Question about M-Audio StudioPro 3 Computer Speakers
Cant get monitors to work
I cant get the monitors to work whatsoever. it doesnt seem like its gettin any power.
help me?
    Habit-Forming:
  • 188 Answers
Check all powre cable properly 1st ,,,
if no diplay..then u r moniter is ded & contact ur computer dealer imideatly...
best regards & best of luck..
Posted on Oct 12, 2007
  • SHIVAJI YADAV
    SHIVAJI YADAV Nov 06, 2007
    hey dude.....u did not make any repley....for u r problem solution ...
    hope it is solved.......
    Was this solution helpful? Show your Appreciation by rating it:
    pls vote for me man..& IF U R PROBLEM IS SOLVED RATE MY SOLUTION AS SOLVED
DS240WB worked fine but seems now not recognizing signal and fails to turn on
The reason why your monitor might not be recognizing a signal is because the graphics card in your pc might not be correctly plugged into a pci slot or your internal graphics may have a short somewhere. If the monitor turns completely off after it cycles Then it might be an internal problem with the backlighting in your monitor screen
Dec 07, 2013 | DoubleSight DS-240WB Monitor
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
I dont have any dash power at all. Whats going on? HELP?
Double check the "gauge" fuse inside in the fuse panel lower left of the dash.
Dec 01, 2011 | Toyota Pickup Cars & Trucks
I have a Dell 2007WFPb 20`` Widescreen TFT Flat Panel Monitor. I cant seem to power up. What is the problem here?
Here is one of the simple solution to your issue.
I suggest your try a different outlet, if your using a strip, try connecting it directly to the power outlet. Also most of the monitor has the same power cable as the computer, try swapping the power cable and make sure only the power cable is connected to test the monitor. If still doesnt power on, call Dell and have it replaced if still has a warranty if not, repalce the monitor.
I hope this resolve your issue.
Thank you for choosing fixya
Mar 04, 2011 | Dell 2007WFPB LCD Monitor
Im not gettin any power when i turn on my unit and everything is hooked up correctly
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 10, 2010 | Pioneer AVH-P4000DVD Monitor
Syncmaster 913v not optimum mode
I just resolved this problem for my SyncMaster 913N.
It seems to be a known issue, however it can take quite some time for the problem to occur. In my case about 3,5 years, so well out of warranty.
Short term solution: unplug your monitor from power. The switch on the front is not good enough. Pull the plug and leave it for an hour or so (all night if you can). Good chance the monitor will work next time you power it up.
The problem will is likely to come back..
Permant fix requires some basic soldering as per this video:
I just managed it and it has been ages since I soldered a resistor so you may very well be able to do it. I spent $25 on tool and part and saved me from buying a new monitor.
Mar 20, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
My monitor doesnt work while my cpu does
Try connecting the monitor to another desktop/laptop, to see if the monitor still works.
Try connecting another monitor to your computer,
to see if the video-card on your computer is producing any output.
Feb 02, 2010 | Fujitsu Siemens SCENIC P300 PC Desktop
No sound whatsoever on LG KG800 Chocolate Phone
easiest way to solve this problem. go to call settings and TTY mode. and switch it to TTY + talk ... if that doesnt work then fiddle around with the other TTY settings untill it does. this disables the earpiece
Dec 09, 2008 | LG KG800 Cellular Phone
I have a Proview 700P MA-782KC LCD Monitor that has a slight 'hums' when plugged in, but doesnt seem like it's getting power. The LED doesnt do anything (stays off) and the On button no longer responds....
can u tell me the model no on the power supply plz as i moved home and lost my power supply soz i cant help u with your problem but maybe you could help me with mine thanks
Mar 28, 2008 | Televison & Video
M-Audio StudioPro 3 Computer Speakers Logo
171 people viewed this question
Top M-Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
jason
Richard Hemingway
Richard Hemingway
Level 1 Expert
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
