Question about Brother DCP 130C All-In-One InkJet Printer
My printer is running though it is printing but then no print out when it comes out
    Sniper:
  • 79 Answers
Appears to not pick up the paper, correct? This can happen after printers just wear out, not been used regularyfor long periods of time. Basically the pick-up and roller assembly's are not funtioning properly. Unfortunately unless its an extremely expensive printer, it would cost too much to have it looked at and repaired.
Posted on May 10, 2009
Tip
HELP!!! A few days ago I was using my printer and it was doing okay, then all of...
Greetings,
This information is intended for those of you that are getting support from the Fixya.com expert community, for your printer. There are a few things you may wish to consider, prior to posting a request for assistance.
A. It's absolutely vital that you use the correct model number and maker's name for your request. Without that, no expert will be able to access their extensive information pool of techniques.
B. Speak just to the current issue. A reference to how long it's been working, is fine, yet presents little valuable information to an expert seeking to refine their response.
C. There are four major areas that represent nearly 99% of all printer issues. They are:
1. Ink issues. This usually happens when the cartridges are changed. It's vital to do a clean and calibrate, just after installing new cartridges. Try that first, and then a test page.
2. Paper jam issues. Visually inspect the inside of your printer, and focus on little slices of paper(comes from those papers with perforations).
3. Communications errors. Check all the cables for secure connection(they do come out sometimes, for no reason). Also, make sure that you have the most current drivers from the makers website.
4. Actual Print output issues. These are across the board, and without all the first 3 issues resolved, would simply add to your potential problem.
Most of the experts are good at what they do, and are willing to help you out. Help them, Helpya.
And, also, it's part of the experts program here to get constructive feedback from all helpees. Please consider adding your comments to the problems, so that we can all learn more about how to be better experts.
Thank you for your courtesy.
Patrick the Printer Man
IB4G2008 Fixya Wizard
on Apr 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Color cartridge runs out even though I'm only printing b&w typed scripts. Any way to shut it off? Only have use for color printing once in a blue moon Hewlett Packard HP DeskJet Printer #932C
Even though you print a b/w document... unless you say 'black cartridge only' in your printing preferences, all the colors get used.
Find 'black cartridge only' in your printing preferences, or 'print in greyscale' and then print your document. You must specify this for your printer to know that it must use the black only.
Jul 23, 2010 | HP DeskJet 932c InkJet Printer
Printer prints perfectly durin test print but
if the printer has a drum or a printhead... then that part is bad...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 21, 2009 | OKI Pacemark 4410 Matrix Printer
Photosmart 7960 prints blank documents; prints from internet ok
If it can print from the internet, it is working properly. I would disconnect the printer from the computer, uninstall the drivers and reboot twice. Reinstall the drivers and hook up the printer when instructed. Make sure that you select this as the default printer. (unless, of course, you have another as default)
Jul 24, 2009 | HP PhotoSmart 7960 InkJet Printer
Printer will not print black ink
Seems to be a common fault with Kodak EasyShare 5100/5300
Contact Kodak Support and go though the following tests:
Remove and re-seat Printer Cartridge(s) - Done
Clean Printhead - Done
Calibrate Printer - Test Sheet Not Complete!
Run Computer Colour Test - Done
They will then send you a new Print Head.
Mar 25, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My printer will feed paper, but no ink is printed..
i im  josh in cebu phils.may i help you? Friend the printer that prints and without ink appears even though not run out of supply. the problem is not the ink  but the tank lever that carries the cartridge.there maybe stuck dried ink on it came from previous ink installed that drain on the lever. Solutions: 1. try to remove all the ink and clean the lever with a soft cloth. 2. go to settings and perform the head cleaning and nozzle check. 3. do the printing repeatedly until the ink comes out. thats all friend good luck hope i helped you.
Mar 14, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer says cartridges full, computer says cartridges empty even though i have bought and installed new cartridges
Printer connection had come out of the computer port and I hadn't noticed, printer itself is stand alone so was printing photos OK but I couldn't print documents. Everything up and running once again and both printer and computer say cartridges are full.
Aug 17, 2008 | Kodak Office Equipment & Supplies
Won't print
plz reinstall the drivers for the printer
Jul 02, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper goes through the printer as though printing but paper comes out blank
Just make sure the cartridges are not running out of ink. Try with different carts, It should work fine.
Apr 20, 2008 | Office Equipment & Supplies
Brother DCP 130C All-In-One InkJet Printer Logo
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
