Home | Dell | Dimension 9200 PC Desktop | COMPUTER KEEPS ON REB...
Dell Dimension 9200 PC Desktop
Problem for Dell Dimension 9200 PC Desktop
COMPUTER KEEPS ON REBOOTING ITSELF.
By utopia334 on May 10, 2009
HI THERE HOPING SOMEONE CAN HELP ME HERE JUST RECENTLY MY COMPUTER KEEPS REBOOTING ITSELF I'VE TRIED IT ON SAFE MODE,TRIED IT ON LAST KNOWN GOOD CONFIGURATION BUT STILL DOES THE SAME EVEN HAD SUGGESTION OF TRYING DISABLE RESTART OF BOOTING BUT NO JOY I'VE ALREADY HAD POST UP HERE ALREADY BUT THAT WAS A COUPLE OF DAYS AGO BUT THOUGHT I WOULD REFRESH POST ANYWAY I'M HOPING THAT ONE OF YOU NICE PEOPLE OUT THERE CAN HELP ME THANX. I have the same problem with a Dell Dimention 9200 about 3 years old. Every now and then it crashes and re starts itself., or it crashes and continuously restarts itself. The system events log logs it as a System Crash. <br><br>Novatech will not touch the PC because it is a Dell. I am now stuck with an unreliable PC.<br><br>Incidently when it dies wirk it works for about 3 weeks then crashes. I am running XP Media Centre on a Dual Core PC. All cooling is working correctly and all updates are current. <br>
Solution #1
posted on May 10, 2009
Not Rated)
hotratchet
Rank: Wiz
Rating: 85%, 124 votes
Shutdown your computer. Find a known good memory module (borrow from a friend, buy some or if you have another computer check if they are using the same types of memory module then use it on the problematic computer) also, make sure your CPU's temperature is not to hot. You can check this by going to BIOS and then check the PC health status. Make sure the CPU temp doesn't exceed 60 degrees celcius. another possible source of the crashing or rebooting is bad hard drive. another one is bad power supply unit. Just try to isolate the problem by testing known good parts on your computer.
Was this helpful?
Yes
No
Solution #2
Not Rated)
fougzki
Rank: Wiz
Rating: 85%, 275 votes
It could be driver problem. But if even almost all mode of boot doesn't help. Your options are repair, restore to factory settings or reinstalls depends on the features your system has for recovery. In old ways we just reformat it and reinstall all, backup cd always on standby.
If harddrive has a fault like many bad sector. We replace the drive.
As for your other system I will say that sometimes updates are not helpful enough. In old days of xp we are not updating, commonly we just update antivirus definitions. We experienced slow down and system crashes. We just install some enhancement software in exchange for some features of xp.
If I miss something just post a comment.
Regards
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 9200 PC Desktop
Questions and Unsolved Problems for Dell Dimension 9200 PC Desktop
Do you recommend Dell Dimension 9200 PC Desktop?
Answer
Answer
why cant i use my spellcheck? it tells me that it no longer has english
Answer
How do I connect hP e9240 to direct tv to use my multimedia software
Answer
Require Packard Bell Easynote R1938 disassembly instructions
Answer
How do I get my Namco all-stars pac-man game to use a gamepad instead of the key board? I can't get... (More)
Answer
GA-8TRC410MNF-RH Hello, I have given this motherboard and I know the position of the panel... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Dimension 9200 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 437
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
