Question about Toshiba Satellite Pro M15-S405 Notebook
Help!! I have just purchased a toshiba satellite, October 1 I got it. Tonight when I went to go on it, the screen has gone off, the power is on and wont turn off and thats it, that is all that is happening. Sue
    Scholar:
  • 116 Answers
Sounds like its in sleep mode.
Hold in the power button for at least 10 seconds. That will power it off :)
Posted on Oct 12, 2007
SOURCE:
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
My laptop was plugged via ac adapter to the wall socket when I turned it on tonight. It went through normal booting up and I typed my password but then all of sudden the screen went black and I could not...
First- I have to know that the battery and the charger are ok. This sounds like a power problem. Take the charger to a shop and have it checked. Have the battery checked. If both are good then it is probably the connector where the charger plugs in.
Aug 16, 2010 | Toshiba Satellite A100-S8111TD Notebook
The cursor of my toshiba satellite has gone out of control. It keeps on jumping uncontrollable when i attempt to use the touch pad. I can only use the mouse. Please help
try to check your touch pad without AC power i mean run your computer on battery if your touchpad working ok on battery so there is a problem with your adapter ampere ask any local repairing center to check your adapter ampere or change your adapter and do not purchase compatible adapter, compatible adapter can not resolve your touch pad problem go for original adapter from toshiba
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 23, 2010 | Toshiba Satellite A20 Satellite A25 Series...
Toshiba Satellite a45-s130 screen has gone real dark need a flash
Paul, Georgiana and You, 1. do you have an antivirus installed on your laptop? if not, then install one rightaway. 2. also from start->control panel->system->hardware->display adapters and monitor. uninstall the display adapters and reinstall them. similarly uninstall and reinstall the monitor drivers. 3. go to http://www.drivershq.com/Drivers/Toshiba/Satellite/A45-S130/4183/9941/10606/Drivers.aspx you will find here a driver detective that can detect your driver problems. try with that. 4. on the site above you will find drivers, for you to download and install on your laptop. if you still have problems, then you have
Sep 02, 2009 | Toshiba Satellite A45-S130 Notebook
Toshiba Satellite Not working
Do you get any power when you try to turn it on? Is there anything that displays on the screen?
See if it is out of warranty for sure. Call Toshiba. If it is, then you might try to remove the compartment lid that has access to the CPU fan/heatsink. Look for clogged lint in the fan. Remove it if possible.
Feb 05, 2009 | Toshiba Satellite A60 Notebook
Screen Brightness gone too low on toshiba satellite 1110 laptop
Hello Tim,
Sorry to answer u by this news :
this problem u have happening by 2 cases ..
1st Case :::: that's maybe ur screen lamps is broken ..so u can see the data but very dark or no Back-light .. so u will need to replace the screen..or advanced option but with expret person to change the lamps from another broken sceen,,
2nd Case ::::: The high-voltage board..it's small board built below the screen to give the screen the right voltage to light on .. so u will need to replace it also ..or Advanced option also but with expert electronic person to check it ..
best luck.
Dec 01, 2008 | Toshiba Satellite 1115-S103 Notebook
Toshiba Laptop Dark screen-cant really see it!! help!!
sounds like your inverter is gone. The inverter supplies voltage to the backlights of your lcd.
Mar 25, 2008 | Toshiba Satellite A70 Notebook
Toshiba p200 no display
That is not typical ,, If me. I would return it to place of purchase and get another one ,
best of luck
Nov 16, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite Pro M15-S405 Notebook Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
