Question about Home
Clean pump on display - Home
    Champion:
  • 248 Answers
Freeall spray pump and motor short run trial
Posted on Oct 03, 2009
W3240 washing machine displays '---'
Possible that the pump is cloggged , remove the pump and clean , if ththere is dirt, fabric or foreign particles it cannot pump and so will shut off the processor.
check this link for tips; Pump
May 31, 2012 | Miele Washing Machines
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont drain displays OE. Pump makes a vibrating sound lie it is plugged already checked filter cleaned it removed hose how do you replace the pump?
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. If the issue returns then yes you should replace the pump, please check this repair manual on how to replace the pump. Please get back to me if you have any other questions.
Kevin
Dec 12, 2010 | LG WM2688HWM TROMM SteamWasher
F2 error after oven cleaning came across my display. I had to throw the breaker. Is this something that can be easily fixed?
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Mar 09, 2010 | Jenn-Air Cooktops
Will not drain and displays code F2. Makes a
ck your pump.take off your access panel get a bucket and unscrew your pump.might just need cleaned out if not then pump bad
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have 1-min on the digital display. wait 15
It sounds like you have a restriction going to the pump.You have a filter which needs to be cleaned.
Nov 10, 2009 | Whirlpool GHW9100L Front Load Washer
Kenmore washer he3t F2
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool awo3761 how do i claen the pump
Remove the lower panel on the front of the washer. The pump will be just inside. Twist the pump knob to unscrew. Clean it. Replace it.
May 14, 2009 | Whirlpool Washing Machines
Ariston AVXD 129 washing machine displayed F--05
my washing machine displayed F--05 and water is not going out, I clean the pump and start the machine but the water is not going out. wHAT TO DO?
Jul 01, 2008 | Washing Machines
Home Logo
35 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
