Question about Acer Aspire 5500 5570-2609 Laptop
Blank Screen - No Display though computer power light remains switched on.
I tried plagging with external motinor. Same Result. Please advise what coupd be the problem.
Thanks.
  • trove Oct 15, 2007
    Thanks for reply.
    Here is answer to your query:
    1 Does the power lights light up. - Yes
    2 Does the hard-drive light up -  No,
    3. Does anything go on the computer. - .
    4 What does and what does not (light up)
    Answer for 3-4
    I can hear fan. I can open/close DVD drive. I can power up and down computer using power key. There are no warning (bip) when I start computer. No other lights go on.
    Also, I googled , youtubed for solutions, study disassembling notebook and tried following.
    I tried to remove and reinstall memory and hard disk drive. I tried starting without memory and hard disk. But no display. I opened up notebook and checked connection to see if anything is loose. I have not opened LCD (Top part of notebook).I do not know how to do it.
    I tried to search for repair manual but could not find for this model.
    If you need more details please inform.
    Thanks for your time and help.
  • 7 Answers
It is not always the case of Beeps coming from the unit with bad ram.. The ram could still be bad and cause no video internal or external.
Posted on Feb 11, 2008
    Sergeant:
  • 457 Answers
You people are not explaining in detail what is actually wrong?.  If you do this we can try to help you.
2 Does the hard-drive light light up
4 What does and what does not (lightup)
Just because you have a blank screen does not necessarily mean the screen is "had it" and by plugging an external monitor to see if there is problem does not exist.
For all we know your motherboard may have ceased to exist or your hard drive crashed or your memory chip.  Please help me to help you?
Posted on Oct 12, 2007
  • Peter Hirawani
    Peter Hirawani Oct 15, 2007
    Thank you very much because you used the external monitor and had no results this rules out any problems with your LCD it seems to be fine.
    And it is not your memory chip otherwise you would hear a serious of beeps so thats ruled out.
    You say the was not lights coming on for the hard drive this is a suspect.....you may need to look in this area. By your diagnostics it is possible that motherboard has broken down if not the hard drive before it..........Im sorry I cannot be any more helpful to you, you did well to explain in detail and thats the way.  But thats my suspicions on what i think it may be.
I have CQ60.it works fine while after some time the screen goes blank and looks completely black though all the lights are on.power is passing through as well. So I have to manually shut down the Laptop...
Thank you for choosing FixYa. I think it would be better if you isolate the problem if its the Display on the machine that's having a problem. Try to use an External Display use it for a while turn on and off the machine if its giving display using your External Display or its doing same thing. If its doing same thing it means there is a problem with the Motherboard, Memory or Video Display.
Hope I've helped you somehow.
AnEspera
Apr 22, 2011 | Computers & Internet
Has a Toshiba Tecra 9000 won't power up. Power light on front is blanking which appears to be a code 3-3-2
The problem is cause due to one of the following: the backlight or the display, check your monitor brightness settings. Sometimes your brightness may accidentally have been all the way turned down, resulting in a blank/dark screen. The monitor controls are on the keyboard, directly above the numeric keys.
Look closely at your laptop's screen if the steps do not restore power to it and if it remains blank. Can you see a faint image on the screen? If so, the backlight may be off due to the LCD "lid close" detector malfunctioning. This malfunction likely happened due to the lid close switch being stuck in the "closed" position even though the lid is open. The switch is located beside the LCD's screen hinges, and tapping the switch a few times should unstick it.
Use an S-Video cable and plug your laptop up to an external monitor, such as your television set. With the laptop and TV hooked up, turn both on and see if your computer's desktop is displayed on the TV. You can also use a fifteen ( 15 )pin monitor desktop monitor by connecting it to the blue fifteen ( 15 ) connector at the side of the laptop if you cannot see anything on screen it is the display problem. If it is, your laptop's display needs to be replaced. If not, your motherboard and/or video subsystem may need to be completely removed and replaced.
Aug 31, 2010 | Computers & Internet
My hp dv4-1435dx screen is blank.It was on then it froze and then went blank. I have tried to fix it by removing the battery and replacing it a number of times. It comes on when started and plays the...
This could be due to presence of static charges on the notebook or hardware malfunction of the video card or defective LCD display screen of the notebook. To resolve the issue, perform the following steps.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now check if the display works fine or not. Incase, if the issue persists, then the video card or LCD screen must have gone bad, and to isolate the same, please connect an external monitor to the notebook and check for the display on it. You can follow the steps below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your notebook is under HP warranty, then contact HP to get the notebook repaired for free of cost.
Jun 01, 2010 | HP Pavilion dv4000 Notebook
Baterry went off. i have charged it but the screen wont come on though i hear the fan. i have to remove the battrey to put it off. have tried an external monitor and it says computer on sleep mode. press...
Perhaps a result of the auto display off. press any key to activate the screen again.
If using the LCD screen, make sure the priority is not set on an external monitor. To do this, press the Fn function key combination to set the display priority.
if you use an external monitor:
1. Check whether the monitor is switched on
2. Check if the power cable is properly connected
3. Check if the cable menguhungkan external monitor and the notebook is connected correctly.
4. Try to set the constrast and brightness on the external monitor
Nov 01, 2009 | Toshiba Satellite A355D-S6921 Laptops
When I power up laptop screen is blank
You may have a burned video adapter.
A trouble shoting setp you can try is attatching an external display and seeing if that works.
Also try the function F5 key combo. I think that is the ASUS mapping to switch display output.
Aug 04, 2009 | ASUS Eee PC 900 Notebook
Blank screen upon startup
Try taking out the hard disk, plug in power and see if you have a display on your screen or external monitor. if same thing happen, try taking out the memory card. If you hear a beep sound it's a faulty mem. card, if no beep sound appears I suspected it's a motherboard faulty.
May 31, 2009 | Lenovo ThinkPad T61 Notebook
Blank screen on start up on Acer Extensa 4620
Did you switch displays to the external video? Try hitting the Fn key and whichever function key at the top of the keyboard has a little TV screen icon over it at the same time.
Jan 04, 2009 | Acer Extensa 4620 Notebook
Labtop Screen Remains Blank
connect to external monitor to rule out bad video card. (remember most laptops have to toggle between internal and external display by using the <FN>+ <F?> key, mine is FN F5.)
If the external works then the problem is
  1. Inverter board or
  2. TAB welds at LCD or
  3. CCFL Cold Cathode Florescent Lamps (backlights)
May 30, 2008 | Computers & Internet
HTC Touch Display lights constantly on while music playback ... Please Help
the screen display remains on if you're listening to music on the speakers. i've tried many things but couldn't overcome it. the only thing you could do is use the headphone to listen to the music. you can then put the device to sleep mode without interrupting the music.
Jan 22, 2008 | HTC Touch P3450 Smartphone
Acer Aspire 5500 5570-2609 Laptop Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
