Question about Memorex MVD2022 DVD Player
Memorex MVD4544 flashes error message that reads "SAFE"
Last night, I think I set something down on my DVD remote that pressed multiple buttons simultaneously. I don't know what happened, but now every time I try to turn on the DVD player to eject the disk, a flashing message appears on the display that reads "SAFE." I've reviewed my owner's manual and can't find an answer, and I can't figure out how to disable the error message. I've tried unplugging the machine and plugging it back in, and I've tried a variety of different button combinations on the remote and directly on the device - so far nothing works.
  • 5 more comments
  • leftcoast Oct 13, 2007
    For the record, I got the problem solved. If anyone else has the same issue, apparently you just need to hold the "power" button down on the remote for a full 5 seconds, and then the error message will go away. It doesn't work if you use the buttons on the actual console - just the remote. :) Back to fully functional DVD operation.
  • Anonymous May 27, 2008
    My MVD4543A did the same thing! Thanks for the solution!!
  • Anonymous Jun 04, 2008
    Thnx for that info.Saved me a bottle of asperin.
  • Anonymous Nov 06, 2008
    Thanks for the info! My kitten stepped on the remote, causing the "safe" display to appear. You saved me a migraine!
  • Anonymous Nov 12, 2008
    Thanks for this, I let my 4 month old daughter play with the remote and couldnt figure out how to turn the thing back on!
  • Anonymous Dec 13, 2008
    Thank you for posting this!!
  • simogene
    simogene Feb 01, 2013
    ZOMG thank you. Small children and remotes don't mix! Also small sick children screaming for their Spongebob video when you can't turn on the player is not cool. So sincerly, thank you for the answer!
Thanks! I couldn't figure it out either!
Posted on Dec 18, 2008
SOURCE:
I cannot locate the manual for our Memorex MVD4544 VHS/DVD player
"I cannot locate the manual for our Memorex MVD4544 VHS/DVD player"
You just did ;)
Please click on the following link, then follow the instructions below to download it:
http://www.retrevo.com/support/Memorex-MVD4544-DVD-Players-manual/id/11188ci374/t/2/
The download page will open in a new window.
Download instructions
1. Scroll down the page a little until you see "Download the Document" in big blue letters.
2. Click on "Download the Document" - after a few seconds another page will open
3. Scroll down this page until you can see a big red button with "Download Now" on it.
4. Enter the 5-digit code in the small white box above the numbers.
You do not need to enter your email address on this page - unless you really want to!
5. Click the big red "Download Now" button.
6. When the "File Download" box appears, click "Save" and save the file to an easy to remember location on your PC, e.g. your Desktop.
When the file download is complete, go to the location where you saved the file and double-click to open it. If you'd like to help murder a few helpless Polar Bears, you can print the manual - or you can take the 'green' option and keep the file on your PC for reference ;)
If you are unable to open the file, you will also need to download and install the latest version of Adobe Reader:
http://get.adobe.com/reader/
If you have any difficulty downloading the file or you have a problem with the player that you are unable to solve with the manual, please reply to me from within this page.
Hope this helps - the Polar Bears are counting on you!
BElectric.
Feb 04, 2011 | Televison & Video
Memorex mvd2047 dvd player - no audio when playing dvd
Regarding the problem with the sound on your DVD player, I would suggest you to make sure the audio cables (red and white) are connected properly to the TV and player.
Also, try using a different set of cables since those ones might not be working and this is why you are not getting audio. On the Memorex remote you will find a mute button, make sure it is not activated.
Jul 23, 2010 | Memorex MVD2047 DVD Player
My memorex dvd shows a split yellow pscan sing
On most of the Models there is a Pscan button on the back of the unit in the middle. just turn that off and you should be good to go.
Aug 22, 2009 | Memorex MVD4544 DVD Recorder/VCR
Remote control won't program.
my remote quit working. do you have a solution? thank you
Nov 14, 2008 | RCA 3-Device Universal Remote with...
Split screen with pscan warning on
I had the exact same problem and I consulted the manual. All you have to do is turn the PSCAN swtich off. It is located on the back of the dvd player. Then turn the dvd player back on and your problem should be fixed.
Jun 07, 2008 | Memorex MVD2022 DVD Player
Set up new panasonic th-37px80b tv last night. Its connected to a v box via scart and hdmi and dvd player via scart. It is not connected to an aerial so only watch tv via the cable box. The problem is I...
The set is in the service mode. TO EXIT THE SERVICE MODE PRESS VOLUME DOWN ON THE SET AND THE OK BUTTON ON THE REMOTE F0R 3 SECONDS.WHEN SELF CHECK SCREEN APPEARS UNPLUG THE UNIT. Solution found on Fixya by QTV1 posted on Nov 20, 2007
Mar 08, 2008 | Panasonic Televison & Video
Error message when reading DVD
Try changing the region setting to region free.
1. Make sure there is no Disc in the tray.
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys,
simultaneously on the player and not the remote control.
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
9. Press Enter on the player.
10. Press Standby and wait 5 seconds.
11. Press Standby again. Your player is now set to the region you requested. If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
Good Luck. Let me know if it works
Jan 09, 2008 | JVC XV-S300 DVD Player
Memorex MVD2022 DVD Player Logo
572 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
