Question about Philips DVDR980 DVD Recorder
AB FFDOCO the error code is there and non of the buttons works remotely or manually I dont know what to do.
All the codes in the manual dont work with my rca tv you know what i can do to fix it?
Eric, most universal remotes have a auto search feature, it should be in the remotes manual. If you have no manual try Google search your make and model# manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://voxrightnow.custhelp.com/app/answers/detail/a_id/1569/~/automatic-code-search-method-for-universal-remote
RCA Remote Auto Code
http://www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button
May 17, 2016 | RCA Televison & Video
How to tune tv with remote?
if you dont know the code too use and have the manual now
try to find the type you have look in google for the manual
use
make model and add the works user manual or similar search
or.. just go to the £1 shop and buy a decent universal
i got one works for me
just press set and hold for a few seconds
the led comes on
then press the red power on
and it starts to transmit turn on off signals
so once it turns on be quick and press the TV buttons
its the button in a row to choose different devices
so this stores the new code
from the manual you can find the codes sometimes not
but you can also get the remote too tell you the code that works
and then note it and if anything goes wrong you dont need to do the set search again
try to use the manual for your one or find it saves any waste
Dec 10, 2014 | Universal Televison & Video
AB-ADP030 remote takes codes to a Toshiba but half of buttons won't work like play and menu
Not the original tv remote alway will have some problems with some functions or missing functions.Want it to work like the original,must buy the original remote.Tried website like Remote.com buy a new or refurbish original tv remote
Apr 04, 2014 | Televison & Video
Need a code for hd satellite receiver 550hd from one for all remote
I couldn't find "AB IPBOX" in the satellite codes, but here is the complete list of satellite receivers in the URC 4081 manual. Hope one of them helps.
Setup Codes for Satellite Receivers:
AlphaStar 0772
Echostar 0775, 1005
Expressvu 0775
General Instrument 0627, 0361, 0869
HTS 0775
Hitachi 0819
Hughes Network 0749
JVC 0775
Jerrold 0627, 0361
Magnavox 0724, 0722
Memorex 0724
Next Level 0869
Panasonic 0701
Philips 0724, 0722
Primestar 0627, 0361
RCA 0566, 0143, 0392, 0855
Radio Shack 0869
Sony 0639
Star Choice 0869
Toshiba 0790
Uniden 0724, 0722
Zenith 0856
Feb 10, 2014 | One For All Televison & Video
I need a list of codes to reprogram a universal remote for magnavox televisions.
hi, please could you let me know the make and model number of your remote, this may be written under where the battery goes as each model will have a different setup option.
if you do have the manual but dont have the codes then what you can do is an auto scan where you keep pressing the standby button until the telly turns off you then save it at that point then the remote should work the telly, if you dont have manual then let me know ok
i need to know if its made by ge or rct etc as their are a few people who make them
CLICK HERE
you may find the manual or codes here
here is the guide for an rca universal remote follow these instructions to scan through all the codes on the remote and save it when you come to the correct one, this is for rca how ever their are many other universal remotes so this may or may not work
1 turn on the target device, in your case this will be the telly
2 press and hold code search until the led lights light up
3 release the code search button
4 press and release the component button you wish to program in your case this will be tv it should flash then light back up and remain lit
5 press and hold the code search button until your tv tuns off then let go and press enter to save the code.
now if your remote is and rca one then keep doing this until the telly turns off then press enter and you should then be able to control the telly with the remote, if how ever this is not the instructions for your remote then let me know what make the remote is ok.
let me know how you get on or if you need further assistance ok
May 26, 2010 | Televison & Video
I dont know code button for my remote rcr311w
Your best bet is too look at the manual for the remote or to contact the company for further instruction.
Oct 26, 2009 | RCA Universal Remote Control
Dont know how to work it
Try getting the manual from retrevo.com Julio milleniumtvsvc@gmail.com
Jul 26, 2009 | One For All URC4110 Remote Control
I dont find philips RC2033 code.
Don't know if you have the original codes or not, but here are the codes for Phillips TV's from the original manual. Hope this helps. Try them one at a time and see if they work.
002, 009, 102, 109, 309, 402, 408, 502, 508, 807, 901, 914.
Good Luck,
Chris :-)
Nov 10, 2007 | Philips PM-8FS LCD Touchscreen Remote...
What do I have to do?
Introduction Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are programming into the remote. While some trial and error may be required to get the right codes input to control your equipment, the pleasure at getting rid of several extra remote controls will far outweigh the hassle in getting it programmed. Instructions Difficulty: Easy Steps 1Step OneManually turn on the device you wish to program. 2Step TwoPress the Code Search button on the remote until the indicator light turns on. 3Step ThreeRelease the Code Search button. 4Step FourPress and release the button for the device you are programming. 5Step FiveEnter the three-digit code for the device using the number buttons on the remote. After the code is entered, the indicator light turns off. 6Step SixAim the remote at the device and press the power button. The device should turn off. 7Step SevenPress Channel Up on the remote with the device on. If the device responds, no further programming is required. 8Step EightTo look up a device code to enter directly into the remote, you can visit the GE Remote Code Locator SAMSUNG 002 012 102 103 112 212 502 512 818 914
Apr 01, 2007 | GE RM24911 Remote Control
Mbr3447 remote code for samtron vcr
Up untill a few years ago they used to make a lot of universals with a "learning" function, that you aim the thing at a certain device untill it figures out the right code for it. I read that the technology was bought since so you dont see those quite as often in the market. ok, if yours is a learning uni, here's a tutorial on how to fix it, in general terms since it varies between remotes: If you cannot get the instructions - most "universal" remotes have a "code search" feature. Usually this involves hitting the "program", "select" or "function" button, then pressing the device button ("TV", "VCR", "AUX") then repeatedly pressing the "power" or "channel up" button until the set responds. The remote will cycle through each of the codes (01, 02, 03, 04) sending the "power" command for each. When you hit the right code - the set responds. When the set responds, stop and then press the "program" or "function" button to enter it (which button varies between mfgrs). If you count the number of presses - that should be the code (12 presses is "12" or "012" - or it could be 11 if the codes start at 00). If you do not have a "program" button (it might be hidden), then you may have to instead hold the function (TV, VCR, Cable) button down for a few seconds (until the light blinks). The usual manual sequence is: 0 1 2 It might also be: 0 1 2 If no program button: 0 1 2 Some remotes use a two digit code, some use three. It'll take quite a bit of trial and error without the manual. you can try getting the codes from the manufacturer, go to their site and see if you can figure anything out there... good luck
Jan 19, 2006 | Zenith MBR3447 Remote Control
Philips DVDR980 DVD Recorder Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
