Question about Sanyo AVM-2557 TV
Sanyo 25" Standard Tube Vertical Deflection Problem
I have an older 25" Sanyo Standard Tube TV with a Vertical problem, all I have is a Horizontal line across the screen, have sound and there is a picture there, just can not view it because of the no vertical deflection issue.
  I have gone through the vertical circuit, replaced the output checked and replaced capacitors in the circuit, also checked voltages, however I'm not sure what the Pump Up Voltage should be, still no vertical deflection, I'm thinking its a vertical drive signal issue, but do not have a working scope to determine this, any ideas on this, has anyone run into this before?
  • Mark Moore Oct 13, 2007
    Hi Modern
       Well, I got my scope working, there is plenty of drive too the vertical output, however on the Pump Up Pin there is vertually nothing, and as well vertually nothing to speak of on the Output Pin, I've checked the Yoke and Yoke path, all good, and I've checked the Pump Up Pin path and related components, nothing! I'll be honest at this point I'm pretty much decided this is a no fix situation.  I Also installed a known good vertical output IC as well.
    An expert who has answered 500 questions.
  • 556 Answers
You can proceed as follow to fix it.
  1. reduce brightness to minimum to avoid screen burn.
  2. check voltage on vertical uotput
  3. check yoke connector for loose.
  4. check v/yoke winding.
  5. check v/drive from signal processor to vertical output
now your problem how to find out whether drive is there or not it is very simple even you donot have scope.
you simply touch with screw driver or meter prob  at the poibt where vertical signal is input to vertical stage
if h/line is spreadindg or tries to spread then your output is ok &problem is in drive ckt.
for schematic try given site give model no &download it
hope this will help
Posted on Oct 12, 2007
How can fix CRT TV vertical bar on CRT
You have no horizontal deflection when you have a single vertical bar in middle of screen. Check out horizontal output tube or transistor of set and environs.
Jun 23, 2016 | Televison & Video
No verticle deflection
NO VERTICAL DEFLECTION MEANS YOU HAVE A HORISONTAL BAR IN THE SCREEN?, Check the power supply for the correct voltage to the vertical circuit, check the vertical DRIVER circuit, check the conductivity of the YOKE (vertical winding) on the neck of the tube
if you have a VERTICAL bar in the screen (common mistake) check all of the above relating the HORISONTAL circuit
good luck!
Jan 13, 2011 | Sanyo DS27800 27" TV
Sir.3#lang sa gitna sa ibabaw nito paliit na horizontal sana matulungan po ninyo ako
You will need to resolder the vertical IC and replace three capacitors that are near or next to the vertical IC. This will restore you television. If you must do the repair I suggest having someone replace the starting capacitor or capacitors in the the horizontal deflection section of the TV as well. The values in the deflection may be 160 or 200 volts at 1Mf and 160 volts at 4.7 Mf. You will correct two problems in one repair. Your TV will last a few more years. Thanks for asking!
Nov 28, 2010 | Sanyo DS31590 31" TV
Vertical line in center have replaced vertical output ic
If the line is vertical then the problem is no horizontal deflection. The vertical chip is probably fine.
Check connections around yoke (thats the connector with at least four wires that goes up to the coils around the neck of the tube)
Maybe that TV has two horizontal output transistors. One for deflection and one for high voltage? Check both of them. Look for bad solder joints!!!
May 21, 2009 | Sanyo DS31520 31" TV
If the line is "vertical" then the vertical circuit sounds OK. The problem would be in the horizontal deflection.
Check yoke connection and solder around horz defl circuit.
If the line is horizontal then I would suspect the vertical IC.
Apr 02, 2009 | Sanyo DS31520 31" TV
RCA-single horizontal white line
Your vertical deflection IC is bad.
Nov 04, 2008 | Televison & Video
Horizontal lines
may be vertical deflection circuit bad capacitors and is a job for experienced tech
Apr 01, 2008 | Philips Magnavox MS2530C 25" TV
Sanyo DS31590 31" TV vertical deflection
If the vertical is not defective or shorted there is a possiblity of bad solder connections on the vertical ic. If connections are good and has b+ voltage to the chip replace chip which is IC 501 LA7841 or LA7845 and change c511 (decimal point 1 film capacitor)
Dec 28, 2007 | Sanyo DS31590 31" TV
RE:Sanyo 27 " Flat Tube Set
What about a cap in the power supply for the vertical circuit? Usually found near flyback-- 2)check vertical drive signal (comes from jungle IC ).Use your scope....
Sep 26, 2007 | Sanyo DS27910 27" TV
Televison & Video Logo
189 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
