Question about Briel Chamonix ES-35 Espresso Machine
Problems with Briel Espresso Maker
Hello. Steam is shooting out of the drip holes(probably not correct terminology) . I have cleaned the coffee basket and the upper screen(fixated to the unit), but steam is shooting out of the holes on the bottom of the basket where the espresso generally drips out. Any ideas?
First all of your water drips out and then steam comes out the brewhead. (usually only when you select steam to froth milk) This leaves a very limited amount of steam to froth milk with and makes a mess. While it may be too late to help you, I have three machines that are doing the same thing. There is a checkball and spring assembly in the boiler section called the "aqua stop" that is leaking by. (it gets gunked up with minerals) I pulled one machine apart and had to destroy it to get the "aqua stop" assembly apart. It may be easier to buy a new boiler for $80 (cheaper than new) but I cannot remember the website I found to buy the boiler. A good clean and soak with vinegar (possibly more than once) may work to dissolve the mineral buildup. Good luck.
Barrie
Posted on Apr 04, 2008
SOURCE:
We have a brilliant Briel Multipro that we use every day but when we have made a cup of coffee and release the coffee holder, steam and hot water spurts from the head area...It stops after a few seconds...
First, I'm NOT a Briel technician, But if you still have pressure from the removal of the portafilter (or capsule) then the exit or pour spout is clogged. You can soak a standard portafilter in warm water over nite and wash it clean in the morning. Really bad? then soak in urn cleaner and flush thoroughly prior to use. For capsule machines follow the MFR's instructions to properly flush the machine. You may also try to "fool" the machine into making a 'no coffee' shot by reusing old capsules over and over again to try and flush out old coffee from the spout. Otherwise the unit may need servicing to remove the clog as most of these capsule machines do not have serviceable parts. Contact your vendor or MFR directly for service or replacement.
*warning! Try not to stick a pin, nail, or paper clip into spout(s) as this may damage valve or offset the dual pour spout. Most of these machines have double spouts and can be easily pushed out of alignment.
* Final; I've noted that your probably using a portafilter type machine. If you have water or steam dripping from head then there is a leak in your head valve or commonly called the 'Group Valve'. Fortunately this is a serviceable part and can be replaced by your vendor.
PS. Have you tried 'Back Flushing? Use a "BLANK" portafilter basket (the one with no holes) or a back flush rubber stopper (from Cimbali). Add a 1/4 teaspoon of urn cleaner of flush cleaner to portafilter and lock onto group. Run shot till it stops (excess pressure and dose will by-pass the group valve. This will flush old coffee and crud out the by-pass pipe and into drain tray. If nothing happens and the group hums for longer than 20 seconds then your probably got a clogged valve and back flush pipe. All will need disassembly, cleaning and/or replacement. Best to call your Vendor for service.
*Be sure to run the group several times and wash the portafiler to get rid of the urn cleaner.
*Tip; It's a good idea to back flush every hour with with plain water from the shot to just get rid of the coffee grounds stuck to the group shower head and leftover coffee in the group valve. Does not hurt the machine and keeps everything working smoothly.
Aloha, youtube; ukeboy57
Jan 11, 2018 | Briel MultiPro Espresso Maker - Brushed...
I have a Briel MultiPro espresso maker. When I try to make coffee, water/coffee starts running over the edge of the basket and it "spurts" coffee and grounds after a few seconds.
The group head gasket needs to be cleaned or replaced. First get a brush and clean put the head, then insert back wash filter(basket with no holes) in portafilter, make sure that it is seated properly(atleast 90° angle with machine), then run the head if nothing leaks around the portafilter the gasket is fine, if it leaks then replace the gasket. Make sure that you press the stop button before removing the back wash filter.
Jun 23, 2009 | Briel MultiPro Espresso Maker - Brushed...
Everything works on my Briel Sintra, but the espresso part!
Adjust the grind on the coffee or the tamping / packing pressure on the grounds.
Jun 22, 2009 | Briel Sintra ED-132 Espresso & Coffee...
I have a Briel ED 132A Classic how do I prime the pump for the st
Sometimes the self- priming pump feature may not work due to a momentary "air lock" condition. If water does not flow from brew head, place a cup under the steam frother. Open steam control and turn the switcher onto the icon of the half-full cup until water flows from steam frother. Turn off steam control, as Espresso maker is now ready.
Manual is located here:
http://www.smithagy.net/BrielInstructionManual.pdf
Mar 15, 2009 | Briel Sintra ED-132 Espresso & Coffee...
Briel Apollo no water when making espresso
Check that the water tank is seated properly. When you lower it in place just give it a little nudge down to make sure its slotted into the catch.
Nov 24, 2008 | Briel Domus Due Espresso Machine & Coffee...
GE coffee maker model # 169164 making too much steam, not coffee
If you look at the bottom, you'll probably find 'China' on it.
The problem you are having normally doesn't show up for a couple of months after the lime has had a chance to roughen the ball in the check valve that makes up the pump. Your pump isn't pumping.
I suspect you have some particulate matter that has made its way to the primitive check valve and the ball is not moving freely as it should. The copious amount of steam you are getting is from the bit of water that makes it to the heating element before the (yet to fail) thermal switch that cycles the heater element.
If you have a clean turkey baster, you may be able to flush whatever crud there is in the water path through to the outlet over the coffee basket by sticking the tip into the water chamber's exit hole. We have a large veterinarian's hypodermic that does the job nicely when it is time to flush it again and soaking the water path with vinegar every few weeks overnight will help keep it pumping properly too.
If the flushing doesn't work, take it back before GE gets completely out of the appliance business.
(Whatever happened to Silex??)
Sep 12, 2008 | GE 106591 Coffee Maker
Spares
Try these people
I got a new basket from them for about $6
Electra-Craft, Inc 41 Woodbine Street Bergenfield, NJ 07621 201 439 1700
Aug 27, 2008 | Briel Domus Due Espresso Machine & Coffee...
Milk steamer emits water even when dripping coffee; steam valve doesn't appear competely close
You can contact the service center and find out exactly what is wrong and if they can just send you a part:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
[email protected]
www.electra-craft.com
Mar 04, 2008 | Briel Domus Due Espresso Machine & Coffee...
Espresso maker not workin properly
Your Brew Head screen and/or filter basket might be clogged with coffee oils. You can soak both pieces in a product that removes coffee oils from either www.urnex.com or Dezcal brand. Coffee shops will do this once a day. If you have the filter basket with the screw in the middle, you will need to remove the screw and soak everything as it can clog also.
If that does not work (it should tho) you can contact the Briel service center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
[email protected]
Jan 05, 2008 | Briel Domus Due Espresso Machine & Coffee...
Briel Multi-Pro Coffee / Espresso Maker
You have a leak in a connection or maybe the boiler. There is nothing you can do but find a repair shop to fix or replace the bad part.
Jul 30, 2007 | Briel ED271AP 10-Cup Multi-Pro Espresso /...
Briel Chamonix ES-35 Espresso Machine Logo
215 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Vitally Alcher
ray gallant
ray gallant
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
