I bought this Lens second hand without a manual. So there is probably an easy solution. But When in manual focus mode, the focus ring 'clicks' rather than moves smoothly. Any ideas? The camera is a Nikon D800 and is in manual focus mode when the focus ring clicks
That lens is not made anymore. There is very little information about it and the warranty excludes some countries. You might try to see if unitedcamera.com would offer a repair service on it.That lens is not made anymore. There is very little information about it and the warranty excludes some countries. You might try to see if unitedcamera.com would offer a repair service on it.
You can't post conmments that contain an email address.
Yes. Of course, the lens isn't an autofocus lens so you'll have to focus manually. Also, the lens does not have the electronics to communicate with the camera, so you'll have to shoot in the manual exposure mode without any assistance from the camera's exposure meter. You can review photos and use the histogram to fine-tune the exposure.
You're probably going to want to use a tripod to hold the camera steady. The lens is long enough, magnifying even the slightest camera movement, and heavy enough that it's almost impossible to hand hold.
If the gears are stripped, it will require an experienced tech to repair.
That being said, there should be a small switch near the lens mount to switch between auto and manual focus mode's, be sure that that switch is pointing to A. When set to M, the little screw recesses into the mount so it doesn't try to engage, when set to A, it'll extend very slightly.
Also, Nikon has manufactured two types of AF lenses - with the motor in the body and with the motor in the lens, as with most newer lenses. Your camera should have a small screw on the lens mount that drives the focus motor between the lens and the camera, but I'm not 100% certain on that. Your camera can focus lenses with and without this type of coupling. BUT, if that screw/motor in the body is not functioning, you'll only be able to use lenses which contain the focus motor inside them, or manual focus lenses (you can manually focus AF lenses too).
Put the macro adapter on the camera and move the camera in and out from an object to try to focus the object in the display. Remember, macro is very small, very close and very small field-of-focus. I hope this helps.
If the photos look pixellated, perhaps you've turned down the resolution/quality setting? Check the manual for how to correct this.
If your photos seem generally hazy, your lens could need cleaning. Use a lint free cloth such as one for cleaning spectacles.
If all your photos have a smooth, out of focus appearance, it could be a camera fault. However, if you've recently been taking photos in poor light without flash, it could also be "camera shake". You can distinguish this from out of focus because the blur is slightly directional rather than being smooth in all directions. Points of light become lines not blurry discs.
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far. but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera. good luck mark
what is the make and model of the lens
Tokina AF-X Pro 28-70mm
