Question about Maytag Atlantis MAV6451 Top Load Washer
Egg smell and mold
Our washing machine emits a rotten egg smell during the wash.   There is also a greyish colored, slimy mold that is around the outside of the drum of the washing machine.  This mold ends up on my clothes.  Please help, the washing machine is 8 years old and we have had this problem for several years.
  • 5 more comments
  • cleanwash Oct 13, 2007
    I was watching the Special Report-that is when I realized I wasn't the only one with this problem!!  I thought I was doing something wrong!!  We have tried to take it apart several times but cannot get the drum to come off to clean it.
  • kdeee Nov 11, 2007
    My Atlantis washer has an egg smell and is making a loud noise. It isn't 2 years old and my last Maytag didn't last 6 years. No more Maytags for me!
  • Anonymous Dec 07, 2007
    clothing is still wet following spin cycle. tub is not spinning. water is only being pumped. Replaced a glazed belt- same results.. Is there a tension setting for belt. could it be a " thrust bearing kit" repair needed, i have previously read of such, being the fix?
  • Anonymous Jan 06, 2008
    Washing macjine smell like rotten eggs while running. I have tried running vinegar thru it, no change.
  • seals Feb 09, 2008
    Wash water smells like sulfur and makes clothes smell as well
  • Anonymous Mar 26, 2008
    My Maytag Atlantis top load washer is almost 3 years old now. Within the first 6 months I noticed a moldy/musty smell and did a bleach wash every now and then and it seemed to do the trick. Just over the one year mark it became worse and I needed to do the bleach wash more often, but didn't seem to fix my problem completely. I did a little investigation and found others had the same issue and that the Maytag Neptune had a class action lawsuit. I called Maytag to explain my problem with the Atlantis and their response was to do hot bleach washes. When I explained that I had been doing this they said that it was out of warranty and that I could pay for a service call if I so wished. Well for the past two years I did bleach washes more and more frequenly until yesterday when I was so fed up that I was either going just get a new one or take the thing apart to see if I could find a solution. After taping the top door down so that it wouldn't fly open, I took a putty knife and slid it under the top panel about 2 1/2 inches in on each side. This released the top. I pulled the washer towards me a few inches to clear the back top panel to open the top panel fully. When I did this I could see about 3 inches of mold and mildew crud threw the plastic tub housing. I unclipped the tub lid from the tub and low and behold not a pretty sight to see. I took the tub lid into the bath tub and sprayed it down with hot water and bleach. I sprayed bleach around the top of the washer tub and tub housing. I spent a good 1 1/2 hours cleaning all the disgusting moldy substance. I now have a clean washer. Who ever thought you would have to wash a wash machine. When it comes time to purchase a new one it won't be a Maytag or anything made by Maytag.
  • bmason9656 Jun 24, 2008
    I've just recently discovered the bad smell problem with my wash. I've had the machine for 2 years. If I renew my "insurance" with Maytag, will they truly fix the problem, i.e. take apart my washer and clean it every two years? I certainly am not up to that task.
  • 14 Answers
Every manufacturer should be included in that lawsuit!
Let's put the blame exactly where it belongs and keep it there until manufacturers clean up their act!
What in the world are we thinking when we allow ourselves to be forced to jump through these ridiculous hoops just do do laundry!?
I am furious and it is over something as stupid as a washing machine! A WASHING MACHINE!!!!
New government regulations for new water efficiency washing machines has my family’s clothing smelling like a stinking, rancid, moldy basement! This is absolutely absurd! I have been told to change laundry detergent, run hot bleach water through my washer and, get this; my washing machine is 1 year old and my clothes smell filthy!!! The mold and mildew from these nasty machines have wreaked havoc through skin rashes and allergies in my children!
I paid $1,000.000 for this da*ned washing machine and THIS is what is being sold to the public under the disguise of efficiency!!?? I have been on the phone about this problem. I have, over the past 3 months, with a technician on the phone, been instructed to do the following:
*Make sure I use high efficiency detergent THAT will fix my problem.
Wrong.
*Cleaned the lint trap (..that is stupidly behind a metal access plate that you have to use a screwdriver to remove screws to get to it EVERY TIME) and THAT will fix my problem.
Wrong!
*Cleaned the water hoses; THAT will fix my problem.
Wrong!
*Cleaned the gasket around the door. THAT will fix my problem
Wrong!
*Cleaned the tub with bleach water. THAT will fix my problem.
WRONG!
*REMOVED the hoses and cleaned the pump. THAT will fix my problem.
WRONG AGAIN!
*Take the pump out entirely and clean all inlet, outlets and hoses. THAT will fix my problem.
WRONG! WRONG!! WRONG!!!
NONE of this fixed my problem of filthy, wet, stinking, rancid clothing that has endangered my family's health! I even washed my children's clothing out by hand in the bathtub and put them in the washer just to rinse and spin and they STILL smelled horrific.
Finally, at the end of my rope, I returned to the appliance store from which I purchased this machine and they have told me that they cannot accept a return. They will not accept a return and I have to deal directly with GE. I HAVE dealt with GE up until the final straw when I they told me I needed a new pump, but so sorry, your warranty JUST expired 3 days ago!!!
Furthermore, my pump was fine. I did NOT need a new pump and have now been told that I cannot return the new, unused pump that cost me another $183.00. I have now been told that this is a problem with ALL front loading washing machines and I should do the following:
*First, run a full complete wash cycle on hottest setting containing Bleach – * Note: wash cycle takes 1 hour and 20 minutes
*Next, run a full wash cycle on hottest setting using high efficiency laundry detergent for another 1 hour and 20 minutes
*Next, run a full wash cycle on hottest setting using Cascade automatic dish washing detergent for an ADDITIONAL 1 hour and 20 minutes
*Next, using Bleach water, wipe down entire interior of washing machine
*Next, using clean white cloth, wipe entire interior of washing machine dry
*Next, leave door ajar to air out machine
*Finally, I have now been informed that I cannot use fabric softener in the machine even though there is a fabric softener dispenser right in the machine because the new front loading machines cannot handle fabric softener!!
Furthermore, I was told that this is new technology and since it is so new, no one really knew these kinds of problems were going to manifest themselves and I just need to try to work with these problems because it is not the manufacturers fault but the GOVERNMENT’S fault! Sorry.
Are you kidding me??
Now I have a $1000.00 piece of junk that the appliance companies are pawning off on unsuspecting consumers and hiding their horrible designs by blaming the government.
So, now this is what I want!
I want the legislature to force manufacturers to properly inform the public of these problems and those who did NOT inform consumers of these issues, COMPENSATE their customers for the $$$$$ it has cost us and the misery and frustration caused by THEIR neglect by NOT informing the consumers of these issues. I want this to be retroactive BACK to at least the year 2005. Furthermore, I want compensated for the cost of buying a top loading washing machine in an effort to keep our families away from the mold and mildew and filthy mess this has caused! Finally, I want manufacturers to own up to the fact that they disregarded the health and safety of consumers in their efforts to profit as much as possible while touting efficiency.
Now I have heard that they have a new 'product' they can sell to us to inhibit the stench of mold and mildew. This is absolutely unacceptable!
This is outrageous and we need to speak out about this and make sure our voices are heard!
Posted on Dec 12, 2007
You should have been watching the Detroit news Special Report yesterday.  There is a class action suit that was settled for this problem against Whirlpool and Maytag - my machine is LT Tromm and it does the same thing - I keep meaning to call Sears about it but mine is only 2 years old. and it's a top of the line machine. After watching this special report on the news - guess what I am going to be doing as soon as that store opens up!!!!!!!!!!   I recommend that you don't be silent about this.  I am giong to check out the Detroit News channel today to read more about it.
Posted on Oct 12, 2007
Top load washer smells like rotten eggs when water is draining into tub
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Sep 19, 2014 | Whirlpool WTW8600YW: 4.6 cu. ft. Cabrio...
Smelly water with water softener
Your local home depot sells a product called AFFRESH that is made for front loaders to clean mold as well as stagnant water smells from washing machines. I have also hear other techs suggest vinegar and water but personally I would much rather have the unit smelling nice and flowery smell instead of a vinegary smell. Also it is important to note your drain line should be at least 6" higher then the top of your washer if it were less then the water that is supposed to leave the machine goes back inside the machine thus giveing some a stagnant water smell or like bad eggs.If you have any further questions message me back
Thank you
Rick
Nov 26, 2011 | Washing Machines
The washing machine smells like rotten eggs on the rinse cycle. The clothes also smell afterwards as well. What can I do to resolve this?
Rotten egg stench is caused by sulphur content in the water or building up over time in your water heater. It can also build in a water system that is rarely run. Have you noticed this smell from other taps in your house? There are inline charcoal filters that can remove it from the water, or you can also try removing the water lines from the washer and running them awhile.
Is this new, or has it been happening for awhile?
Dec 04, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Rotten egg smell in my dishwasher
Yes mold and rotten food in the filter screen at the bottom of the dishwater water tube
Oct 16, 2017 | Hotpoint 24 in. HDA3740G Stainless Steel...
Terrible smell during washing cycle!
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. Good luck with it.
Nov 27, 2009 | Kenmore Elite 45986 Front Load Washer
Rotten Egg Odor from washer
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
NOTE(Follow the procedure correctly as stated. If the issues persist, this may lead to a deceased rodent, or small mice that has crawled into the unit to die. This is highly uncommon, but possible)
Nov 02, 2009 | Whirlpool GHW9100L Front Load Washer
After about 18 months, washing machine smells like rotten egg/fart. Is there anyplace to clean it out?
If you have well water, Check your "Annode" Rods in the Hot Water Heater. Had mine do this. I had to Replace the Whole thing as it built up to much Contaminents from the "Hard" Water.
May 12, 2009 | Washing Machines
Rotten Egg Smell
Make sure the rubber door gasket is clean. Pull it back and clean under and around it. The gasket will collect dirt and begin to mildew causing various odors. Run the machine empty, boil a medium pot of water to almost boiling, then put it in the machine during the wash cycle. This will help clean the lines, during the rinse cycle place a 1/2 cup of vinegar in the unit. Make sure you are using HE detergent. 1-2 tablespoons will due. If your using liquid fabric softner, dilute it by half. These machine use less water than a typical top loader and can't dissolve regular detergent effectively. There by causing your lines to get clogged with gunk.
Nov 02, 2008 | LG WM1814CW Front Load Washer
Rotten Egg Smell
Repair man told me this is common with front load washers. I was told to put Sunlight dish washing detergent (for dishwashers not hands) in the machine (about 1/2 cup) and do a hot wash with the machine empty.
Jan 21, 2007 | LG WM-1832C Front Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
321 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
