Question about Maytag MER6769 Gemini Electric Kitchen Range
MER6770ACW comes up with F1-1 after oven warms up?
Gemini maytag stove model mer6770acw error code F1-1. error code still comes up after the oven has warmed after 30 minutes. Once warmed up, I cancel the code but keeps coming up and until I turn off the oven and temp goes down a bit. Checked temp resistance and is around 1140ohms. I don't want to replace control board if I don't have to.
Any help on this area where eles to look? Oh one of the top burner hot lights is also staying on as if the burner was still hot? Again could this be an issue tied in with the control with the F1-1 code?
Thanks
  • 93 Answers
SOURCE: i have maytag range model
F1-1 : this indicate runaway cook upper oven.
Solution is to check oven temperature sensor,replace if necessary.
F3-1:It indicate oven temperature sensor, upper oven. You need to replace your temperature sensor.
If you need the part # let me know.
Posted on Jul 26, 2008
  • 3 Answers
SOURCE: CODE F1-1 STOVE MAYTAG GIMENI/ WHIRLPOOL S/S NO ICE TO ICE BUCKET
Sorry i still have this problem with code f1-1 appears on the screen panel especially when it get warm or hot and still need help. thanks
Posted on Aug 08, 2008
  • 3 Answers
SOURCE: maytag double oven model #
still i have the with oven heats up and stops working the codes coming on the panel are f 1-1 and f 1-3 range model # is maytag double oven mer6770acw
Posted on Sep 13, 2008
  • 409 Answers
SOURCE: Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
Posted on Oct 25, 2008
SOURCE: Maytag Gemini Stove oven will not come on get a code F1-1
Put in a new thermastat in the top oven and it works great. Thanks for the advice(from other's having problems).
My Maytag was older than I thought, so the thermastat was not available on line, but found one at a repair shop that worked. Thanks!
Posted on Jan 12, 2009
I have a maytag gemini electric double oven stove. The cooktop works, but neither oven works. I recently set the timer on it, and had a very hard time figuring out how to set it. Could that be a c
You should have a tech sheet in a plastic sleeve on the back of the oven towards the top if not there shoot the model number so i can look up code don't wish to guess they change too much
Feb 13, 2015 | Maytag 30" Self-Cleaning Freestanding...
Jan 10, 2009 | Kitchen Ranges
Oct 25, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Bake element doesnt work everything else does
hi there,
the bake element can melt for various reasons, however, i think that you problem lies somewhere else.
here is the service manual. have a look through it and let me know if i can be of more help.
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Sep 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag double oven model # mer6770acw code f1-1 and f3-1 appears on the panel when using the ovens ofcourse when it gets warm or hot the ovens stop working.thanks for help
Sep 09, 2008 | Maytag Kitchen Ranges
Maytag Gemini Electric Kitchen Range
Codes are correct .The back needs to be removed and your sensor is a 2 wire part ,The easiest way to make sure you change the right one is by turning oven to on and run a voltage test at each end of the thermostat.Rule follows : If oven is on you should have 115 -120 volts present and make sure you have the same at the other end of thermostat ,if you have the volts at one side and not the other than that is the bad thermostat. Please rate this !
Aug 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Aug 08, 2008 | Kitchen Ranges
I have maytag range model mer6770acw it give me codes f1-1 and f3-1 after 10 to 15 minths of using the oven what is that codes means and what i should do before calling the service tech. thanks
Jul 26, 2008 | Maytag Kitchen Ranges
Maytag gemini gas oven
you have to allow the broiler to warm up. give it a few minutes (maybe even ten) eventually the broiler will come on.
Nov 12, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6769 Gemini Electric Kitchen Range Logo
132 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
