Question about Acer Aspire 5315 Notebook
Acer Aspire 5315 brings up message problem with Device manager
Somehting to do with kontiki?
Sound problem on Acer Aspire 5315
you want to download a new sound driver i think your sound driver is not working
Jun 28, 2009 | Acer Aspire 5315 Notebook
Acer 5315 will not start up windows
check the BIOS setup screen, when you get the ACER screen press F2 or F10 or the DEL or END or ESC key one of those will get you into the bIOS SETUP. Once there revise the boot order, make sure the CD is first to boot then HDD. Also review to see if the BIOS recosgnized the HDD. the symptom you are describing may be a bad HDD.
Jun 02, 2009 | Acer Aspire 5315 Notebook
I install window xp. now audio is not working
In all likelyhood, the audio driver is not installed.
Check your drivers by going to your device manager and look for devices which have a yellow dot next to them. You will find device manager by right clicking "my computer" and choosing "properties". If you find a yellow dot next to your audio card, go to the Acer web site at: www.acer.com and select your product from the drop down lists.
Regards,
Graemevm
Apr 22, 2009 | Acer Aspire 5315 15.4-inch Notebook PC
Acer aspire 5315 will not boot up, indicating no bootable device
Sounds like you wiped out the harddrive try reinstalling the os if that does not work you may ned a new harddrive
Mar 16, 2009 | Acer Aspire 5315 Notebook
My laptop acer aspire 5315 cannot see the dvd/cd rom,so i canoot play any cd or dvd.
do one thing go to the device manager
right click my computer > properties > hardware > device manager
than go to the option that is ide/ uninstall the secondary channel and than restart the system
the issue should be resolved
Jan 10, 2009 | Acer Aspire 5315 Notebook
Acer 5315 elock
Go to device manager and click on your dvd/cd drive. Double click on this and enable the drive.
If driver is missing, go to Acer's website and download your dvd/cd device driver.
Dec 08, 2008 | Acer Aspire 5315 Notebook
Sound problems
well, the driver is not installed properly.. you must install it first so that u can use your cam.. f installed already, check your connections and make sure your cam is detected by your computer
Nov 14, 2008 | Acer Aspire 5315 Notebook
Acer aspire 5315 laptop cd/dvd drive stop working like there was none
This will be one of two things, 1- a driver glitch, you will need to uninstall the drivers for the cd/dvd drive from the device manager, then reboot. The machine will find the drive and reinstall the drivers automatically. This will fix it if it's a driver problem. You can also try any updated driver utilities, or patches for the drive from Acer's support site. 2- the cd/dvd drive has failed and needs replaced. These are basically plug and play devices, they either work or they don't, so a majority of the time when the machine stops recognizing the drive, it's because the drive has malfunctioned. Unfortunately, these drives are considered sealed units and replacement parts aren't available.
Aug 30, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
