Lenmark printer black ink doesent print,
Ink full.all is working ok ,it prints but seems theres no ink .it worked ok untill lastr week. have donetest page but no blck ink and have turned up darker set.thanks for any help. apprieciated. annette
  • annette77p May 10, 2009
    it is a new cartridge not a refill ,a genuine one. thanks i will replace it, abit let down as they are so expensive ,it did work at first and the in level is high.thankyou.
  • 28 Answers
Suggest installing a new black print cart. espically if you have refilled the current one.
Posted on May 10, 2009
MX700 printer does not print in black
you have a clogged jet and ink has dried inside i reckon... the only other thing it could be is the message from the logic board (its motherboard) inside printer isnt getting to the print head or print head itself has malfunctioned - i would suggest to fix but it would probably be cheaper to buy a new one but dont give up.... sometimes they do work if you print pages even tho there is no flow and the heat may dislodge blockage if there is one... But heres a video that may help...
May 06, 2017 | Canon PIXMA MX700 All-In-One InkJet...
I have renewed the black ink cartridge but the printer does not print and i want to clean the print head but do not have a clue and i am very unclear on my computer so need step by step help the printer...
there is a utility in your printer software , using that you can clean the head of the printer, if this does not solve your problem use the alignment option from that utility
Jul 29, 2011 | Epson Stylus C66 Inkjet Printer
Black ink cartridge holder not working , can not print with black ink cartridge holder, when i use the colored ink holder printer works ok
The problem you are describing is with the black ( BC-10 ) print head and not with the printer.
1. Check your black ink tank and be sure it is not dry.
2. Run the printer through one DEEP cleaning cycle and see if that improves the print.
If your black ink tank is full, and the deep cleaning cycle produces no improvement, you will need to replace the BC-10 print head.
Mar 11, 2010 | Canon BJC 85 InkJet Printer
Black ink jet doesn't print
if your black ink does not print, there is a possibility that the nozzle of your printer are clogged by dried inks, to print a nozzle check. turn off the printer then press and hold the paper (middle) and power buttons together for 3 seconds then release. it should feed the paper and print a nozzle check pattern. if the black lines are full of gaps or breaks in the line. you need to do head cleaning to remove the clogs, press and hold the ink button (teardrop) for 3 seconds, wait until the power (green )light stopped flashing. turn the printer off then print a nozzle check again. just repeat the head cleaning process until the black pattern is ok, as well as the other colors. all shld. be complete.
then print
Feb 11, 2010 | Epson Stylus Photo R200 InkJet Printer
Black ink not working
Print out a test print to see what comes out. If the printer is printing the black and colour blocks then the printer should be OK. If not then check the black and colour inks to make sure they are OK and remove each of the cartridges and reinstall them. Then run a full cleaning cycle and reprint the test sheet. Keep doing this until all the inks are printing OK. Then run an alignment test making sure that there is plain white paper in the paper tray and adjust the printer as necessary.
Oct 07, 2009 | HP Photosmart C7180 All-In-One InkJet...
I just bought a new printer today its a lenmark Z2300m Color Printer i only have color ink for it do i need black ink for it because everytime i try to print it comes out greenish
Under your printer preferences there is a way to print gray scale. SO even if your image is in color, it will print black and white. Every printer interface is different, but when you go to print, there's usually a properties or setting button that will bring you to another page from the initial print menu. here is where you would choose gray scale.
If you try for black with only a color cartridge, it'll come out a dark green or blue color. Or on some cases, it will tell you it's out of black and you can't print.
Sep 30, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Lexmark X5150 yellow and black ink not printing
Take a piece of kitchen tissue (not cloth) dampen it and wipe over the print heads. If you don't see any ink on the tissue do it again until you do, Then let them air dry and try again.
May 02, 2009 | Lexmark X5150 All-In-One InkJet Printer
No black ink prints but colors almost perfect
Sorry, no good news: Infact you need a new printhead. The refill ink has clogged the filter inside the head which is in front of the nozzles. Another reason could be: Did you unplug the printer from power in those weeks of none use? If yes, the head has dryed out. In future: Do one simple test print once a week when you dont use the printer too often. That keeps the nozzles going :) There is some hope, too: See here how to fix it on your own http://www.fixya.com/support/t209702-get_color_print_black_works_fine (Following the link given to hstt.net : choose mfc 215c inside)
Oct 05, 2007 | Brother MFC 420CN All-In-One InkJet...
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
66 people viewed this question
k24674
jasbo
jasbo
