Question about RCA HD56W66 56" HDTV
Parental Lock I purchased a used RCA 56" HDTV and the parental code is locked on it, it even has the front control panel locked out, how do I default this...
  • 1 more comment
  • Bgone1 Oct 12, 2007
    Likha, I tried that, the remote takes it to the parental lock, but wants me to enter a code, I dont know the code, or any of the default codes... anything you suggest would be helpful
  • Bgone1 Oct 15, 2007
    Bgone1 again, I have found no answer other than access by the factory input, but does the RCA 56" HDTV (HD56W66) have a reset or default in the chassi like most TV's you can unplug it for a period and it defaults back to original factory spec's is there a way to do this with this TV
  • cc2517 Dec 31, 2007
    I have exaclty the same problem. Has anyone figured out how to fix this?
  • 790 Answers
Use the remote control then go to menu! find the unlock mode!
Posted on Oct 12, 2007
SOURCE:
I have a a Silo 42'' HDTV and the menu keeps on popping up
Mine had the same problem. If you go into the menu --> Parental control, type in default code ( 0000 or 8888) --> Then check the front panel lock to make sure it is on
This should fix it, it worked for mine.
Jul 22, 2011 | RCA Silo Digital LTSL3220 32 in. LCD TV
I need the code for rca xl100
Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you forget your password, press the following buttons on the remote,
one by one: MUTE, DISPLAY, CLEAR, and RESET (you must be in the
password entry screen). Parental controls will then unlock and you can
re-enter a password via Lock Parental Controls.
If you need the manual please let me know.
Feb 06, 2011 | Televison & Video
Is there a master code to reset the Parental Restrictions. I locked it a while back and forgot the code
Yes - the factory default password is 9999. This can still be used even after setting your own password. If you need any assistance with changing setting the parental lock settings, please let me know.
Regards,
BElectric
Jan 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
The frontpanle on my rca t.v is locked and i cant get it off
Front Panel Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV's front panel. The remote still tunes to any channel. When using this as a Parental Control method, remove access to any remote
that is capable of operating the television.
1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel.
2. Press the right or left arrow to turn on (box has check mark) or off (box doesn't have check mark) front panel lock.
Sep 22, 2010 | RCA 20F530T 20" TV
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
FPA LOCK ON
FPA means the front panel is locked by the Parental Access Control Menu.
Unfortunately, the FPA can only be removed using the remote. There are no magic front panel button combinations.
The cheapest way out is to buy a Universal Remote Control at Walmart (about $10) and program it to your RCA TV. Then you can go into the Parental Control Menu and remove the lock.
Dec 23, 2008 | RCA G36788LV 36" TV
Parental control/lock on Mitsubishi WS-55613
I can help you unlock your Mitsubishi HDTV V-Chip parental lock.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Aug 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi parental control reset for tv model vs-5061
I can help you unlock your Mitsubishi HDTV V-Chip.
I hope that helps.
Jul 20, 2008 | Mitsubishi VS-50611 50" Rear Projection...
Parental lock
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
RCA HD56W66 56" HDTV Logo
97 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
