Question about Husqvarna 28cc Gas Line Trimmer
Starter assembly dogs have snapped 5 times in last year
  • 246 Answers
Hello jshepher15:
If this is an OHV Engine, then the Valve Clearances Require Setting.
It can Also be a Damaged Flywheel Key that is Causing this Problem.
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
Can not raise feed dogs
They WILL come up for you, and here's how. You see, anytime you put the feed dogs down they go down right away. But when you put them up again, you have to turn the hand wheel TOWARDS YOU (ALWAYS TOWARDS YOU FOR ANYTHING) at least one or two times before the dogs come up again. You'll hear them "snap" into place, but until you do that, they won't move at all, on ANY machine I'm familiar with.
A word about pulling the hand wheel towards you. If you turn it away from you for more than one revolution, you run the risk of throwing off the timing. I was told this by a technician of many years experience many years ago.
Sep 12, 2014 | Sewing Machines
How to install starter dog #590698 on a recoil starter for Craftsman walk behind?
Remove the top cowl/starter cover, turn over and you will see the starter dogs.
Aug 15, 2014 | Garden
Cotton is bunching up on the bottom of the fabric and then it snaps
Do you happen to have your feed dogs lowered? Tighten the top tension a bit and make sure you are holding both threads when you start a seam.
Also make sure you have recovered all needle pieces.
Dec 11, 2012 | Sewing Machines
My dog is 5 years old and I just bought it a sweater for the winter. Now my dog has never worn clothes before. Will I have a hard time getting it to put on the sweater?
It really depends on your dog. Some dogs show no resistance to trying on clothes, while other can actually be intimidated by them. If your dog is giving you a hard time, start with something small at first like a neck scarf. Then move on to the sweater.
Sep 10, 2012 | Dogs
My 1999 saturn SL2 i in stalled a new rebult stater motor about maybe one year ago , now the last 3 months about it's been a hit and miss on starting most of the time it starts then every so often
it might not be the starter it could just be a relay i would check the relay and if it is just clicking when you try to start it then that is probubly it if not maybe you have a bad batery
Feb 16, 2012 | Cars & Trucks
2004 E150 van wont start. -5 degrees last night, battery is less than a year old and tests out OK according to NAPA test. When key is thrown, just a click is heard. Dash volt meter reads normal,...
START BY CLEANING THE BATTERY TERMINALS. NEG CABLE OFF FIRST THEN POSITIVE. CLEAN CABLES & TERMINALS PUT CABLES BACK ON & TIGHTEN POS. FIRST, NEGATIVE ON LAST & TIGHTEN. IF THAT DOESN'T DO IT. LOCATE STARTER RELAY ON FENDERWELL. TURN KEY TO START. MEASURE VOLTAGE AT STARTER RELAY. IT SHOULD READ NEAR 12 VOLTS. IF NOT CHECK NEUTRAL SAFETY SWITCH. THE STARTER MAY BE STUCK OR WORN AS A LAST RESORT HOLD IGNITION SWITCH IN START POSITION, AT THE SAME TIME TAP ON METAL PART OF STARTER WITH MEDIUM SIZE HAMMER. IF STARTER GOES AFTER HAMMER TEST, REPAIR OR REPLACE STARTER.
Jan 21, 2011 | 2004 Ford E150
Century 2004: Flywheel/Starter or miracle of Lucas oil?
The starter and gearbox are not connected by way of a grinding noise.
If it is the gearbox, I would get it serviced or replaced. If starter motor, the grinding noise will be there only when the dog gear is engaged when starting.
Jun 12, 2017 | 2004 Buick Century
Trying to connect agitator without dogs getting out of place
I thought the two parts would snap/connect together. They don't. Put the agitator on upside down over the "dogs" and their connector. Holding that together put the top agitator over the bottom. Carefully put over the metal connector inside the washer and connect the bult. The bult is what holds the pieces together.
To take apart initially I had to use a socket set with a long extension and a pipe over the racket handle to get enough torque to loosen the bult
Dec 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Machine quilting
To stipple ,remove the ankle and foot, lower the feed dogs and, most importantly, lower the presser foot lever.
You can also buy a LOW SHANK darning foot which will help prevent skipped stitches. It must be screwed onto the machine instead of snapping on.
sewman7
Oct 29, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Agitator Dogs
Nothing is manufactured to last these days. What brand of dogs are you using ? FSP is the original brand and should be used. Also, check the inside of the agitator. Are the gear teeth in good shape ? It only take one bad tooth to destroy the dogs.
Dec 12, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Husqvarna 28cc Gas Line Trimmer Logo
112 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
