Question about Toshiba Satellite A100-S8111TD Notebook
My Toshiba Satellite Pro A-100 sound is gone. Can it be repaired
My PC is ok but when I install the driver the volume and equalizer doesnt show. It there a way of repairing this. There is no sound at all coming out of the pc.
My toshiba satellite L300, has lost sound. when i play it show the sound bars, but nothing is coming out
Check the device manager to make sure the sound drivers are installed. to do this you right click my computer then click manage. when the computer managment comes up, click Device Manager. Look to Sound, video and game controllers. Make sure your sound driver is installed and does not have a red X or yellow circle with a exclaimation point in it.
if you have sound drivers installed as above would show; you need to check your levels. here is a location to show you all this: http://www.tinyeye.com/avsetup/soundsetup_xp.html
if these are fine then you need to look at the side of your unit. some toshibas have a volume control by the headphones. Sadly enough this does not just control the headphone sound but controls the speakers as well. Turn it up if it exists.
Jun 29, 2011 | Toshiba Satellite Pro L300-EZ1501 Notebook
Sound in my toshiba laptop is very less , i have installed sound driver "context" . still sound is low.
This is your correct driver, please re-install it from here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2860981&rpn=PSK2LU&modelFilter=L655D-S5145&selCategory=2756709&selFamily=1073768663#
If this doesn't help you, you can try this:
2. Click on Properties and open the Enhancements tab. Beware, You might not have Enhancements tab, lust like me. Go to next suggestion.
3. Check the Loudness Equalization checkbox then press Apply then OK.
If this trick doesn't work for you nor you can't find the Enhancements tab on your Sound's Properties (just like me), then try this next trick. Use VLC Media Player When playing your favorite music or movie, try using VLC Player. VLC Player as a unique volume meter that goes up to 400% of your maximum pc volume.
May 11, 2011 | Toshiba Satellite L655D-S5145 Laptop
I have toshiba satellite pro L310.But i couldn't find software CD.but in the internet there is drivers for toshiba satellite pro L300 model.Is there is a equal those two drivers?how can I get drivers for...
Here is the link for driver download for Windows XP
http://www.getpcmemory.com/drivers/download-toshiba-satellite-l310-notebook-windows-xp-drivers/
Download it.
That's it
Jan 04, 2010 | Toshiba Satellite Pro L300 Notebook
Microphone issue with "Toshiba Satellite A135 4656" with XP
Most of the drivers can be found here:
http://il.computers.toshiba-europe.c...jsp?service=IL
Select: Notebook
Select: Satellite Promag-glass_10x10.gif
Select: Satellite Pro A Series
Select: Satillite Pro A200 (PSAE1)
Select: PSAE1
Select: Windows XP
Select : Search
This model has the same Chipset Drivers as the A135-S4677
You will need XP SP2 (NOT SP3)
The LINK will show you alot of drivers, but follow this order by make and version #
Chipset Utility: INTEL 7.1.0.1014
Display Driver: Intel 6.14.10.4833
LAN Driver: Realtek 5.664.205.2007
Wireless Driver : Atheros 5.2.0.125
Sound: Realtek 5.10.0.5464 (Next page)
Modem: You will have to select you region
Sep 26, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite L310 problem , display cannot appears
If the screen went blank after the driver install, sometimes clicking the mouse on the screen will bring the picture back. It sounds like the monitor is having a conflict with the resolution the driver is throwing out. Reboot the laptop and when you see the Toshiba splash screen, tap F8 until you see the multiple boot menu. Scroll to Safe Mode with networking and reboot. If the screen comes up, go to the control panel > System > hardware > display adapter > click on the plus sign and double click the reported adapter.click on driver tab and select roll back driver > click yes to any prompts and click ok. Reboot normally and see if that clears the problem.
Sep 07, 2009 | Toshiba Satellite Pro L300 Notebook
Sound
Check toshiba website for the drivers with your system model..
Jan 28, 2009 | Toshiba Satellite A205-S4617 Notebook
Sound
Hi!
Here you can find the drivers for that computer:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1209157&rpn=PSAA0U&modelFilter=A100-S8111TD&selCategory=3&selFamily=1073768663&selModel=1209157|PSAA0U
Jan 24, 2009 | Toshiba Satellite A100-S8111TD Notebook
SOUND DRIVER
Kindly check your sound settings first. It must no be on mute. Check also the physical knob for the volume control. If you have an earphone to try, then it might help to determine if there is no problem with the speakers. Also you need to try windows media player, cause it might be the settings on the software that you are currently using. If you are not sure for the correct driver for the sound card, you can find it it the Recovery CD of this notebook. (TOSHIBA RECOVERY DISK, DRIVERS and APPLICATION). The most appropriate sound card driver is in that disk. If still unresolved, try running PC Diagnostics for the speakers and sound card. The sound card might be defective as a last option.
Sep 07, 2008 | Toshiba Satellite A100-S8111TD Notebook
Audio speakers not functioning, help!
Hi Leon7, there is more than one driver for your Satellite A100-S8111TD notebook as listed one the link below.
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1209157&rpn=PSAA0U&ct=DL&BV_SessionID=@@@@0584055190.1206837807@@@@&BV_EngineID=cccgadedjkjmfdecgfkceghdgngdgnj.0
There is (All I'll list is for Vista), Realtek Audio Driver for Windows Vista (v6.0.1.5343; 01-30-2007; 15.18M)
HD version. Realtek HD Audio Driver for Windows Vista (v6.0.1.5343; 01-25-2007; 15.18M)
Before you re-install make sure you remove any other driver listed in add/remove programs.
Good Luck & Kind Regards.
Mike
Mar 30, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
164 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
