Question about Toshiba 62HM95 62" HDTV
Toshiba 62hm15, black screen red, green flashing lights together
I have a Toshiba 62hm15, I plug it in i get the green light, i power on its red, but nothing but a black screen no audio, It goes from green to red for power, shuts its self off and repeats that untill both the red and green are flashing together, I still have black screen, I even reset it. Does anyone know what the problem is?
djnick989
  • 1067 Answers
SOURCE: my toshiba wont turn on but red light come on an green light flashing no picture or sounds
yes ill got remote link for u here give me one sec
Posted on Jan 29, 2008
SOURCE: Flashing green light
sounds like the bulb is blown. Its the main lamp in the side of the set. you will see a small door there once you take it off there is 2 screws to remove and bulb in its casing will slip out. by looking at the buld you should be able to see if its blown. You should get approx 3000 to 4000 hours from a bulb but if you are a heavy user of this tv with higher contrast the bulbs dont last. i have this model tv myself and ive been told that they are not designed to be run for long periods of time and dont use gaming machines on them. Shame they dont tell us this when we are buying them.. hope this helps you Craig (crazy@woosh.co.nz) let me know how you get on
Posted on Feb 25, 2008
SOURCE: toshiba 62hmx84
replace bulb
Posted on Aug 27, 2008
SOURCE: won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Posted on Dec 09, 2008
daniel719
  • 240 Answers
SOURCE: Toshiba 61G9UXA red light but no sound or picture
good this tells you that the convergence IC's need to be replaced
if the IC's wer good it would tryto come on this is a youke isolation test.
also check r417 if bad replace.
replace 2 ea sth 392 110
thanks
daniel.
Posted on Jan 13, 2009
How do I fix 62HM15 picture. Have sound-No Picture. Have red light steady and Green light blinks 8 times and cuts off and back on.
Usually 8 flashes means the lamp is not lighting.
When most lamps go bad , they physically crack because of excess heat.
The problem is probably the lamp or the ballast, which makes the voltage to light the lamp.
Replace lamp and remember to close the lamp access door after replacing, because the lamp will not light if the door is open an
Jan 23, 2015 | Toshiba 62HM15 62" Television
Connecting my new samsung blu-ray player (bd-fm57c) to my toshiba theaterview tv.
I don't think that cord will work. HDMI carries video and audio signals, you might get video but probably no sound. You might as well try anyway though so here goes... The red green and blue plugs are your video and the other red plug and the white plug is for stereo sound. The yellow plug is just a lower quality video plug. So plug in the red blue and green plugs into the component video inputs on the TV then the red and white plugs into the audio inputs. DON'T plug in the yellow plug. If this doesn't work go to your local home theater store and ask for a receiver or switcher that will downscale high def HDMI to component video and stereo audio. You can probably pick up a cheap one for around $100. Good luck!
Mar 29, 2014 | Toshiba 50 Inch Big Screen Flat Tv Theater...
The red light is blinking and the tv want come on
First on this model remove the lamp and examine it to see if shattered inside---customer replaceable and door (unplug set first) is on left side as seen from the front.
With door off remove two brass screws and grasp handle on lamp cartridge and slide it out---with the screws removed the lamp cartridge just slides out--pull it out and look.
Mar 24, 2012 | Toshiba Televison & Video
Wiring diagram for 220 volt light with switch
ok here goes first what do you want to do? replace switch or what, all 220 volt lights have a switch, plug has 2 hots( one red-one black), then you have a white and a green, red and black are power, white is neutral and green is ground.whit goes all the way through to light, so does the green, switch controls power so red on one side of switch and black to other side, hopes this helps
Oct 15, 2011 | Home
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Toshiba 62hm15a- bright flashes
my toshiba 62HM15A has bright and dark flashes.
Sep 30, 2008 | Toshiba 62HM15 62" Television
Toshiba 62HM95 62" HDTV Logo
356 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
