Question about LG enV VX9900 Cellular Phone
No Memory Hello, I am wondering how do I delete applications that doesn't exist...My phone will not let me download applications that I need to download ringtones nor ringback tones, It tells me no memory left... V/R Mr. Wilson
  • 106 Answers
Re: No Memory
You can go to
settings and tools -> memory -> phone memory -> PH usage
then click clr and browse the other options. thats is what on your phone and you have the option of deleting them from there.
Posted on Nov 02, 2007
0 characters
3 Points
I bought nokia c5 , and i don't know how to delete some applications as the message of memory full delete some applications is usually appearing please help me
To delete the application on the phone is quite simple.What you need to do is to go to the main menu, then you select application, then you select the application you want to delete,then you select option and scroll to delete, then the application will be deleted.
But i will suggest you move the applications instead of deleting them. To move the applications, just do the same thing you did when you wanted to get to the application to delete, then you select move instead of delete, it will ask for where you want to move the applications to, then you select the memory cards position, then the applications will be moved to the memory card.
Thank you for using fixya.
Sep 05, 2011 | Nokia C5 Cell Phone
I hav d nokia E63..! & i cannot send any says "memory full , close some applications first...(& i hav absolutely no applications on except messaging)...... before it said that...
hi, the memory might truly be full...check your memory status and see if truly it is full....if after checking, you realized that it is full, then you will have to delete some messages and delete some applications that you use less often..but, if you check your memory status and you realize you still have space, then it means you will have to scan for virus.
Mar 16, 2011 | Nokia E63 Cell Phone
My memory card had been corrupted.. all the files saved on it deleted... after that i cant download any application now on my nokia e63 phone..
You probably just need to format the external memory card that you had before and got corrupted,because with that you will have gotten rid of maybe the existing virus that was acquired by the card,then if you have a PC suite for your Nokia handset, run an antivirus to clean the virus from the phone.
It is having the problems,just probably because there were some existing virus that corrupted your phone from the site you downloaded your documents!
Thank you.
Dec 09, 2010 | Nokia E63 Cell Phone
Lg chocolate bl40 doesn't access music player just displays' loading' & rotating circles.It remains in this mode indefinetly, or until it switches itself off.If the cancel button is pressed the phone...
Problems like that is like a memory storage failure. Check if there is enough memory in your memory card. Try to delete some un-needed files or application to free up space. If you have an alternate memory card try to replace the existing memory card.
Nov 26, 2010 | LG CHOCOLATE BL40 (1 GB) Cell Phone
Hanging phone?
hi, it could either be two problems..the 1st problem could be that you do not have enough memory on your phone i.e. the phone memory could be low. so all you need to do is to delete some applications you have downloaded on the phone so as to create more space for your phone...delete from phone memory and memory card..please note, if you have an application that is not compactable with your phone,delete it please because that could also be the problem.
the second option could be that your phone is all you need do here is to scan for virus.
Jul 19, 2010 | Nokia N73 Cellular Phone
How to remove the software from memory card
Well, when you deleted some application it has to be done through installer. You might just delete application pressing C button. In that case there's an install file but no application acces. Try use Y-Browser and if you can't find the file then format the memory card.
Rate me if it helped. Thanks.
Apr 13, 2009 | Nokia N95 Cellular Phone
Lost application
hai delete your phone memory and then try it wors
Mar 21, 2008 | Nokia N70 Cellular Phone
Deleting ringtones to free up memory space
Get a micro SD card for the phone and move your music to the card.
Jan 04, 2008 | Samsung SCH-u740 Cellular Phone
LG enV VX9900 Cellular Phone Logo
65 people viewed this question
Top LG Cell Phones Experts
Scott Fryer
Steve Sweetleaf
Steve Sweetleaf
Jeremy Murray
Jeremy Murray
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
