Question about Edimax BR-6114Wg Router (BR6114WG)
What is the difference between wireless router and a LAN router?
    Scholar:
  • 43 Answers
You can a wireless router that does the same thing as a LAN router, but you may have a cable LAN router that doesn't host clients wirelessly.
The basic funtion of both is to correctly route network traffic for the intended recipient. The information can be from computer to computer or across intranets (normally high-end switches are used instead) or from the internet through a modem (modulator demodulator) to computers connected to the router (wirelesslor cable).
The difference being, the cable LAN router is connected by a ethernet cable and is capable of faster nominal transfer speeds and a wireless is able to transfer information across a 2.4GHz radio signal.
Don't knock the speed of the wifi, though. I quite happily stream movies from my server to my TV through a wireless connection.
Posted on May 10, 2009
2 Suggested Answers
  • 56 Answers
SOURCE: Belkin Wireless-N Wireless Router with 4-Port Switch F5D8233-4
It will work just fine, I had the same info display when I was w/ Time warner.
Posted on Apr 29, 2008
HOW TO Connect tl-740n wireless WIFI router to PTCL DSL WIFI ROUTER
The easiest way to chain two wireless routers. *Please note this is just to have wireless access*
Make sure DHCP is enabled for both, make sure their SSID (the name that shows up when you connect to it) is different.
Make sure they are both different networks. So for example configure the first for 192.168.0.0 network and the other for 192.168.1.0. Now plug an Ethernet cable from the 740n router (WAN) port into a (LAN)
Second method *This only works if the tl-740 router supports AP mode (Access point).
In the configuration of the 740 router, enable AP mode and make sure DHCP and nat are turned off if they are on. Configure the wireless to operate on channel 1 6 or 11. Name the SSID the same as the other router. Plug in Ethernet from WAN 740 to LAN on the other router. Now on the DSL router make sure the SSID is the same and select a different channel from (1,6,11). Now you're all set.
Jan 26, 2013 | D-Link DSL-G604T Wireless Router
I dont know my SSID code
The wireless router has a default SSID usually it is the router manufacrurer's name, you should change this SSID to something different to make your wireless router secure.
Connect a LAN cable from the router to the LAN port on your computer, open a browser and enter the router's configuration URL and go to the wireless settings to change the SSID.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 14, 2011 | Computers & Internet
Had to reinstall Intel wireless LAN 'PRO/Wireless LAN 2100 3B Mini PCI Adapter'. Now it can see our home network, but nothing happens when I click on 'connect'. I am using a different comptuer as the one...
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Apr 23, 2011 | Computers & Internet
My G Mimo Plus adapter won't pull and IP address. Any suggestions?
Is there a RESET button on the back of the router, if so power it up and press the RESET button until all the LEDs flash and reconfigure the router.
Try a different LAN cable, the other could be faulty
Install the latest LAN and wireless card drivers (this problem sometimes occurs when you install a new router).
Check the LAN and wireless cards are functioning correctly in Device Manager.
Open the DOS cmd window.
Test the NIC - loopback test address - ping 192.0.0.1
Ping the router's IP configuration address
Type ipconfig to see what IP address you get (if any)
Type inconfig /renew all - this will (should) get a new IP address from the router's DHCP
Let me know how things work out.
Dec 24, 2009 | Belkin Wireless-G Plus MIMO Router with...
Toshiba NB 205 connects to router but not internet
The wireless configuration is set differently on routers, eg the SSID, and encryption. You need to configure the wireless LAN card in the laptop to connect/communicate with the different routers.
Some wireless LAN card allow you to setup different profiles/settings for different wireless routers. Eg one setting for the office and one for home, which allows easy connection to the Internet by selecting the appropriate profile/setting.
Aug 17, 2009 | Toshiba Computers & Internet
Cant acess internet or wireless network,need passphrase
The IP address 10.0.0.1 is a default for some types of network routers including Cisco routers. open it in browser and make LAN and WAN setting of modem and Router Same and security passkey of wireless same ans of wireless lan card and DNS setting same suyyam@gmail.com
Jul 22, 2009 | D-Link DI 514 Wireless Router (DI-514)
Apr 28, 2008 | Computers & Internet
DI-524 Wireless
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has 192.168.2.1, you may assign 192.168.2.4. Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Feb 20, 2008 | D-Link AirPlus DI-524 Wireless Router
How to use this unit as a Access Point for an existing Wireless Home Network
set the second router through the web menus to a different ip address, cant have 2 devices on the same (default) 192.168.0.1 address, try 192.168.0.2 (example only) to stop data collisions
connect by cable secondary router lan port 1 to the primary router lan port 4 (any lan port to any lan port),
drag secondary router upstairs on its cable and install it wherever you want
set two routers on different channels.
set all wep settings on both routers the same.
set all pcs to 'auto channel' select
wireless adaptors in pcs will then select strongest signal at any point and transmit thru that router
Feb 15, 2008 | D-Link AirPlus DI-614+ Wireless Router
Can't get it to talk to my LAN in ad hoc mode
Is the AP connected to the router using a ethernet cable? Are you having similar issues when you connect wirelessly to the wireless router?
Feb 11, 2007 | D-Link AirPro DWL-810+ 802.11b...
Edimax BR-6114Wg Router (BR6114WG) Logo
111 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
