MY LG AIRCONDITIONER COMPRESSURE LOADING TIME IS 15 MIN AND UNLOADING TIME IS AROUND 1 HR., AFTER 1 HR AGAIN IT COMES ON LOADING. NOW OUR AC SET POINT IS 22 DEG. AND ROOM TEMP.IS AROUND 29 DEG. AC IS 5 YRS. OLD KINDLY TELL US THE PROBEBALE CAUSES AND SOLUTION.
    Scholar:
  • 152 Answers
The system is short of gas and requires the leak to be repaired and some additional refrigerant
Posted on May 10, 2009
I have a problem with air flow from the vents when I drive for 45 minutes to 1 hr. The AC works great around town for short trips but when I have a long trip, after about 45 minutes air flow almost...
the evaporator is freezing up, this then limits the air flow. if you stopped the vehicle and after a short time a very large pool of water would be leaking out of drain tube from vehicle (on ground under vehicle) confirming this. some water is normal. the evaporator thermistor or temperature sensor (thermostat) needs setting or replacing, or checking that it hasent fallen off of evaporator core.this then causes the air compressor to continually run and not cut in and out like it should, so it freezes up after longer operation. A/C system being slightly over full, or sticky/jammed open TX valve can give same symptoms also. take to automotive A/C place to check system with pressure gauge set
Oct 07, 2013 | 2000 Chevrolet Blazer
Receptacle. the box says 208/230 volts ac 15 amps
Buy a NEMA 15-R recaptacle at an electrical supply house.
Jan 27, 2010 | LG LWHD1800R Wall/Window Air Conditioner
How do you set the clock on the AM/FM cassette radio on this model
Without knowing which radio you have??? I will guess. With the radio OFF, push the SET button, now use the Seek/Scan buttons to change the time. when done, push the set button again.
Dec 18, 2009 | 1997 GMC Safari
I have a lg 1.5 ton split ac , problem is compressor trip in 5 to 10 minutes ang agin start in 10 min..i will call service centre , he wl change capactor and service indoor n outdoor unit ,but problem will...
first check the compressor amps and the condenser fan rotation are correct if ok check power come to the compressor without interuption (from control in the indoor unit)if the remote setting are ok correct voltage to the compressor may high pressure stop it or low pressure compressure overheat.and if this was repeated many time the best to change the compressor.
Aug 28, 2009 | Heating & Cooling
Can't set the ttime
Press and hold the hr button for 3 seconds until the 12:00 starts flashing, then press the hr button again to set the hour. Then, press and hold the min button for 3 seconds until flashing starts - press the min button until minutes set.
-Tha Mp3 Doctor
Mar 08, 2009 | GE 106591 Coffee Maker
Changing the time pioneer DEN2000MP
The solution that worked for me is:
1) turn off the radio.
2) Push and hold the power button down (the dial). DON'T release the button.
3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
4) use the up/dwn, right/left buttons to set the clock.
5) turn off the unit by pushing the power button (again, the dial).
That is it. the clock should be set.
Hope that helps,
Nov 11, 2008 | Pioneer DEH-2000 CD Changer
Mitisubishi Ducted Reverse Cycle AirConditioner
1.check blower fan motor.if blower fan motor donot work then compressure trip after 5 to 10 minitue.
2.make switch of airconditioner n reset again.
Feb 11, 2008 | Mitsubishi MS12TN Air Conditioner
Cuts in and out
I suspect a bad compressor run capacitor. Take the unit to a service facility & have the capacitor & overload protector replaced. The overload will be weakened by the repeated cycling.
Jul 14, 2007 | Danby DPAC8020 Air Conditioner
JVC HR-S9700 TAPE STUCKS, HAVE TO BE PULLED OUT, CASSETTE DOOR REMAIND OPEN,VCR SWITCHES OFF-CAN NOT BE PLAYED AGAIN
Check out the drive that works the unloading and loading operation of your machine. Also check the switch that is activated by the presence of your cassette. If something is wrong with the latter, the tape will not load and unload properly. And under those circumstances your machine will not work.
Try Google search for your questions. You may get lucky and get the answers right there!
Mar 13, 2017 | JVC HR-S9600 S-VHS VCR
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
