Question about Microsoft Office Standard for PC
Numerical methods can you help us on how to make a program on microsoft excel regarding 2nd order polynomial regression where we can input data points such as values of x and y in the coordinate system that will lead us to the necessary equation in the form of y=a+bX+cX^2? tnnnnnxxxxxxxxxxxx
  • 28 Answers
Re: numerical methods
Is this the formula you are looking for:
If this helps, please rate me. Thanks, Patty
Posted on Dec 30, 2007
0 characters
3 Points
What is excel
Microsoft Excel is a commercial spreadsheet application . It features calculation, graphing tools, pivot tables, and a macro programming language called Visual Basic for Applications.
Microsoft Excel has the basic features of all spreadsheets, using a grid of cells arranged in numbered rows and letter-named columns to organize data manipulations like arithmetic operations. It has a battery of supplied functions to answer statistical, engineering and financial needs. In addition, it can display data as line graphs, histograms and charts, and with a very limited three-dimensional graphical display.
Jun 04, 2011 | Microsoft Excel for PC
What is excel
Microsoft Excel is a spreadsheet program which allows one to enter numerical values or data into the rows or columns of a spreadsheet, and to use these numerical entries for such things as calculations, graphs, and statistical analysis.
Dec 15, 2010 | Microsoft Office Excel 2003 for PC
Excel vba
For complete guide please refer to this link
Thanks and regards
Fixya is educating to educate
May 12, 2009 | Microsoft Office Professional Edition 2003...
Dear Sir, In case there are atleast 80 files or more having same format containing datas in columns in each file with different figures, I want to merge all file in a single sheet in one shot. Kindly...
If the column names and orders are same across files, then you can directly use the MS Excel's import data function, this will do your job.
Alternatively, if you want to do it manually, import each file in separate excel worksheet using data import wizard or simple copy paste of data (in latter case you have to use Text-to-Col feature of excel), and then manually append all figures (copy-paste in one go) to any external excel sheet.
Then finally, export/save as that external sheet to any filename of your choice.
Hope this helps.
Mar 24, 2009 | Microsoft Excel for PC
Minimize Data Entry
I will suggest you to create small application in .net for ths which will add some value and process your data;If you want to use Excel only make a master sheet with details and use it in other excel sheets
Jan 02, 2009 | Microsoft Excel for PC
Excel formula
I'm assuming you'd like to assign a numerical value to cardinal references (1st, 2nd, 3rd, 4th, etc.).
Best way to do this is to create a quick lookup table on a separate sheet of the same .xls document. Down at the bottom of the page, click on Sheet2 and create a quick table where column A has 1st, 2nd, 3rd, etc. and column B has your values.
Now click back to Sheet1 where your data is and in A2 put this formula:
=VLookup(A1, Sheet2!$A$1:$B$x, 2, FALSE)
Note: replace the lower case x in the formula above with the number of the last row of data in your lookup table on Sheet2.
You can copy and paste this formula down the column to calculate your other values.
Hope that helps!
Aug 30, 2008 | Microsoft Excel for PC
How do I run a regression analysis in Excel
You probably want to use the LINEST function for straight lines or LOGEST for exponential curves.
In Excel 2007, there are a few tricks. One is to select a range of cells and enter your formula there. If you do not select a range of cells all the variables (coefficentis, R2, errors, etc) will not be dislayed.
The other tricks is one must hit Ctrl+Shift+Enter to display the results. is a link from Microsoft with a detailed explaination. Happy OLS regressing!
May 13, 2008 | Microsoft Excel for PC
Selecting only Numeric part of a database feild
Well, one solution is to fetch the whole data, including the non-numeric part, and then convert that into a number. Most programming languages strips off the non-numeric part of a string when converting into a number. For example, converting '24Michell' to a number will result into '24'. Consult your programming manual on how to convert a string into a number.
Oct 01, 2007 | Microsoft SQL Server Standard Edition for...
I have data in excel
Excel cannot search by colour, however you can rank by adding a column, in which you place a ranking value (if you colour code as well you can appear to rank by colour), sorting by the ranking column will give you the same ranked rows together in numerical order.
Sep 11, 2007 | Microsoft Office Standard for PC
Microsoft Office Standard for PC Logo
44 people viewed this question
Top Microsoft Business & Productivity Software Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Microsoft Business and Productivity Software Expert? Answer questions, earn points and help others
