Question about Garden
Need to know the ratio of petrol to 2 stroke oil needed please
Could do with finding a user manual aswell
  • Tim Phipps May 11, 2010
    You need to re-post the question with the model of machine that you have. The oil mix varies between different machines.
    You can usually find the information that you need online with a little searching.
  • Anonymous Mar 28, 2014
    can i use multi ratio sny oil and or marine 2-stroke?
    President:
  • 1,489 Answers
32 parts gasoline : 1 part oil
is a good range for weed whacker engines.
Posted on May 10, 2009
Is the JCB M25 strimmer petrol only or 2 stroke please. can't find manual. Many thanks, Margaret
it is a petrol engine and the carby listed indicates that it is a 2 stroke
the oil /fuel mix ratio is 50:1 with a fuel octane rating of 91 ( do not use e-mix fuels ) recommended oil from the manufacturer specifications is a synthetic 2 stroke oil
Brand of manufactured oil optional
Jul 30, 2017 | Garden
Does this engine require mix gas?
Peter
you are too short on details like make model , 2 stroke or 4 stroke
read your user manual or look on the petrol cap as most have the ratio on the bowser emblem
so for an answer, it is most likely a 2 stroke and so-- yes-- it will require a oil/fuel mix in the tank
if you do not know it , start with a ratio of 40:1 ( 40 fuel -1 oil) and only use 2 stroke oil not normal engine oil
run at rpms and there should be a trace of blue smoke
too much smoke cut the oil back to 50:1 and no smoke increase the oil to 30:1
go google and type in user manual for ( make and model ) --and the ratio will be in that print put
Aug 19, 2016 | Garden
2 stroke petrol oil mix yz 85
Hi, Anonymous for this scenario you will need your service/owners/ manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
fuel oil ratio for yz85
YZ85 fuel oil ratio Yamaha 2 Stroke
YAMAHA YZ85 LC Owner Service Manual
OEM parts for Yamaha
YAMAHA YZ85 Owner Manual
Oct 25, 2013 | 2005 Yamaha yZ 85
I have a Poulan 625 push mower. What type of oil should I use in it? I can't find my manual.
If it has a 4 stroke engine, as most lawnmowers do, then you just car engine oil. Very occasionally you come across 2 stroke mowers.
The way to know if it's a 4 stroke or 2 stroke engine is, if it has an oil tank it's a 4 stroke engine. If there's only the one tank, i.e. you mix the oil with the petrol then it's a 2 stroke engine.
If it's a 2 stroke engine you mix petrol and 2 stroke oil at a ratio of 40:1
Jul 12, 2011 | Poulan Garden
What is the 2 stroke petrol mix for a garden strimmer, Ryobi 25cc PLT 2543 please?
hi there keithprobert
the ratio to use if using top quality 2 stroke oil is 50:1 that is 20 mills of 2 stroke oil per 1.0 litre of petrol that you mix.
but if not using top quality 2 stroke oil use ratio 25:1 that is 40 mills of 2stroke oil per 1.0 litre of petrol that you mix.
cheers pauly46
dont forget the thumbs rating
Jun 02, 2011 | Garden
Need gas misture ratio for trimmer SRM2501
pauly46 here
the ratio you should use is 50:1
that is 20 mils of 2 stroke oil for every 1.0 litre of petrol that you mix
so if you want to make 2 litre mix use 40 mils of 2 stroke oil , then add 2 litres of petrol only and give good shake
note use good quality 2 stroke oil , such as sthil or husqvarna oil from your outdoor power shop
but if using general 2 stroke oil from a garage use 40 mils of oil for every 1 litre that you mix
this ratio is 25:1 this mix is on the richer side
cheers hope this helps
May 01, 2011 | Echo Garden
I've lost the user manual for my Ryobi 25cc RPT 2543c strimmer. Can you please advise where the dip stick is to check the oil. Can't seem to find it.
Ryobi RPT 2543c This is a 2 stroke engine, so no dipstick. You mix oil with the petrol (ratio 50:1) or 200ml of two stroke oil per litre of petrol, and that's how the engine is lubricated. Hope this helps, arvidis@btopenworld.com
Apr 19, 2011 | Ryobi Garden
I have an old craftsman snowblower. It is a pullstart. I inherited this from my father. He did not have the manual.. wondering if I could find how much gas to oil mix and if it is a 2 cycle or 4 cycle...
The way to tell if it's 2 or 4 stroke is, if it has seperate tanks for the oil and petrol then it would be 4 stroke. I know that's not entirely true in today's world but up to recently it was. If it's 2 stroke then you need to mix the petrol with 2 stroke oil. Unless someone knows the right mix ratio I would start off with a rich mixture of 25:1 and see how it goes. If it's giving off a lot of smoke I'd reduce the oil a little to 30:1. It should be ok with this ratio. Use good quality 2 stroke oil e.g. Husqvarna or Stihl as some of the cheaper oils available at car service stations are not as good at protecting machinery.
Dec 04, 2010 | Craftsman Garden
I have a homelite f2020 series petrol trimmer i would like to know the petrol and oil ratio mixture please
I use 50:1 with Sthil 2-stroke oil in ALL my 2-stroke equipment. This ratio does not smoke at all, and does not foul plugs.
Never had a problem yet. At this mix ratio, you can also use it in 4-stroke engines, which means you only need 1 fuel can on site. Also eliminates the possibility of using the wrong can to fill the trimmer.
Jun 16, 2010 | Homelite Mighty Lite Lawn Trimmer
Do you mix petrol with 2stroke oil
Yes if you have a 2 stroke. You will need to look at the manual, or somewhere on the bike for the ratio.
Jun 13, 2009 | 2005 kawasaki KLX 110
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
