Question about Whirlpool Duet GHW9150P Front Load Washer
WATER IS COMING OUT OF THE DETERGENT DOOR. I'VE HAD THIS PROBLEM BEFORE FROM PUTTING POWDER DETERGENT IN THE LIQUID DETERGENT AREA. I BELIEVE IT'S CLOGED. WHAT CAN I DO TO SOLVE THIS. IT WAS UNDER WARRANTY WHEN IT WAS FIXED BEFORE NOW IT'S NOT.
  • 51 Answers
STOP USING SOOOOOOOOOOO MUCH DETERGENT, AN USE HE DETERGENT. POOR HOT WATER IN DESPENER LET SOAK. IT WILL BREAK THE SOAP LOSE .
HE DETERGENT REQIURES A TEASPOON ONLY
Posted on May 16, 2009
Why does my LG top load washer have mold in the detergent area?
This is a common issue, they make cleaning products to remove this gunk. Hot water and bleach will kill it as well.
Feb 01, 2017 | LG Washing Machines
LG Tromm WM2233HW- Problem with oily residue on clothes
Use warm water and powdered detergent. Leave the door open in between cycles and it will be clean as a whistle in a week... Powdered detergent is HE also, don't believe the hype, stop wasting your money on useless chemicals to rinse away the garbage chemical soaps you are being ripped-off by... Hopefully, the liquid detergent hasn't corroded the washtub and drive shaft so badly it is oozing slime!
Jul 26, 2016 | LG Washing Machines
What type of detergent is best liquid or powder
Liquid detergent is better for all washing machines.
Apr 22, 2016 | Miele Washing Machines
Says no detergent but detergent tank is full. Won't complete cycle or cancel. Door is locked. What do we do?
Unplug. Hopefully, it will reset in an hour. Detergent feed may be plugged, or sensor is not working right. Is detergent powder or liquid? If liquid I' try some water in the tank and see what happens.
if powder and plugged feed Id try the water to rinse out the blockage if any. Water may clean the sensor enough to "wake up"
But your owners manual with troubleshooting may give you better answers. Possibly Mfg's Customer service like can help.
Feb 27, 2015 | Washing Machines
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
It has a musty smell
Step one: Identify the source. Try switching to a high efficiency powder detergent instead of liquid. (Suds collect in nooks and crannies.)
Step two: Clean. First wipe the inside of the washer, especially the area where the door seals to the inside. Mold can collect around the insides and folds of the rubber seals. Get in there and make sure you cleaned it all. You could use bleach or Pinesol.
Step three: Use a quarter cup of dish washing detergent (powder is best, liquid if you must), along with a towel. Put the machine on the "sanitary" (hottest water) setting. Let it finish its cycle. This should get rid of the mold completely.
Step four: Leave the door open between wash loads. This will decrease the mold build-up as it allows the tub to dry completely
NOTE: IT WILL TAKE 2-3 WASHINGS TO TOTALLY RID THE CLOTHES OF THE MUSTY SMELL.
Hope it helps!
Aug 22, 2011 | Whirlpool Washing Machines
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Do I put powder detergent in the same place I put Liquid detergent?
Detergent compartment
Add liquid or powdered detergent to this compartment for your
wash cycle. The detergent separator must always be in place,
either in the front or back position.
 Do not fill beyond the “MAX” level.
 Liquid or powdered color-safe bleach may be added to the
Main Wash compartment along with the same type of
detergent, liquid or powdered.
 Liquid detergent: Put the SEPARATOR in the front position,
between the guides, as shown as shown by Position 1 below.
There will be no gap between the bottom of the wash cycle detergent
compartment and the bottom of the separator.
Powdered detergent:
Put the SEPARATOR in the back
position, behind the guides as shown by Position 1 below. There will be
a gap between the bottom of the wash cycle detergent
NOTE: The separator will be in the POWDER (back) position
when shipped from the factory.
Nov 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Creda Washing Machine Detergent Dispenser not emptying
does the detergent get wet?
may be the blue trap door that is behind the detergent in the drawer is set for liquid detergent ie 'closed' and needs to be set to open to allow the powder past. or the holes above the detergent section where the waster comes out are blocked so water goes in another route.
you could always put the powder straight in with the wash to get yourself out of trouble.
Feb 03, 2009 | Washing Machines
Whirlpool Dishwasher
I believe this problem was indeed from using cheap dishwasher powder. After tearing the panels off and checking everything I could think of, I switched to cheap liquid detergent and no more problems. :)
Oct 22, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool Duet GHW9150P Front Load Washer Logo
147 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
