Question about Kenwood KFC-6982ie Car Mid-Range Speaker
Powering 4 6x9 speakers, need amp
I have 2 sets of kenwood kfc-6982ie's (90w RMS, 500w max, 4 ohm), I have a sony headunit thats suposed to put out 52w to each speakers but I also have 2 12" kicker cvr's powered with a 750w RMS kicker amp so the low bass is deafening compared to the mids and highs, I want to get an amp specifically for the 6x9's. I know I need at least a 2 channel amp but would it still be surround sound if I don't get a 4 channel amp? also what would be the perfect amp, or amps for the job? Thanks.
PS I might return the front 6x9s for 6 1/2s if I can't fit them in the front of my car, havent installed those yet.
  • miketallica6 May 10, 2009
    yeah I think I would go for the 100rms to each speaker so I can match the mid and low bass evenly, and thanks for the info about head units, but when the box says the kenwoods can handle 90 RMS and 500 max, does that mean 90 on each speaker? or 90 for both?
    Novelist:
  • 150 Answers
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
Posted on May 10, 2009
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
Two questions. 1) can my amplifier over-power this sub; kicker L7 15 inch dual voice coil 1,000 watts RMS wired for 2 ohms? 2) is my amp too small for this sub-woofer? thank you for your time.
No, your not over powering your L7, your underpowering your subwoofer.
Your Kenwood is
500W x 1 at 4ohms [20-200kHz 0.5% THD]
900W x 1 at 2ohms [100Hz 1.1% THD]
Your L7 is:
Max Rec Amplifier Power (WATTS PEAK/RMS)* 2000/1000But its ok for your subwoofer, alteast your not giving it to much stress. But personaly, get another mono amplifier that would match your subwoofers rating.
Apr 08, 2011 | Kenwood KAC-9103D Car Audio Amplifier
I have brought these speakers, when i turn the headunit up above about 3 quaters of the way they distort, they are running off a 4 channel 4ohm amp with 400watt rms but they do it with the gain on the amp...
If you run the power amp at a very low setting it makes the amp subject to noise and distortion. You want around a 60% setting.
Speakers also need to have proper loading, that is in a cabinet or enclosure that is kind of matched to them. If the amp is rated at a true 400 Watts RMS then the speakers should be at least 800 Watts as they "cheat" on those SPEAKER ratings and MANY A SPEAKER IS BLOWN AS A RESULT.
Mar 21, 2011 | Cdt Audio HD-53ST Car Component System
Can i run a 4 channel 400watt amp to 4 6x9 speakers?
yes i dont see why not
they should work perfectly
is the question how to wire it?
if so then reply to this message
LOL
kenwood KFC
May 12, 2010 | Kenwood KFC-6982ie Car Mid-Range Speaker
What kind of amp do i need for 2 kicker ds6930 140 watts peak and 2 ks6930 6x9 watts peak 150 and 3 Kicker KS350 3-1/2 40 watts each peak
600 Watt to 1000 Watt 4 CHANNEL AMP for the four 6X9's and a less powerfull 4 Channel amp thats at least 200Watts to 400Watts peak for the 3 3-1/2 kicker speakers. Because if you try to connect the 3 3-1/2 speakers to only 1 4 channel amp that the 6X9 speakers are on you risk of overheating the amp and blowing the speakers too!!!
Apr 05, 2010 | Kenwood KFC-6982ie Car Mid-Range Speaker
NOT SURE WHAT OHMS SUB I NEED!
if you get the 4ohm you can wire it to run a 2ohm an the kenwood amp will push 900 watts at 2ohms.they say it can push up to 1800 watts,that would be at 1ohm.that kenwood runs 500 at 4ohms an 900 at 2ohm.if you need help wiring the sub or anything else let me know bertman285@hotmail,com Max Power Output 1800W Power Output 4 Ohm [14.4V] 500W x 1 [20-200Hz, 0.5%THD] 2 Ohm [14.4V] 900W x 1 [100Hz, 1.1%THD] Bridged[4 Ohm] -
Oct 09, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
I have a Kenwood KFC-W3514DVC and its hooked up to a Valor Multimedia VPA402 500 watt 2 channel amplifier. If i want to optomize my system the cheapest way should i buy another subwoofer or should i buy a...
find the rms rating of the sub and compare it to the amp.if the rms of the amp is higher than the sub you have enough power to push the sub.if its lower look at the rms of the amp if it can be bridged.you would like to see the rms matched to the sub or subs if you have enough power.
Sep 06, 2009 | Kenwood KFC-W3514DVC Car Subwoofer
Will 2 KENWOOD KFC-6982iE fit in 1999 mazda protege
If they fit then put them in. The only thing is, if your not using a amp they may not sound good.
Jul 01, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
Support Question about RMS
you are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
if you have any questions email me at thadoggma420@hotmail.com
Jan 22, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Kenwood audio equipment
If it was mine i'd want $200-$300 if in mint condition. Try a classified in the local paper or online ads.
Sep 11, 2007 | Kenwood 2 10 " SUBS SUBWOOFERS 500W POWER...
Kenwood KFC-6982ie Car Mid-Range Speaker Logo
1,511 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
