Kef PSW2010 Subwoofer common problem DIY repair
My Kef PSW 2010 Sub Woofer is suffering from the common relay trill noise problem that happens when it is left running on standby mode. I am an electronics engineer, so I'm just looking for basic advice on what is likley to have gone. Some user groups state cirtain capacitors and other say the relay that it is the activation relay. Do you have a maintanence manual or circuit diagram for this ? Thank you Mino
    Problem Solver:
  • 17 Answers
The relay buzzing fault is caused by a faulty electrolytic capacitor.
You need 47uF 100v 105C radial.
C52 on the corner of the board near some power resistors.
Posted on Aug 11, 2010
  • 1 more comment
  • Frank Johnson Sep 12, 2010
    More information on my Kef subwoofer repair site.
  • lofpat Oct 06, 2010
    Perfect advice , changed the C52 capacitor yesterday and the issue has been solved, I guess it's better to switch off the subwoofer next time instead of in AUTO mode , altough the LED switches then to RED still all the components in the PSU are running on full power which in the end will burn the device....
    I saw that the back of the PCB is quite dark already which indicates that a lot of heat has been on the PCB , any other suggestions to change other components on the PCB to avoid overheating ??
    Thanks, Patrick
  • Frank Johnson Dec 13, 2010
    There are some modifications on the link above.
    Easiest thing to do is to space C52 off the board and bend away from the hot resistors.
    Also use a good quality 105C rated capacitor.
    Sergeant:
  • 349 Answers
If you are really keen you could fit a small computer type fan to add additionally cooling!
Posted on Oct 30, 2011
I have a Denin AVR-3802 Amplitier and Kef PSW 200 Sub-Woofer. How do I connect up the sub woofer? It' s been disconnected and my son who set it up originally has gone to Australia. Help
At the back panel, almost at the center, you can locate an RCA connector for the Subwoofer output. Take a look at this:
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 15, 2011 | Audio Players & Recorders
The amp on my kef sub woofer amp is making a consent buzzing noise it sounds like a kettle boiling. Help
Ok so no guarantees this will work, but it did for me and I knows it's very late but hopefully it will help someone else with a similar problem.
I had the same problem and as clmrt5000 said a very long time ago there could be an issue with a ground loop, although this is likely to give a high pitched buzzing sound.
This can easily be fixed by adding a switch to disconnect the mains earth from the back plate, or you can just unscrew the earth and tape it up, this fixed my ground loop, (some models already have a ground lift switch)
As for the "boiling" sound I also got a saw tooth wave sound (like a strange squeak or beep that changed frequency) this is caused by faulty components, and thanks to Frank Johnson (http://lug.demon.co.uk/kefrepair/?p=60) who suggested that you can simply and easily replace 3 capacitors on the main amplifier board (c58 - 47uF 63v or 100v) + (c52 & c53 - 220uF 25v) but stand them away from the board on the length of the capacitor leads to prevent them from absorbing heat from surrounding hot components (with heat shrink tubing to prevent shorting)
Now my sub works as good as new, apparently these 3 capacitors can cause all kinds of problems it's a common fault, so if you are handy with a soldering iron, or know someone who is you could save yourself a lot of money by repairing you faulty KEF sub.
p.s. if you have ANY of the KEF PSW subwoofers they all have similar issues, you can find a guide to fixing them at the link above, Frank is a brilliant and very helpful man.
Jan 07, 2011 | KEF Audio PSW 1000 Subwoofer
Im having trouble with connections from kef psw 1000 sub to onkyo tx sr506 amp. sub is making a bit of a humming noise but not getting any proper sound through. dont know what im doing wrong. can anyone...
Have you got the sub defined to the Onkyo correctly? Try conencting the sub's input to one of the Tape Out connectors and play some FM through it. That will prove if the sub is alive. The nwe can troubleshoot the correct failing device.
May 03, 2010 | KEF Audio PSW 1000 Subwoofer
On my yamaha rxv640rds a boom noise on sub
It sounds like there is a DC bias with the switching and they did not design a good fade in and out when switching... If this is original, chalk it up to BAD design.
Jan 07, 2010 | Audio Players & Recorders
I have a Kef PSW 2500 that emits a loud buzz when on. I pulled the amp, but I'm not sure if its the speaker or amp. What should I be looking for the speaker outputs from the AMP? How can I tell if its a...
Have just repaired a similar problem with a KEF 2500 - relay was chattering at 50 Hz rate, buzz in speaker output.
Problem was caused by overheated / dried out Electrolytic filter cap (C52 - 47uF 63V) on the relay coil supply feed.
The overheating is caused by adjacent power supply dropping resistors which run very hot due poor design of power supply.
A service manual for a similar model is available at following link, refer to power supply section:-
http://www.eserviceinfo.com/downloadsm/35375/kef_psw2000.html
To replace,
1) remove chassis from speaker cabinet (8 screws), disconnect red/black speaker wires from main PCB spade connectors.
2) Remove 4 screws attaching main pcb heatsink assembly from face panel - lift assembly from faceplate (a bit messy , much heartsink compound between mounting faces)
3) unplug the AC 3 pin connections adjacent to the large capacitors and the 3pin connector on end of pcb (near C52), then roll assembly over the top of the audio sub-board to access underside of pcb.
4) solder connections to C52 is accessible at edge of board without further dis-assembly.
Take extreme care replacing C52, as the circuit board is of poor quality, (usual domestic electronics quality) being single sided copper without plated through holes.
The board is already heat damaged by heat buildup from power supply resistors, so the track will most likely lift and crack when disturbed- to counter this problem link the +ve capacitor pigtail to an adjacent solder pad on the same track.
Assembly is reverse of above, take care to preserve/ensure minimum disturbance of heatsink compound.
Nov 29, 2009 | KEF Audio PSW 2500 Subwoofer
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Nov 06, 2009 | KEF Audio PSW 3000 Subwoofer
KEF Subwoofer PSW2010 (KHT2005.2) - No power
chik power sours first
thaen chik transformer inside
u will see it burned if so chang it
Aug 18, 2009 | KEF Audio KHT 2005.2 System
Subwoofer clicking noise
Hi I am afraid it sounds like exactly the same problem I had, Namely the PSU(power suplly unit) is failing, This is a common fault (by reading loads of forums) I contacted KEF today about mine and they say the probably wont be able to source any more spares(due to so many having thuis problem no doubt) So I would suggest contacting the people you bought it from,Under the consumer protection act you should expect an electrical item to "Last a reasonable amount of time" .Mine is 3 years old and I do not consider this to be a long period so kick up and you should be entitled to a repair or at worst a partial refund.Look here basically the same Sub.
http://www.avforums.com/forums/showthread.php?t=436234&highlight=kef
Mar 04, 2008 | KEF Audio PSW 3000 Subwoofer
7,493 people viewed this question
 Grubhead
Grubhead
