Green power LED flahingno other reponse
DELL 1704fpt. Power LED flasing green no other response. Found power supply cap,s faulty. Replaced 2X 1000uf/10volt electros and all good. New to this but would like to help so pls disseminate as appropriate. regards Mike
  • Frank Zhang
    Frank Zhang May 11, 2010
    DELL 1704fpt LCD monitor, do you check the power output voltage without loader and make sure no other component damage.please let me know
  • 157 Answers
Now when that happened it might have fried your hard drive and motherboard. So you will need to get both of those checked out!
Posted on May 29, 2009
I got dell optiplex 755 desktop computer in the power supply unit at the back there is a small button and a green light what are these for??
It help diagnose problems with your computer
A solid green light means the computer is operating normally.
A solid yellow:- the power is operating fine but your computer not processing data. This could mean there is a problem with the CPU or another component on the motherboard.
A blinking yellow light: power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode
Jan 29, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
I have a Dell ultraSharp 1704FPT 17 in.Flat panel LCD monitor and the power button keeps on blinking green but nothing shows on the display.i tried my cpu on different monitors and it worked well but my...
I think you answered your own question--the computer works well with other monitors, but not this one.
I would suspect that this one is bad.
You might try to do this: Start the computer in safe mode and see if your monitor is reacting to video settings that are beyond it's capability (although if this is the case it should tell you it's out of range).
If it works in safe mode, try resetting the resolution to see if it will work with the new monitor (I seriously doubt that this is the problem).
Oct 07, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Power light flashs off and on and pc clicks
Most newer models of Dell computers now have a diagnostic LED surrounding the power button on the from of the computer. When you press the power button to boot the PC, the light should be green and remain green under normal circumstances. Any other lights will help you troubleshoot the power issue you are having.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data. This could mean there is a problem with the CPu or another component on the motherboard.
A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode.
So use the LED power light codes if your Dell computer has them. Also pay attention to any unusual beeps or sounds coming from the computer. Well, I was sure that the voltage selection switch was in the right place. And I found it highly unlikely that the processor power cable would suddenly unseat itself. Ugh.
Then I had an idea. I flipped off the surge protector and then flipped it back on. Tada! No more orange lights. Weird. The moral of the story: try the simple stuff first.
I hope this helps and please dont forget to rate my answer. Thank you! :D
Apr 28, 2010 | Dell OptiPlex SX280 PC Desktop
Only amber light is on when start...no green lights...
its a power problem. Your power supply is not giving enough power
Dec 08, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Falshing green power biutoon.
Verify all cables are secure, try reseating them. If the power led continues to flash, this usually means the power supply in the monitor is bad.
Oct 03, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Power light flashing HP Compaq Presario SR1230NX PC Desktop I powered the unit down; when I tried to powered it up the only reaction is a green led flashing. The led is located in the back close to the...
Sounds like the Power Supply is bad likes its not able to power on itself. Best thing to do, try a different known good power supply and attach it to the motherboard, if you get the same symptom with the machine not powering on then its a bad motherboard. If the machine does power on then you know your original power supply is bad.
May 28, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
17 in dell monitor
Please disconnect the Monitor Data cable from Computer.
If you see Dell Colored bars, it means, monitor is working fine,
If still black, please ask for replacement, since Monitors have 3 years of warranty if not purchased with the computer.
Now connect the cable back to computer and turn the computer off by holding the power button on computer and turn it back on...
Blinking Green shows that computer is in sleep mode......
Hope this should resolve the issue.
Nov 06, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Latitude D505
Just repaired a laptop with the same symptoms:
Won't charge the battery, won't power from AC.
Also if you power the AC adapter when not connected to laptop you get green power LED on the adapter. When you plug it in the laptop the green power LED immediately goes out.
Opened it up and found SO-8 P-ch mosfet by the DC input socket. Source (pins1,2,3) is connected to the inner barrel (+19.5V), Gate 4 gets driven low, applying the input to the Drain. (pins 5,6,7,8) On my board the drain was short to GND. Applying power directly to the Drain via a current limited bench PSU (set 1A limit) showed a couple of volts.
Placing a finger on the opposite side of the board revealed a SMT ceramic cap getting hot.
CP13 I think. Opposite side to the power connector, almost under it. I would guess at 1206 or slightly larger and there is an 0402 cap just next to its bottom pad at 90 degrees to it. Cap was glued before soldering so had to flow both sides at the same time with a soldering iron and force off. Would likely have been 1uF or bigger 25V. Removal restored operation. Runs OK without but would suggest putting something in there 0.1uF 1206 50V, perhaps a couple stacked ?
BTW you have to strip down everything and remove the main board to get to the cap :-(
Hope this info is of use....
Robin
die4laser.com
Jul 26, 2008 | Dell POWER SUPPLY PS-5201-5D (PS52015D)...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
