Question about Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System
My washing machine does not have a spin cycle
Westinghouse Lt 7585. The machine operates normally until it reaches the spin cycle. Clutch Mechanism disengages and it seems as if something is jammed.
I just solved this problem myself. It's the lid lock mechanism which is located under the top cover. When I manually moved the aluminum locking tab over my washer prompty drained and spun. There are four wires total going to the switch. Well, the solid white and the white/red wires control the lid lock mechanism. You can either replace the entire switch or bypass the lid lock by wire nutting the two wires I previously mentioned together. Now, if you bypass, be forewarned the lid will open while the washer spins very fast which presents a potential danger. For immediate use, bypass until you get the replacement switch. Hope this helps your problem.
Posted on Aug 25, 2009
E27 and e95 code
I had this problem. I tried to interupt a cycle just after it started and then couldn't start the cycle again, with the E27 code coming up.
e27 refers to a problem with the door locking mechanism which could be due to a number of causes. The problem I had was with the solenoid in the door, not a genuine problem with the door latch mechanism.
Here is how I fixed it:
(1) Set knob to off
(2) Hold down spin selector and Allergy rinse buttons and turn the knob to the LEFT (right does not work)
(3) The display then shows a number of program codes P01 to P14. (Pressing spin selector rotates through the codes).
(4) Press spin selector until you reach P02 on the display, then press the start button, the door will click and the machine will begin a cycle.
(5) Turn the knob to OFF, and then you should be able to use the machine as normal.
Jul 18, 2011 | Bosch Nexxt 300 Series WFMC2201UC
My washer spins out very slowly and the water drains but the clothes are very wet.
f the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing.
Nov 30, 2010 | Westinghouse WWS833ES Super Capacity Top...
Machine will not agitate during rinse cycle of normal wash.
The brake is part of the mechanism to function the spinning. The agitation is another mechanism to function in the other direction of the same motor. This mechanism is below of the other. The helix part needs to replace to fix this. This should be done when you change the brake. Of course this is a result from the brake change since you have take this apart before you can get in the spinning mechanism. It is good that now you don't have to touch the spinning mechanism, but only the agitation mechanism. It is not from the tight belt. Hope this can help.
Jan 09, 2010 | Dryers
I just replaced the belt on my White WESTINGHOUSE la 560axw2 WASHER. It is now severely out of balance whenever it reaches the spin cycle.
The problem may be with the top springs may be damaged you can replace the spring set completely to get the smooth running in the spin
Dec 30, 2009 | Westinghouse WWS833ES Super Capacity Top...
The machine will start a cycle normally, but after the timer reaches a certain point it stops counting down and the machine will continue to agitate until you force it to stop.
Thank you for verifying the model type so many folks post non FAV6800A/FAV9800A questions in this forum machine specific topic area.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
You will need the Service Manual for support. I’m an owner like you with a solid repair skills on the machine and will try to help you DIY the repair if we can ID the issue through troubleshooting.
Do you have this condition in all wash cycles? Will a Quick Wash cycle complete? Do you see the Cycle Status LED ever indicate the machine has moved to the Spin Cycle during the wash cycle? This could be a Control Board failure but we need to troubleshoot.
I want to make sure the Wash basket will spin up with a Spin Only cycle selection. Can you select a Spin Only cycle with a empty wash basket. I would release the washer top so you can observe this test. I want to rule out a broken Clutch large wrap spring.
Page 33 of the Service Manual will show you how to release the washer top from the base. In Spin Only cycle raise the top just enough to make sure the wash basket is rotating Counter Clock Wise – CCW with the Spin Only cycle selected and operated.
If the above test doesn’t indicate an issue I would like you to try the Quick Service Cycle test on page 15 of the Service Manual and see if your FAV6800A will pass that test with no clothes in the washer. When you put the machine in Service Mode press and hold simultaneously the Enviro Plus and Spin Only keys until the machine beeps and the LED display reads 00. Then press Wash/Rinse Temp to start Quick Service Cycle test. Did the test complete with a PA indication in the display? It will only display the PA code for a few seconds. End of cycle will beep washer will unlock and Cycle Status LED will indicate complete.
Waiting for your reply….Rich
Dec 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Tube doesn't spin during rinse/spin cycle.
It needs a new clutch. Call a repair technician.
Nov 19, 2017 | Washing Machines
Hoover hse 130m washing machine problem
i found a squirt of wd40 worked wonders
May 27, 2008 | Hoover H130E Front Load Washer
Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System Logo
1,319 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mack Baxter
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
