Question about Edimax PRI-682 Router (PRI682)
Wireless won't connect to the internet when in WPA TPIP mode
Cannot connect to the Internet at all
    Scholar:
  • 42 Answers
I have found that some routers do not like text and numbers mixed in the password. After having a ton of problems I set up the wireless password to all numbers and haven't had a problem since.
Prior to that the wireless would work for a day or so and then quit. It was frustrating.
Also, when the router calls for text or hexadecimal I have found that they really don't mean text unless it is between A to F, which isn't really text but a hexadecimal number.
So, take the simple approach. Put in all 5's for your password. You can change it later if everything works, but use all 5's just to see if you can get going.
Don't read this part if you already know this.... You have to connect a computer via a hardwire ethernet cable to the router to set the password encryption. I used 192.168.200.1 as the IP address to get to the modem. Put the IP address in your browser address bar and you should come up with a screen that is addressing the modem. Select wireless security or some similar sounding menu item and then make your selections.
After you do this, and before you disconnect the ethernet cable, try to get on to the internet using the hard wired ethernet cable. That will be bypassing the wireless routines. If you can't get on via the ethernet cable direct connection, it is unlikely that you will be able to make the wireless work because there is a problem downstream from your computer -- the modem or perhaps the connection at the street.
Once done you can remove the ethernet cable from your computer. Go to NETWORK CONNECTIONS and properties and set the identical parameters WPA, etc in the properties including the all 5's password.
If you have set the wireless to connect automatically it should connect to the internet.
good luck
Posted on May 14, 2009
D-Link DIR-615 mobile phone wifi internet connection problems? connect but no internet
What wireless modes are you using? Under Setup/Wireless/Manual.
Try single mode G or mixed G and N?
Channel Width set for Auto 20/40Mhz or try 20Mhz only.
Try setting a manual channel to a open or unused channel.
What security mode are you using? Preferred security is WPA-Personal. WPA2/AES Only. Some WiFi adapters don't support AES, so you might want to try TPIK only or Auto.
What wireless devices do you have connected?
Any cordless house phones?
Any other WiFi routers in the area? Use InSSIDer to find out.
Turn off Short GI, WLAN Partition and Extra Wireless Protection if you have it. Under Advanced/Advanced Wireless.
Sep 17, 2014 | Computers & Internet
My Compaq Presario CQ60 won't connect to wireless internet.
how'd you do 2012 post then 2017,
shocking.
some one needs new clock battery , LOL
Aug 30, 2017 | Compaq Presario Computers & Internet
Wirelss router won't allow other devices to connect to it - eg kindle, iphone, but internet works fine on computer (which it's plugged into)...
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 24, 2011 | Belkin (F5D5231-4) Router
Hi.. I have just been connected to cable broadband with a Motorola Surfboard SBG9001 modem. I don't have any security, how can I change that so that the neighbours get free internet. Thanks
Open Internet Explorer and type 192.168.0.1 in the location for a web address.
When the SBG900 page appears choose WIRELESS on the left.
When WIRELESS appears click SECURITY AND stay on the basic page.
Choose WPA as the SECURITY MODE.
Use your phone number as your passphrase
Under the WPA CONFIGURATION section choose TKIP and LOCAL WPA-PSK.
Then click SAVE CHANGES.
The SBG900 may restart before the changes take effect.
May 17, 2011 | Arris SURFboard SBG900 Wireless Router...
Setting up security WPA
Hi Friend,
In order to resolve the issue please follow the steps:
1.Connect the router to the computer and turn it on.
2.Type 192.168.1.1 in the address bar of the Internet explorer and hot enter.
3.Enter the Username and Password (default password is admin and leave blank the username section)
4.Click Wireless tab and fill the sections as mentioned:
Wireless Network Mode-Mixed
Wireless Network name-As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID-Enable and click Save settings
5.Now click Wireless Security tab.
6.Select the Security Mode as WPA Personal
7.WPA Algorithm-TKIP
8.WPA shared key- Enter a key/password of 8 to63 digit length
9.Group Key Renewal-3600 and click Save settings
Turn off the router for 30 seconds and turn it on after that.
Now your network is secured with WPA Personal key.
I hope this will resolve the issue.
Regards
Chiranjeet
Jun 01, 2010 | Linksys Wireless-G WRT54G Router
We cannot connect wirelassly
...I'm not sure on what your actual question is here but make sure you have a wireless network to connect to (you can buy wireless router and an internet service via any internet service provider- I use BT)
If that's not your problem (which i don't know what is) - then make sure your typing security WPA key in properly. (WPA key should be located on the back of your router/hub if that wireless hub got delivered by your current internet service provider). If your still having trouble contact your current home network manager (dad/mum/guardian/employer/lanlord) who has software to control the WPA & what it is).
Your xbox should have a network adapter already installed (device inside that allows connection wirelessly to a networks wireless router/hub). So that shoulden't be the problem (unless your xbox is broken)
Apr 11, 2010 | Sony Playstation 3 (PS3) Console
Need wpa key for xbox live
WPA key is your Wireless router key for internet access.
To connect your console to wireless internet and go to Xbox Live you must enter WPA key for your wireless router.
It`s a same key than you use to connect your Notebook, cellular phone, etc. to your home network.
Dec 19, 2009 | Microsoft Xbox 360 Console
I have a apple. i want to put a password.. wpa security. how do i do this?? i have searched all over. the set up cd is only for pcs..
you want to put a password on wpa security...
here's what you do, actually you are going to open the firmware of your Wireless Router.
Open Internet Explorer, at the "search engine" just type the Gateway Address (192.168.x.x) then ENTER. After that will asking for Login: admin Password: admin __ this time your on the firmware of the Router. This time will appear and select for putting a password on wpa security. Hope this might you the steps. Good luck!
Aug 05, 2009 | Trendware TEW-432BRP Wireless Router...
Try to make sure if the router is connected to the modem. In the router, try to make sure that it is using PPPoE.
May 10, 2009 | Edimax BR-6216Mg Wireless Router...
How can i put internet in my psp?
To connect to the internet;
  1. Check that you have your PSP® (PlayStation® Portable) system set up for Wireless (WLAN) networking in Infrastructure Mode.
  2. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  3. Make sure you are within range of a wireless access point (or hotspot) that allows connections to the internet.
  4. Select icn_www.gif (WWW) under icn_network.gif (Network) from the home menu and press icn_btnx_color.gif.
  5. Use the up and down buttons to select the address bar and press to display the on-screen keyboard.
  6. Use the on-screen keyboard to enter the address for the web page you want to display.
  7. When you have finished entering the address, highlight the Enter button and press icn_btnx_color.gif.
  8. Select a connection and press icn_btnx_color.gif.
  9. The web page will be displayed.
  10. To hide the on-screen menu, press icn_btntriangle_color.gif.
Setting up Infrastructure Mode;
Infrastructure Mode allows you to connect your PSP® (PlayStation® Portable) system to the internet through a wireless network (WLAN) access point.
Required items:
  • A PSP® with system software version 2.0 or later.
  • A wireless network(WLAN) access point with internet access, such as:
    • A Wi-Fi hotspot (such as those at cafés, hotels and airports).
    • A home wireless network, which might include:
      • A subscription to an Internet Service Provider (ISP)
      • A DSL or cable modem
      • A wireless broadband router
  • Settings used for the SSID, WEP/WPA-PSK encryption and WEP/WPA-PSK key, as specified when the wireless access point was configured.
To set up Infrastructure Mode on your PSP®:
  1. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  2. Highlight icn_settings.gif(Settings) from the home menu.
  3. Select icn_networksettings.gif(Network Settings) and press icn_btnx_color.gif.
  4. Select Infrastructure Mode and press icn_btnx_color.gif.
  5. Select New Connection and press icn_btnx_color.gif.
  6. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue.
  7. To set the Service Set Identifier (SSID) for the access point, select one of the following:
    • Scan: searches for and then displays a list of access points (or wireless networks) and displays the SSIDs.
    • Enter Manually: allows the user to enter the SSID using the keyboard. Select this option if you know the SSID of the access point.
  8. If you choose the Scan option in the previous step, select the access point to be used and press icn_btnx_color.gif.
  9. Confirm the SSID and press the right directional button.
  10. To enter security information for the access point, choose one of the following:
    • None: does not set security information.
    • Wired Equivalent Privacy (WEP), WPA-PSK (TKIP), WPA-PSK (AES): all set security information. Press the right arrow button to move to the screen for entering WEP or WPA (Wi-Fi Protected Access) keys. Note: The WEP and WPA key fields display eight asterisks no matter how many characters you enter as the key.
  11. After entering the security information, press the right arrow button to continue.
  12. To select the address setting method, choose one of the following:
    • Easy: the following information is automatically set
      • IP address settings: Automatic
      • DNS settings: Automatic
      • Proxy server: Do Not Use
      • Internet browser: Do Not Start
      Note: Most home networks will allow you to use the Easy address setting, which is recommended.
    • Custom: you can manually enter detailed setting information, such as when you are using a static IP network. For details, see the instructions supplied with the network device or the information provided by your ISP.
  13. After selecting the address setting method, press the right arrow button to continue.
  14. Check the settings, using the left arrow button to return to previous screens to make any necessary corrections.
  15. To save the new connection, press icn_btnx_color.gif.
  16. To test the connection, select Test Connection and press icn_btnx_color.gif.
  17. If the connection is successful, information about the network connection will appear. Press icn_btncircle_color.gif to end the connection test.
You can also check http://www.us.playstation.com/support/psp
for more information.
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
Edimax PRI-682 Router (PRI682) Logo
167 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
