Question about Plumbing
The pop-up drain stopper on my American Standard bathtub no longer seals in the down position. Any suggestions? KG
    President:
  • 1,489 Answers
Unscrew it (turn left/counterclockwise), thoroughly clean it, lubricate it with liquid dish soap, screw it back in. If it still doesn't work, best bet is to get a replacement.
If, when you remove it, you find the gasket around the bottom is torn, probably ought to replace it and forego the cleaning step.
Posted on May 10, 2009
How to remove bath tub pop-up stoppers
Put the lever in the open position so that you can grab the stopper. After you get a grip on it, put the lever in the closed position and the drain plug and rocker assembly will pull out in a horizontal direction.
Sep 25, 2014 | American Standard 1583.470.020 Universal...
About a year ago I installed an American Standard Cadet lavatory faucet with the Speedconnect drain. When I fill the sink with water it leaks out very slowly. I have not had any success in repairing this...
Try adjusting linkage under sink,squeeze metal piece and pull off to adjust to different hole setting,you can fine tune with small screw on chrome rod,so you can pull stopper down tighter
Jan 30, 2011 | Home
Bathroom sink needs new drain, leaks under counter
Is it a new sink? Most of the time if it's new you'll have to get more pvc pipe because the new tail piece that comes with the new faucets usually is either longer than before or shorter. Yes you can get another tail piece or you may be able to by a longer pvc piece to to hook up the the metal tail piece. Make sure you have the plastic seals inside the pipe where they attach together or it will leak. Once you have it all together close your stopper and fill the sink with water and then pull the sink stopper and watch for leaks if it dont leak then it wont leak.
Dec 30, 2009 | American Standard Cambridge 5' Americast...
I removed the plug on my American standard lifetime drain and it won't close now. I can't get it to hold water now. I can't find any diagrams to show how the plug should be configured to help solve the...
You have to take apart the "drain rod" assembly under the sink. There will be a rod with nut on it that goes into the drain near the sink. Take the nut off, drop the stopper in with the eye hole towards the wall and then reinstall the rod through the eye on the stopper and tighten the nut.
Oct 22, 2009 | American Standard Lifetime Drain, White
How do you remove the plunger
how do you remove bathtub drain stopper. manually screws open--won't twist off--no screws apparent????
Aug 09, 2009 | American Standard Plumbing
The tub/water stopper...how do you take that off to unclog hair in the drain?
The overflow drain / stopper lever has 2 screws holding it in place, place a rag over the drain and remove the 2 screws. then remove the drain assembly, it should slide right out. You can now clean the assembly, you may still need a piece of wire to fish the hair out.
Jul 24, 2009 | American Standard 2771.018WC.222 Cadet 5'...
How do I remove an American Standard (or Delta?) pop-up drain?
Remove the lift rod and lift up the stopper.
The lift rod is under the sink and one end goes to the lift rod and the other end goes into he base of the plug.
Jul 05, 2009 | American Standard Princeton 2393.202.011...
Sink stopper will not disengage
Hi Im here to help. There is a lift rod that is connected to a pivoit rod that lifts the pop-up drain up and down. If this has become disconnected, or broken. heres a link (scrool down) to a picture of how it works.
http://www.hometips.com/content/popups_intro.html
Please remember to leave me some good feedback! Thankyou.
Dec 11, 2008 | American Standard Model 2373.801: Enfield...
Plumbing Logo
827 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
