Question about Dryers
No heat STARTED OFF BY TAKING VERY LONG TO DRY CLOTHES. AFTER DRYING TWO LOADS OF CLOTHES. I NOTICED THAT THE CLOTHES WERE STILL DAMP AFTER TWO CYCLES AND DID NOT FEEL ANY HEAT SO I REMOVED THE VENT HOSE TO SEE IF ANY HOT AIR WAS BLOWING BUT NO SUCH LUCK ONLY COLD.
    Scholar:
  • 43 Answers
Depending on the dryer there's either no flame or a blown heat element.
An appliance service person can fix this very easily.
Posted on May 10, 2009
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
My dryer is not heating the air clothes are rolling and air seems to be blowing but the clothes are damp when cycle ends and they are not warm. what do i need to fix this?
if the clothes are damp then I would disconnect the vent tube, and dry a load of clothes. If they are dry then the vent needs to cleaned. Hope this helps Tim
Feb 06, 2011 | Fisher and Paykel DEGX1 Electric Dryer
How do you dry on this machine? if you dry on the green, does it completely dry?
The automatic preheat and drying cycle kicks in as the final wash spin is under- way. The system employs a condenser dryer in which the hot air used to dry the clothes is channeled into a drum, instead of being released into the great outdoors via a dry vent hose. Cold water is drawn into the drum at the same time. The two mix, and the result is a condensing process.
The chlothes should be dry. there may be a damp feeling to them but otherwise dry. If your machine is not drying then the element could be going bad, or a thermal cutoff. those would be the easyiest fixes.
The BIG drawback is drying. It takes about 90 minutes to dry a load, and the clothes come out very wrinkled. Because the drum is so small, the clothes don't 'toss' in heated air and don't fluff at all. Clothes also come out stiffer than a regular dryer.
Jan 06, 2011 | Equator EZ 1500 Front Load Washer / Dryer
My GE dryer takes 3-4 times as long as I expect it to to dry my clothes. I've read that it should take about 45 minutes to dry a load but after the first cycle the clothes are still damp. It usually takes...
You have checked a lot already ... thanks for the comlete story. Often the questions here hurt for detail.
Are your clothes getting hot?
Two reasons for not getting dry ...
No heat
No air.
You need warm air (heat and air) going through your drier to achieve dryness.
Sounds like you have no heat. Are you properly setup on the control panel (you selected heat)? You have physically inspected the entire exhaust sustem including the outside vent, hose and lint trap - absolutely clear ...
check the heat my friend
Oct 20, 2009 | Dryers
Delic ate cycle taking too long to dry
This is normal because the delicate cycle is a low heat cycle.
Aug 01, 2009 | Dryers
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
Dryer starts drying and thinks clothes are dry, but they aren't
Check the timer, and the sensor. Sounds like it is having a problem with the timer or sensor no noticing that the clothes are still wet. Please rate if satisfied. Thank you
Feb 12, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
GE Dryer DDE7200SBLWW doesn't dry quickly
it sounds like it could be your vent turn dryer on go outside and feel your air coming out of vent if not a good air supply clean your venting system
Dec 13, 2007 | Dryers
Dryers Logo
119 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
