nve to reach in and move it around to prevent the destruction of the foam.
Jun 22, 2008 | Haier Mechanical Air Conditioner HWF05XC7
Heating & Cooling Logo
847 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
