THe ''V'' belt has broken which powers the twin cutting blades on the MTD RS115/96B sit on mower. I have tried e-mailing Barrus in Oxford who import the machines and have been completely ignored. All I want is the replave ment belt or the size, not much to as is it ? Any ideas where I can buy said belt. Regards Graham Streets
Try Checking the Breakdown at the Following Site Addy for the Belt Number and Size and you can Order the Belt from this Company as Well. http://www.smallenginepartswarehouse.com/parts.asp
Hope this Helps.
ed, be sure there is nothing wrapped around the blades. lower the deck and be sure the belt is around all of the pullys. If the belt comes off one of the pulleys or the pulley on the engine it may feel normal but it wont engage the blades.
There are two belts, one for the deck and one for the main drive. The main drive belt can be seen on the upper pulley under the engine. Check to see if it has slipped or broken.
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site, http://www.mtdproducts.com/ Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Check your tire pressures: 10 psi. for rear tires. 14 psi. for the front.
Note that according to MTD: Making sharp right hand turns. Twin-blade mower decks are designed with
the discharge on the right side and two side-by-side blades. The
side-by-side twin blade decks have the left hand blade positioned
slightly forward and in front of the right blade. This provides cutting
overlap when traveling in a straight line. As a result, the tractor
should mainly operated making primarily left hand turns when cutting.
During left turns this cutting overlap is maintained. If turning right
when, it is possible to negate this overlap and leave an uncut strip.
