Question about Pioneer PureVision PDP-4340HD 43 in. Plasma HDTV
Media Receiver Shut-down, Blue LED Flashing for Pioneer PDP-R06G
My Media Receiver PDP-R06G turned on and then off, followed by Blue LED flashes of 8 times. The Plasma unit concurrently switches off. Any solution to this?
    Top Expert:
  • Pioneer Master
  • 74,634 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Posted on Mar 16, 2015
SOURCE: I have a Pioneer PDP-R05G
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
http://www.pioneer.owner-manuals.com/PDP4360HD-service-manual-PIONEER.html
service manual link above,
as an aside here, sometimes things in storage can quickly degrade especially big low value capacitors, these increase in internal resistance, and all sorts of problems ensue, this is why, say, military things are cycled at least weekly when in "Moth balls" to prevent exactly this.
Posted on Mar 12, 2011
SOURCE: The media receiver shuts off and the plasma screen
Pioneer plasma pdp R03U shuts off and tv shows E01 or action freezes while soun dgoes on and then stops E01
Posted on Jul 19, 2010
  • 41 Answers
SOURCE: Upgrading media receiver on Pioneer PlasmaPDP-5030HD
You can use a PDPR06U if you can find one for sale its 2 generations later than your's. Look on Ebay. I might have one too but I got to look.
Posted on Mar 29, 2009
  • 41 Answers
SOURCE: pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Posted on Mar 30, 2009
SOURCE: I open the top cover of my Pioneer Media Receiver
Any luck with this? I really need this information as well.
Posted on Nov 22, 2010
Pioneer pdp-ro6g media receiver flashing 8 times, any suggestions what error is or how to clear it? Thanks Jason
Sep 29, 2015 | Pioneer Televison & Video
Pioneer PDP-435HDG will turn on, and I get a test pattern type screen for a couple of seconds, then monitor turns off. Media receiver unit is flashing the green power led in a 7 flashes pattern. Hel
Jan 11, 2015 | Pioneer Televison & Video
PDP - 436PG display turns off then straight off and the red standby flashes 3 times, pauses then repeats
That is an error code that likely means power supply issue and based on brand not likely to be a do it yourself fix. Consider having a authorized Pioneer service center look at it and get an estimate.
Nov 05, 2012 | Pioneer PDP-4360HD 43 in. Plasma...
Power Surge
charlie the proble has something to do with the tv guide here is a response from an older post Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was. Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Aug 05, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
Pioneer PDP-RX06XE has no picture
check PDP 436XPE UNIT may be Y board short...or need factory restore to the original state....
Nov 18, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
How to play PDP-434PG with PDP-R05G
I do not know how to solve your issue sorry, I need the media centre you have for a PDP435. Would you like to sell the media receiver PDP-05G ?
0212624139
Aug 27, 2009 | Pioneer PDP-4360HD 43 in. Plasma...
Pioneer media receiver pdp-r04u
try testing dvd player direct to tv dont use uvsal remote go to tv turn it on and change inpput to dvd see it works
Feb 06, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Can I use media receiver PDP-R04U with PDP-436PU display?
You need the pioneer media cables hooked up to the media receiver to the plasma unit itself. each end has 2 different plugs. one has 2 thumb screws and the other is a squeezable end that clicks into place. They MUST be on before you plug in any power what so ever!!!! And yes, other information is being passed through.
C-Dog
Sep 18, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer PureVision PDP-4340HD 43 in. Plasma HDTV Logo
1,773 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
