Question about Acer NSK8458AN Keyboard
I have installed a new lid on my acer aspire 3050. during the install of the wirless antenas I had to remove the keyboard. Unfortunately after re installing the keyboard etc I have now discovered a number of key no longer work ie: x c space bar 1 caps lock and some of the arrow keys. Any suggestions?? Cheers
  • Deeds69 May 10, 2009
    Hi I have tried this a couple of times but still no use??
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
Reseat the keyboard connection. This happens when its only making slight connections. Some laptops can be pretty tricky, especially if the ribbon cable is a bit short on the keyboard. If this helps please rate my solution.
Posted on May 10, 2009
Aspire laptop wirless switch is off cant turn it on
I think you need to install the drivers from acer.
Feb 04, 2014 | Acer Aspire 6530-5143 Notebook PC
Cracked screen on a aspire1094z notebook and my external display works only in safe mode
Off hand I suggest you disconnect the Video Cable.
May be mistaken, but I think there is enough damage to the LCD screen, that it is causing only Safe Mode to be used.
Of course it does depend on how the LCD screen was cracked.
Dropped the laptop while it was on? Going to be Harddrive damage, and possibly further damage through the laptop.
Let's start by disconnecting the Video Cable connection, at the motherboard side. Then see if the external monitor works, and in normal mode.
I don't find an Acer Aspire 1094z, but I do find an Acer Aspire 3050-1094.
Acer - Manufacturer
Aspire - Model Series Name
3050 - Model Series Number
1094 - Model Number
If this is incorrect state back in a Comment.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the 'paragraph' that starts with Aspire 1200. (1200 in Blue)
Drop down to the third line (2930), scroll across; click on the blue - 3050.
[Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (3050) it may take up to 30 seconds, before the first page comes up.
When I refer to a page number, it will be for the Adobe Reader page number box at the Top, to the right of the Down Arrow.
The Zoom In icon ( + ) at the Top increases the view size, when you click on it.
The Zoom Out icon ( - ) decreases the view size.
IF this applies;
Click on the icon at the Top/Left corner. Toggle Slider.
There will be two square icons.
Show Thumbnails on the Left, Show Document Outline on the Right.
Click on Show Document Outline to see the Bookmarks menu ]
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Laptop closed, normal position except the Back is facing you.
There are two screws to remove, in order to remove the
Keyboard Cover.
Bottom of Page 67, top of Page 68.
Philips head screw, one on EACH side.
They are in the black plastic of the laptop, and next to the silver 'lid'.
(Display Cover = 'Lid')
Turn the laptop around, front facing you; open the laptop.
The Keyboard Cover is the strip of plastic above the Keyboard.
The Hinge Covers are an integral part of this cover.
The Microphone Cable is attached to the Launch Board, and the Launch Board is attached to the bottom of the Keyboard Cover.
For this reason suggest go slow, so you do not damage the cable (Wires); when removing Keyboard Cover.
Once the cover is lifted off, disconnect the Microphone Cable from the Launch Board.
This is an example of the Keyboard Cover removed,
http://www.cdsparts.com/p-379-new-acer-aspire-3050-3680-5050-5570-5570z-5580-middle-keyboard-cover.aspx
Suggest come to the Right side of the cover, and ease it up a little, by inserting a thick guitar pick; into the parting line.
(Where the Keyboard Cover meets the Bottom Cover)
Insert how far? About 1/4th Inch, or half the length of your little finger's thumbnail.
Ease that end up a little, so that you can get a fingertip underneath, then using fingers of both hands; ease up on the top, and bottom side of the cover; as you head towards the Left side.
(Sorry about the run-on sentence)
The cover may just pop off as you start, or you may have to carefully go along, and ease up on it all the way.
To the Left by the left Hinge, you will see motherboard side of the Video Cable.
White piece of Mylar plastic tab to gently pull up on, and this unplugs the Video Cable from the motherboard.
A look at the motherboard side connection of the Video Cable, in a pictorial guide,
http://forum.notebookreview.com/acer/352528-aspire-3050-upgrade-sempron-turion-x2-tl-50-a.html#post4515287
Scroll down to about half page, look at the photo under the heading -
h. remove the long cover, and remove the two screws on the keyboard.
See what looks to be a white piece of tape, over by the left Hinge?
That's the motherboard connection side of the Video Cable, and the white pull tab.
Also details how to replace the LCD screen.
If you wish to do this, I would appreciate a Comment back, so I can give you some tips, and possible guidance if you wish it.
Unplug it. Attach the Microphone Cable again, but leave the Keyboard Cover loose.
(You can't reinstall the cover, because the unplugged Video Cable is in the way )
Reinstall the Battery.
Plug the AC adapter into the laptop, THEN plug the AC adapter into power.
Turn the laptop on.
Any change?
Post back in a Comment.
Regards,
joecoolvette
Feb 26, 2013 | Acer Aspire Computers & Internet
Hi I have reformat my Acer aspire 3050 and he delete my drivers what should I do to get them back?
HI friend
click here to download your drivers
Realtek - Audio audio.png Acer Aspire 3050 Realtek Audio Driver for Windows Vista Enterprise 32bit
Filename: Audio_Realtek_6.01.5334_Vistax86.zip
File size: 33.3 MB
Version: 6.01.5334
broadcom.jpg Broadcom - Bluetooth bluetooth.png Acer Aspire 3050 Broadcom Bluetooth Driver for Windows Vista Enterprise 32bit
Filename: Bluetooth_Broadcom_6.0.1.3500_Vistax86.zip
File size: 19.5 MB
Version: 6.0.1.3500
bison.jpg Bison - Camera camera.png Acer Aspire 3050 Bison Camera Driver for Windows Vista Enterprise 32bit
Filename: Camrea_Bison_1.0.0.14_Vistax86.zip
File size: 9.3 MB
Version: 1.0.0.14
suyin.jpg Suyin - Camera camera.png Acer Aspire 3050 Suyin Camera Driver for Windows Vista Enterprise 32bit
Filename: Camera_Suyin_1.0.0.8_Vistax86.zip
File size: 22.4 MB
Version: 1.0.0.8
ene.jpg ENE - CardReader no_image.png Acer Aspire 3050 ENE Card Reader Driver for Windows Vista Enterprise 32bit
Filename: CardReader_ENE_5.1.2600.3000_Vistax86.zip
File size: 627.3 KB
Version: 5.1.2600.3000
conexant.jpg Conexant - Modem modem.png Acer Aspire 3050 Conexant Modem Driver for Windows Vista Enterprise 32bit
Filename: Modem_Conexant_7.62.00_Vistax86.zip
File size: 2.1 MB
Version: 7.62.00
synaptics.jpg Synaptics - TouchPad touchpad.png Acer Aspire 3050 Synaptics Touchpad Driver for Windows Vista Enterprise 32bit
Filename: Touchpad_Synaptics_9.1.0_Vistax86.zip
File size: 22.9 MB
Version: 9.1.0
ati.jpg ATI - VGA vga.png Acer Aspire 3050 ATI VGA Driver for Windows Vista Enterprise 32bit
Filename: VGA_ATI_8.332.0.0_Vistax86.zip
File size: 110.4 MB
Version: 8.332.0.0
atheros.jpg Atheros - Wireless LAN wireless_lan.png Acer Aspire 3050 Atheros Wireless LAN Driver for Windows Vista Enterprise 32bit
Filename: Wireless%20LAN_Atheros_7.2.0.152_Vistax86_A.zip
File size: 2.8 MB
Version: 7.2.0.152
broadcom.jpg Broadcom - Wireless LAN wireless_lan.png Acer Aspire 3050 Broadcom Wireless LAN Driver for Windows Vista Enterprise 32bit
Filename: WLAN_Broadcom_4.102.15.61_Vistax86.zip
File size: 2.9 MB
Version: 4.102.15.61------------------------------------------------------------------------------
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Mar 30, 2010 | Acer Aspire 3050 Notebook
My Key board dosnt work on my acer aspire 3050 but
Log into safe mode and then try a system restore
Click on start and then all programs
Click on accessories and then system tools
Choose system restore on the list and restore to an earlier time
Then choose a date at least a day before this first happened
Please let me know the results
Dec 29, 2009 | Acer Aspire 3600, 5030, 5500 Keyboard...
"lost backspace button on Acer Aspire One"
Unfortunately, there is no way to purchase just one key of the keyboard. Acer does offer full replacement keyboards and they are easy enough to install. Unless you can find just the backspace key on eBay or something, you might have to replace the entire keyboard.
Thanks for using the fixya Forums.
Mar 28, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 3050 keyboard issues
go to my computer, right click, properties, device manager, look down list for keyboard, click '+' sign, you will see your keyboard listed, right click select uninstal, then restart notebook it will reinstall itself and should be working as normal.
Sep 03, 2008 | Acer Aspire 3050-1733 Notebook
Acer laptop not conneted to 2Wire147 Moderm
make sure you turn on the wirless on your laptop. Could you see this wireless under view wireless available wireless network??. When you say will not connect, you already see it or no ???
Apr 28, 2008 | Computers & Internet
Acer aspire 3050 black
refer to ur user manual to see which key for brightness e.g.fn+f 9
(reduce brightness)if havnt got one can easily download one of net.try to swich screen to monitor.connect external moniter and press fn+f 5.(refer to manual maybe different key)
press down and release screen lid button see if any response.if all fail need to disassemble.
remove screw in about middle of pc underneath.this ia retainer screw for key board.remove screws dirrectly behind screen to remove plate with buttons.then can get access to keyboard and lift away (do not disconnect it just rest it on screen or front of pc )check cables from mother board to screen.check inverter.
all these are worth checking but initially sounds like inverter faulty.
Mar 05, 2008 | Computers & Internet
Frozen keyboard acer 5100
for aspire 3050, try to remove the battery, battery can cause many strange thing.
if you still got problem after removing battery, it's look like motherboard need repair.
Mar 02, 2008 | Acer Aspire 3000 Notebook
Acer 3050
During the windows installation, did you delete the partition, recreate the partition, format, then reinstall?
Sometimes viruses can last through reformats, but deleting the whole partition, then recreating it can fix the problem.
Nov 12, 2007 | Acer Aspire 3050-1733 Notebook
Acer NSK8458AN Keyboard Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
