Question about Intel Dot Station (INTC300AIO) PC Desktop
Disc system failure error
I just changed my motherboard, process and ram... maintain my old hardisc... i cant load into win xp... so i do a repair on windows.. successfully load into windows... however when i restart my system... it is booting from cd and have a disc system failure error, asking to insert cd and press enter... pls note tt my 1st boot is cdrom and 2nd is hardisc...
any solutions?
  • wtm Oct 12, 2007
    tried 1st boot device as hardisc... also don work...
    how?
  • 28 Answers
You can set a jumper setting it given nr ide port or sata port or pwd suppuly socket b/h HDD ( Given intruction on HDD for jumper setting) if your problem is not solved change your ide cable or sata cable
Posted on Mar 03, 2009
    Habit-Forming:
  • 188 Answers
U SHOULD SET HARDDISK AS U R 1 ST BOOT DEVICE.. I THINK THIS MAY SOLVE U R FROBLEM..
IF IT DONT HELP ,U. THEN..U CAN RE INSTALL WINDOWS..
best regards & best of luck..
Posted on Oct 12, 2007
  • SHIVAJI YADAV
    SHIVAJI YADAV Oct 12, 2007
    ok man u have lost or crash u r window ...
     only 1 solution is there for u that u re install ur window... ok
    i recoment u to use win xp-sp-2  for best pc porformance...and 1 more thin ..
    u shouad have a good anti virus program on ur pc to protect it from virus...use avg 7.5
    im sure u r problem is solved....................................ok
    byby
SOURCE:
My PC : 945GCM2S-A2-6H Mother Board 1.60 Intel Pentium (R) Dual CPU E2140 @ 1.60GHz 1.60GHz 1GB RAM 80GB HDD ATA Formatted , Partitioned. IS OK. OS: Win xp2 is OK. PROBLEM: Every time when the PC...
might be cmos battery is flat on the motherboard and it is forgetting the Type of hard drive you have.
Suggest looking for cmos battery it might be a cr2032 type battery attached to the motherboard .
Mar 26, 2017 | Microsoft Windows XP Professional
Hello sir i have new M4N68T-LE-V2 with new amd athlone 260 my prob is when i install drivers in xp and restart then blue error appears i update bios change install directory also change ram and try...
Hi, you can download a manual here if you don`t
have one:
http://www.asus.com/Motherboards/AMD_AM3/M4N68TM_V2/#download
Please select your operating system 32 or 64 bit system.
Select manual and click on global for download.
Unzip the file before you can read it.
My guess is that your harddrive has a defect.
Or the windows disc is broken so all the files on
it not being loaded properly on the harddrive.
A blue screen is typical harddrive failure.
Try to change the harddrive with a new one
and see if the problem helps you.
Aug 31, 2011 | ASUS M4N68TM Motherboard
I think i have malmare. i can not see homepage. i get notices hard disc error, ram memory useage is critically high, ram memory failure, ram hard disc cluster detected, system detect problem ide/sata...
Hello.
Try System Restore.
Boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
Hope this helps.
Jun 24, 2011 | Acer Aspire 5520-5908 Notebook
'm installin win xp on my pentium3 with 10gb harddisk n 256 mb ram... it shows setupdd.sys could not be loaded error code 7 durin installation.. i tried change d xp cd 3 times.. still hav same problem
change the cd-rom unit,i know it sounds crazy but try it before you waste anymore blank discs,im a tech and that is one solution that works ,good luck
Feb 27, 2011 | Computers & Internet
How can i fix a blue screen error UNMOUNTABLE BOOT VOLUME. technical information is: STOP: 0X000000ED, etc.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test or replace all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Jan 13, 2011 | Microsoft Windows XP Home Edition
When I try to download xp operating system in my motherbord after copying files when it restart it shows ----"error loading operating system" After that I change my Cd Rom, operating system disc, hard Disc...
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
Sep 05, 2010 | Mach Speed PM2MP Motherboard
Ms-7061 msi motherboard will not install win xp with sata drive
The problem is that your version of XP does not have SATA drivers and therefore does not recognise your new drive. Vista does. If you Google the problem you will find many solutions on how to rectify the situation. Basically, you have to make a floppy disc with the correct drivers for your Motherboard's hard drive controller. Then, when you launch your Windows XP installer, it will ask you a question about needing to install 3rd party drivers. Yes is your answer. Tap F6 to ensure that the installer doesn't skip.Insert the floppy disc and then after the drivers are loaded, the installation will proceded normally. The other alternative is to leave your existing XP installation in place and add the new disc. Later you can clone your old disc onto the new drive and then remove your original disc.
Feb 11, 2009 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
Disk boot failure error while booting
What does it says???Cant find hard drive or what???
Jul 18, 2008 | Compaq Presario 700 470024-192 Notebook
Os error
do a operating system repair, use the windows xp disk to do this
May 28, 2008 | Intel Motherboard
Intel Dot Station (INTC300AIO) PC Desktop Logo
67 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
