Hello. I need assistance on fitting a new keypad on my Fujitsu Siemens lifebook E7010. Can you help please?
  • Anonymous May 10, 2009
    Hello ,thanks for replying. I have a new keypad for my fujitsu siemens e series lifebook e7010. To replace the keypad, do I just pull it off and stick the new one down or do I need to lift the plastic base and insert the keypad in?
  • Nelson Olaso
    Nelson Olaso May 11, 2010
    hi....what do you want help us???what kind you need assist..thanks
Where do I buy LifeBook S7020D motherboard?
You can buy it only from Fujitsu Siemens,because each model will be manufactured in a different style and design. So any other related model boards will not fit in this case. If they have stopped manufacturing the motherboard for such a model, then nothing could be done.
Go for a new one rather than worrying about the old.
Sep 12, 2012 | Fujitsu Siemens LifeBook S7020D Notebook
Does my siemens lifebook c6555 fujitsu have bluetooth?
Hello Darren,
Sorry, but it doesn't have a Bluetooth.
Nov 03, 2011 | Acer Aspire 5535-5050 Notebook
My fujitsu siemens lifebook s 7110 is over heating what can ido?
You need to turn the laptop upside down and remove the panels, remove the fan assembly and clear the fluff and dirt from the copper heat sink.
If you don't feel that adventurous you can buy a laptop tray with built in fans that blow cool air into the laptop to help keep it cool and assist the main processor fan.
Jul 24, 2011 | Fujitsu Siemens LifeBook S7110 Notebook
I have a fujitsu siemens lifebook E7010 laptop and the problem is this : When I switch on power the system goes ON but with a black screen and the small LCD is showing the start logos CD player is working...
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Jul 22, 2011 | Fujitsu LifeBook E7010 Notebook
I have fujitsu siemens lifebook S 7020D and has bios password, i dont know the passward and when i tried three times to write the password, i got (system disabled with noise) please help me what to do
Hello, all i know that you can do, is to open up the system and bring out the board. Deep it into a salt water for about 20min, then take it out and dry it very well, then couple it back then see if the password will come up again.
Apr 02, 2011 | Fujitsu Siemens LifeBook S7020D Notebook
I have a Fujitsu Siemens Lifebook E7010, and smotimes it work great, but somtimes it will not start, there ar just 1 long beep and 2 short beep tones. pleas help
check for updates on fujitsu web.. it seems you have to flash the bios.. (when it beeps in most cases there is hardware problem... proc, ram, hard drive, or even mother board... check with manufacture if he had post some of the new updates for your laptop
Dec 02, 2009 | Fujitsu LifeBook E7010 Notebook
My Fujitsu Lifebook E7010 suddenly needs a password to go to setu
This sounds like an administrator password. Generally this p/w is left as password. Try password all lower case and try Password with capital P.
Aug 10, 2009 | Fujitsu LifeBook E7010 Notebook
LIFEBOOK E7010
3 beeps is generally a video card problem. Unsure if your laptop has separate video or if it is imbedded on the board, first make sure ram is fully seated in socket
Aug 27, 2008 | Fujitsu LifeBook E7010 Notebook
My fujitsu lifebook e7010 doesnt always turn on properly
If an external monitor is plugged in an the display is ok then the problem is probably an inverter board or bad/loose flex cable to the lcd screen.
If the external display is distorted then the problem is the video adapter on the laptop.
Mar 31, 2008 | Fujitsu LifeBook E7010 Notebook
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
