Acer TravelMate 650, 660, 800, 6000, 8000, Ferrari 3000 keyboard - KB.A1303.001
Problem for Acer TravelMate 650, 660, 800, 6000, 8000, Ferrari 3000...
No operating system - instal xp pro
By dannic3 on May 10, 2009
I could not boot into windows xp pro. Kept getting - system32driverspci.sys - I had tried to repair and also reinstall but it would not let me do either, so then I decided to try w98se. The laptop is an Acer Travelmate 6000 with about 1g Ram. Setup 98se deleted my xp pro and when I had to put a floppy (laptop does not have one) I shut the system down - When I rebooted from the hd I get the Acer Flash screen then the following:
'' Broadcom UNDI PXE-2.1 (build082) v6.2.2
Copyright .....
Copyright ...
All rights reserved
PXE-E61: Media test failed, check cable
PXE-M0F: Exiting Broadcom PXE ROM
Operating System not found''
I am able to boot from the cd. I have managed to start the xp pro set up but when it goes to format I get a message -''setup was unable to format the partition. The disk is damaged. You must select a different partition for xp'' That is the only partition on the drive. The laptop has only one partition. I am now back to the setup screen that has the three choices - setup, create a partition or delete the existing partition. If I delete this partition will I still be able to install xp pro.
I hope I have made sense. Thanking you
Best Solution
posted on May 10, 2009
Very Helpful)
dww0642
Rank: Guru
Rating: 90%, 66 votes
With what you have done, it seems pretty cut and dry. You hard drive appears to be damaged, which is why your having problems formating/accessing it.
I would recommend running a hard drive test. If you not sure how, I would ask a local repair shop to run a quick test on the hard drive to confirm its bad. Most shop will do this test for free, if you get a hard drive through them. If you wanna go online and get your own hard drive, testing should be less than 30 bucks.
If this helps please rate my solution.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Acer TravelMate 650, 660, 800,
Questions and Unsolved Problems for Acer TravelMate 650, 660, 800,
Do you recommend Acer TravelMate 650, 660, 800, 6000, 8000, Ferrari 3000 keyboard - KB.A1303.001?
Answer
Answer
Nothing happens when I hit the ''enter'' key on my keyboard - can you help? I use a laptop with an... (More)
Answer
MX3200 keyboard - how does one set keyboard clock / date?
Answer
can't get my wireless mouse to work with my laptop, and computer won't recognize my using finger on... (More)
Answer
My numlock is turned on in the Bios but when xp starts it turns off numlock. How can I keep numlocks... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer TravelMate 650, 660, 800,...:
Top Keyboard and Mice Experts
Rank: Guru Guru
Solutions: 14880
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Keyboard and Mice Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
