Question about Kenwood DNX7100 Car Video Player
The entire unit stop working
My car battery drained after leaving my car headlights on all night. Then, after recharging the battery and getting the car running again, my Kenwood video player/radio could not be turned back on. The entire unit is now dead; not even lit. Some people have told me that the unit may have a code which is needed in order to turn it back on. Is this true. Does anyone know how to turn the unit back on?
  • codeman01 Nov 26, 2008
    so i have a very similar problem and it is driving me insane. i bought the dnx7100 in november of 2007 and had it installed im my 2004 VW GTI. everything was working great and i loved it, but i got rid of the car so i had it removed. i recently decided a year later to put it in my 2008 jeep wrangler. best buy hooked everything up, but they couldn't power the unit on at all, not even a light. they checked all of the conections with an amp meter and there was power all the way up to the unit, but it just will not power on for some reason. luckily i got an extended warranty, but before i send it back to kenwood i am going to call their technical support and see if they can trouble shoot me so i will post if i figure something out.
  • thatboyc1 Dec 04, 2008
    my kenwood is not powering up due to a code problm can you help me bypass are remove the code
Did you check all fuses already?
Posted on Dec 02, 2007
Mazda cx-5 i-stop not work on at night when i driving with headlight on?
Autostart/stop is dependent on battery voltage above all else. If the system senses battery lower than perfect charge, it disables automatically the prevent battery from draining due to frequent restarts with inadequate charge time (especially in stopand go traffic). When your headlamps are on, you typically have an extra drain of 12-30 amps, and more on some cars with HID headlamps and multibulb driving lamps. The alternator knows these cars will draw so much (over 30 amps) if left on for a 2 or 3 minute stoplight wait, the battery may get drained to below optimal...so the system will frequently refuse to activate when headlamps are on. On cars that are voltage sensing only, or have date coding/mileage coding of the battery (BMW mainly), a new battery will re-enable the night use on such a system. On cars where it is sensing load, you may have to accept that you cant use the system at night.
Jan 04, 2018 | Mazda Cars & Trucks
2010 G37 - battery was dead - jumped it off and drove it for twenty minutes. Next morning it wouldn't start and now it wont stop clicking (like a relay). Any suggestions?
if the battery goes dead or low it must be recharged with a charger, driving the car will not recharge it properly. The alternator is only meant to maintain the battery, not recharge it. Get the battery recharged and verified and then try again.
Mar 02, 2015 | 2010 Infiniti G37 Coupe
Troubleshoot/Repair Remington MB-1000 Beard Trimmer
If you leave the batteries in the charger with the mains power turned off then the batteries are probably being drained by the charger. Get new batteries and when flat (only flat not just used or part flat) recharge fully then remove from the charger unit. Rechargeable batteries have a habit of developing a memory as if you recharge a part charged battery then it will only recharge to that flat point
May 30, 2013 | Remington MB-1000 Professional Beard and...
Replaced the k134 car cuts off after engine gets hot. guessing 40 minutes of driving
The battery in most cars is used only for starting and operating electrics when the engine is not running.
After that, the alternator provides power to operate ignition and electric systems - and of course; recharge the battery. A faulty battery shouldn't cause the car to stop running. If the alternator is not functioning properly, the car will get power from the battery instead. When this happens, the voltage will drop quickly - depending on how many electrical accessories are on, etc. You will notice headlights becoming dim at night just before the engine quits. The car would not be able to start / run until the battery is recharged.
Nov 08, 2012 | 2000 Cadillac Catera
Tinker Bell Night light
Try replacing the two rechargable AAA batteries in the mushroom.
Apr 19, 2012 | Cars & Trucks
What's draining my battery?
1: Faulty Battery: inspect and fill it with distilled water, if needed: battery may be shorted out
2: Alternator: the voltage regulator inside alternator will drain battery when it quits working: break unit open, and replace the regulator: or replace the entire unit with a rebuilt alternator.
3: Loose alternator belt, which slips and does not allow for enough revolutions to fully charge the battery - especially at night-time, when you are running your headlights and such.
Now, to do a test, which will tell you if the alternator has failed, in 10 minutes:
1) Simply loosen, but Do Not Remove, the battery post clamps / cables, from battery.
2) Start Engine.
3) With engine running, REMOVE both cables from battery posts (engine should continue to run) (if it does not / dies out upon removal of cables, then test no further): ensure to secure the positive post cable - wrap it with a rag, or set it on cardboard or rubber, so it does not ground: then reach inside, and turn ON your headlights: upon doing so, and highlights are ignited, if the engine dies out - if the engine quits running the instant you turn your lights on, with the battery cable disconnected off - that means that the alternator is Not Charging; that it is not producing enough current to run itself / maintain itself running / maintain the engine running; so it does not produce enough electricity to keep your battery fully charged - and, is in fact, draining your battery of any available current which was stored in it.
So, more likely then not, it's the electronic regulator / diode stored inside of the large alternator unit: but, because, your car is a 1990, the brushes on your alternator are shot anyway; so you are better off just replacing the whole unit and belt: and battery if need be.
I hope this helps somewhat: where, with ENGINE RUNNING at normal / higher idle speed, and BATTERY DISCONNECTED, and ACCESSORIES RUNNING, especially headlights and heater - the Engine Must Remain ON / Running - on solely alternator power.
In that: the battery is only required to start the car; stored energy / current for the purpose of starting the car, as supplied by the alternator - and adjusted by the regulator: a faulty regulator will fry your battery, by over-charging / allowing too much electricity to flow.
Good Luck,
Ray
Sep 18, 2011 | 1990 Lincoln Town Car
Hi, The battery has suddenly drained on my 1999 T Reg Mercedes C Class Estate. Yesterday the horn suddenly sounded for no reason and would not stop....then it stopped on it's own. This morning, no power in...
According to the Mercedes forum, you are not alone, the alarm system goes off at random, it has something to do with the tow button, disabling the horn doesn't stop the alarm and the lights keep flashing. But the horn is quieted. I would trash the alarm system, or pay the dealer to mess with it, which is usually an expensive joke. You have insurance on the car, let them steal it. I stopped worrying about my bike, I leave the key in it. Nobody touches it. Before I couldn't leave site of it. Now, I don't care. Let them have it, I'll get a new one, Anyway, check out mercedes forum.
Jul 21, 2010 | 1999 Mercedes-Benz C-Class
Headlights causing battery drain while driving?
Hi:
Though your car seems fine without using the headlights, you have a charging problem, and need to get a couple things checked out. First make sure your battery connections are clean and tight. Your alternator belt should also be checked to make sure it is serviceable and properly tightened too. Your alternator should be checked under load, and lastly, your battery too. Most auto parts stores, such as auto zone,will check your parts for free,so you should only be spending money on what is broken!
Feb 17, 2010 | 1990 Honda Accord
Battery keeps loseing its charge
Look at ths page I put up will give you a clue. If you want to get it done right sometimes you got to do it yourself.
http://www.fixya.com/cars/r3955386-check_battery_altanator_most_cars
Jan 28, 2010 | 1997 GMC Sierra
Kenwood DNX7100 Car Video Player Logo
179 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
