Question about Samsung P30 Notebook
Nc10 fn key not working
Hi,had samsung nc10 for a week ,but the fn key has now started playing up.i have to reboot to get it working.thanks
Samsung NC10: Severe Fn key problem
i would check the bios for an option to keep fn always on and disable that. i would also try updating the bios. THIS HAS NOTHING TO DO WITH THE OS
Feb 26, 2014 | Samsung NC10-14GW Notebook
Hi, i ve samsung NC10 and the back space key and left shift are not working. further to advice from samsung service center i restored my netbook but after restoring; even the function key f11 isn't...
BS, its some ******** bug samsung is **** they dont help many people have keyboard problems they should release a fix software also my spanish nf210 does not even have a working fn+f11 i had to run a software to turn numlock off how ******** and i still have the problem too that shift dont work and backspace dont work
Dec 16, 2010 | Samsung NC10-14ROBL Notebook
On battery power screen dull fn plus arrow key does nothing
The screen is supposed to be dimmer on battery power. Your notebook does this so that the battery lasts longer.
Hope this helps!
Oct 20, 2010 | Samsung NC10-14GW Notebook
My NC10 netbook screen is blank (dead) when powered on
try looking for an FN button and an icon on your keyboard that has 2 screens on it one is blank and one has an outline in it Hold the FN button down and press that key with the icon usually the icon is blue on a keyboard and is on the F1-12 buttons or on the numberpad
Apr 09, 2010 | Samsung NC10-14ROBL Notebook
My laptop's brightness doesn't work. It's at its lowest.
Ok, I had this problem too. Go into start - all programs - samsung - Easy Display Manager, then start Easy Display Manager. Try your function key and brightness and it should work. If you cant find easy display manage this way, type it into your search and start it this way. I have mine on my shortcut menu and start it every time I re-boot now.
If none of this works, just reinstall the program from here.
http://www.fixya.com/unanswered.aspx?q=samsung+nc10
Hope this helps
Jim
Oct 25, 2009 | Samsung NC10-14GW PC Notebook
To use my key board with out pushing the fn button
The Fn key is used in conjunction with F3 to F12 function keys to select second function assigned to these function keys.
Why do you want not to use the Fn key on your keyboard?
May 23, 2009 | Samsung NC10-14GW Notebook
Samsung NC10 Fn key inactive
Go to Start, All Programs, Samsung, then Easy Display Manager Option. Make sure that the "Advanced Volume" is enabled. Somehow that also enables the other functions. I couldn't use my function key for anything but after I enabled advanced volume, the function key was working for brightness, sound, F4, etc.
You also have to make sure that the Magic Keyboard is on.
Hope this helps!
Mar 14, 2009 | Samsung P30 Notebook
Keyboard problems with samsung nc10 netbook
I just had the same problem and found the solution on here. press the fn key and the numlock key which on mine is the F11 button so i assume its the same on yours. hope this helps.
Jan 31, 2009 | Samsung NC10-14GW Notebook
NC10: Can't type without holding function key down
I set up my girlfriends this morning, to turn off Num Lock, you need to have the machine on and select Fn + F11.
That'll turn it off and you'll have the bliss of typing normally again!!
Jan 06, 2009 | Samsung NC10-14GW Notebook
Samsung P30 Notebook Logo
328 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
