Question about GNR F141 (Black) 14" LCD Monitor
The fuse went on my computer monitor, when i replace fuse & started up computer all the colour settings are out, the computer loaded up & screen was red, ive try setting colour on monitor but
The fuse in my Gnr monitor when , i have just replaced the fuse, 7 now all my colour settings r out, the screen was red in colour when computer loaded up ???
3 Suggested Answers
  • 7 Answers
SOURCE: monitor gnr ts 700 driver
GNR Corp Ltd. (UK) Support Q, How do I install/reinstall my GNR monitor drivers? A, Check the link on the GNR website: wwwgnrintl.com. Q, Where can I find the latest drives for my GNR ...
www.amtiva.com/client/gnruk/support/faq.html
Posted on Sep 17, 2009
budmrtn
  • 11361 Answers
SOURCE: how can i change the preset resolution of my gnr
The video resolution setting is done AT THE MONITOR DISPLAY PROPERTIE SETUP, not at the monitor. The video card driver is up to date?
What OS are you running?
If you are running Windows 7, you need to find driver for this model.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jun 30, 2011
Testimonial: "although not the complete answer: it put me on the right track-problem solved...Jem. "
Amp popped then went off , now blows fuses when replaced
Output stages have blown and are shorted - need to be replaced.
Feb 16, 2016 | Computers & Internet
How do I fix the color?
No! the problem is in the LCD panel display, behind the LCD is a large circuit board that process video, colour, brightness, and balance, if that goes wrong it throws the colour content off, replacing monitor best option. But first it would be a good idea to sub the video cable from the monitor to the computer to cover everything and hook a spare monitor to the computer to rule out the video graphics card.
Apr 30, 2012 | SVA-USA VR-20 20" Flat Panel LCD Monitor
Shows different color complete blue or red scrren at connection
shake vga cable at different places & observe.........if colours becomes normal or it comes & again it goes...then vga cable is deffective.......either you have to change full vga cable or you have to repair that cable itself................after shaking cable also if no improvement then......hit your monitor lightly on left side or righr side or on top & observe ...........if colours becomes normal or it comes & again it goes...then following is the situation...............after 4 or 5 yrs in some monitors on main board at some soldering joints crack develops....then due to loose contact colour problem comes (1 of the sympton) ...........when we hit that lightly then those loose contacts joins temporarly & again colour comes nomally for some time............so solution is ......monitor main board & crt circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no improvement then..following is the situation.....................on CRT circuit board ( circuit board that is fixed to tube) ''red green blue'' - video output IC ( some thing like LM2469TA ) will be there - it should be replaced - usually it will be fixed to heat sink ------- before changing IC all the components on CRT circuit board should be checked ( after switching off monitor ).........this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good monitor service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )
Apr 11, 2011 | SAMTRON 55V 15" CRT Monitor
I have a LG flatron L246WHX monitor connected to my laptop, the colour on the screen suddenly is only showing green and purple colours. how do I get it back to normal, is the adjustment done on monitor or...
First, make sure that the cable you are using is plugged in tightly on both ends...if some of the pin connections get loose the colors can go a little funky.
If Cable is tight try another cable. This will eliminate the cable as your problem.
If another cable gives you the same result it is then usually either a problem with the video card in your computer or the monitor itself.
Try plugging the monitor into another computer if you can. If the monitor is OK on another computer, the problem is then probably the video card on your computer. If you have a desktop, it can be replaced usually, or another video card can be added and used if your video card is built into the motherboard.
If all of those fails, it is likely the monitor went bad. Check if it is under warranty to see if they will replace or repair. If not under warranty you may want to replace the monitor at that point.
Mar 23, 2011 | LG 22" FLATRON LCD Monitor
Samsung syncmaster 2433bw , suddenly went out of colour. Tested it with a ps3 but I found a setting that shows me colour .. its the dynamic option under magic colour
Samsung Sync Master 2433BW has the brightness rectangule and monitor menu in one corner of my screen. How I disable/remove that rectangul?
Oct 21, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
VGA problem with HP monitor
The VGA cable are standard pin out for VGA DB15HD connector.
Learn about it here: http://en.wikipedia.org/wiki/VGA_connector
Apr 02, 2010 | Computers & Internet
The back lights come up on turn on then went out. now no back light at all
found 5 amp fuse open and one driver chip on lamp power board #4532GM replace chip and fuse works fine. chip had a hole burned in it
Oct 21, 2009 | Philips 23PF9945-37 23" Flat Panel LCD...
I have lg studioworks 552v monitor connected to a windows 98 computer . the screen had some problem before now rectified but i had 256 colour running now after repair there is only 16 colour . how to get...
In Win98, you will get only 16 colors if you don't install the VGA driver. It is not a problem with your Monitor. Install the VGA driver. If you can't find the driver (we may be able to help to find it), try replacing the VGA.
Apr 19, 2009 | LG Studioworks 552V 15" CRT Monitor
Computer monitor goes blank after initial start-up reaches the desktop
Try setting your graphics card output to something simpler like a basic 640x480 resolution 64k colours and see if it still does it... it maybe that you have the resolution/colour depth to high for the monitor to properly handle
if it is stable at the lower setting slowly increase untill you reach a point that you and your monitor are both happy
Oct 08, 2008 | Computers & Internet
GNR F141 (Black) 14" LCD Monitor Logo
123 people viewed this question
Top GNR Computers & Internet Experts
David Payne
David Payne
Are you a GNR Computer and Internet Expert? Answer questions, earn points and help others
