Question about Toro Lawn Mower With Toro Power Tools
I am having problems removing the top belt on the mower for replacement.
  • 246 Answers
Hello
On Some Model Mowers the Engine Pulley Must be Loosened and Lowered in Order to Replace the Top Belt.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
How to replace transmission belt on x324 john deere lawn tractor
Remove 3 bolts and guard-A
Loose hardware-B-C
Remove nut-D
May 01, 2014 | John Deere Garden
I have a Honda HRR2165VXA mower that is having issues with the smart drive.
hello, hello, Drive belt replacement for front drive mowers. remove the belt coved on top of deckand clean out grass,turn mower on side where carb is facing up,use a pair of vice grips on side of mower deck so the blade can stop,remove the blade,remove the belt cover and clean out the grass,remove belt from rear and front pulley pulleys. install new belt,put belt cover and blade back on,put front belt cover on, should work,if that is not the problem; wheels will not prepeal the mower,wheels turn only when raised off ground, Check the gears or groves on the inside of the wheel for access wear that is a common problem,check the axle drive gears to make sure turns ok, to check gear box if ok pull mower back wards while drive is engaged,if wheels turn backwards than the trams is bad,all of this is caused by the operator,by not disengaging drive while pulling mower backwards or by holding mower back not allowing to propel self completely,hope this helps,any comments welcome,thank you.
Feb 15, 2012 | Garden
My Motion Drive Belt slipped of it's pulley on a Husqvarna Riding Mower Model 917-289570. Do I have to remove the rear tire to put the belt back on?
i had a 2148. you remove the mower deck as the first step. feed the belt over the pulley on top the transmission, then put it over the engine pulley. then have someone push the clutch pedal in so the tensioner pulley moves, put the belt in the guide pulley and on the tensioner. release the clutch put the deck back on and you are good to go. notice there are little keepers welded to the frame for the front, engine, pulley and it is easy to mistakenly put the belt over them instead of under them.
a general rule is that a pulley shaped like a Vee takes the V of the belt whilst a pulley which is flat takes the flat back of the belt. if you bear that in mind you will not have a problem putting belts back on. also there is a little decal on top the deck showing how the deck belt and deck drive belt go.
Sep 09, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I need a manual or step by step instructions to change the belt on my Toro Personal Pace mower
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Read more: http://wiki.answers.com/Q/How_do_you_change_drive_belt_on_toro_lawn_mower#ixzz1MMJlZFMZ
May 14, 2011 | Toro Personal Pace CARB Walk Power Mower
Instructions to replace drive belt on toro model14ap80rp744 and daigramn
Hi. Here's the procedure on how to replace the belt. Sad to say i dont have a diagram for that. Please see below instructions.
Aug 19, 2010 | Toro Garden
Replacing the Drive Belt on a Poulan Riding Mower
Without an impact, it's will be more difficult. The only way to get back-up on the bolt is to remove the screen over the flywheel on top and put a socket on the flywheel nut
May 28, 2009 | Poulan Garden
Need to change secondary drive belt
You need to remove top belt,then jack the rear of mower up.Loosen rearend bolts so rearend drops so you have enough clearce to R/R (remove and replace) secondary belt.
May 13, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Belt drive replacement
First you have to remove the top cover over the belt. If it's still on, work it off the pully. Then you have to remove the blade, blade adapter and cover underneath. Put the new belt on the pulley underneath and push it out the slot to the pulley on top and put everthing back together. Hope that helps.
Apr 29, 2009 | Craftsman Garden
Toro 20073 self propeled, walk behind mower-how to replace belt ?
Wait until the mower cools off
1. Remove the drive belt cover from the top of the mower
2. Tip the mower up, being careful to not go too far or the oil and fuels may spill out
3. Remove the mower blade - as I recall the bolt is 5/8" (could be 9/16") You will have to hold the blade from turning (if you have impact tools, this will be much easier)
4. Remove the blade
5. Pull the pulley out or off and remove the belt - be careful to not lose the crankshaft "woodruff" key - it's the little piece of half/moon shaped metal that keeps the pulley from spinning on the crankshaft.
6. Reverse the steps to reinstall
You MUST make sure the blade is tight when you reinstall it. Also, the blade usually fits over a couple of pins - make sure they are lined up properly and the blade is installed right-side up.
Mar 16, 2009 | Toro Lawn Mower With Toro Power Tools
Poulan mower throwing the belt.
1) Remove the cover on the top of the belt and
remove the belt from the transmission pulley
2) Lean the mower back on its handle and secure it
with whatever you have that will keep it there while
you work on it, any heavy object will do
3) Remove the blade bolt, the blade, the blade
adapter and the plastic belt guard from the bottom
You should now be able to remove the belt
4) While you have the belt off, closely inspect the
pulley on the engine shaft, they sometimes get
grass built up in the groove and this will cause
the belt to run off and also wear prematurely.
Hope this helps you out
Chuck
Mar 15, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Toro Lawn Mower With Toro Power Tools Logo
78 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
