I have an ASKO W 6551 front load washing machine; when I tried to put some eucalyptus oil in the small tray for softener accidentally the plastic (bottle)cap the size of a 20 cents Au coin slipped right down inside the pipe; can this damage the machine? or can I leave there ignoring the noise? thank you, Stt
  • stt_29 May 10, 2009
    I managed to remove the cap as instructed by rkavi thank you;
    now while in spinning mode the drum is awfully unbalanced and makes a horrible noise;
    is it because we laid the machine horizontally on one side while trying to extract the cap?
    the machine is shaking really badly and the noise is frightening;
    I could not reply to rkavi, I really wanted to but somehow I could not type a new comment to him;
    we managed to implement the first solution given by rkavi; it really worked;
    then we encountered a second problem and got a solution for that one too by muzzi_123;
    thank you to both of you, great service;
    thank you again;
    ST
  • 749 Answers
Well you can leave it there because your machine has automatic sensors e.g if the hot water is not working it will stop and show you a error code, its the same if the plastic bottle cap manages to block any pipes of the machine it will stop to prevent further damage and show you a error code.
Posted on May 10, 2009
    Scholar:
  • 123 Answers
Hey,Look for obvious dents and creases in the drum.inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub look for cap stuck .
Clear the water pump from obstructions like cap when a noise occurs while the washing machine is emptying water.
this wil be a problem if u dont care about it,so perform the above techniques,otherwise ur washdrum will be spoiled.
How do i remove the drawer to clean it out the bleach, softener, detergent dispensers?
The dispenser slides out . There are plastic slideson both sides of the outer dispenser tray which run into grooves internally . be careful not to force its removal as you will damage the tray
Feb 10, 2015 | Kenmore Washing Machines
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
Where does the detergent go and where do i put the fabric softerner? I am using a Kenmore Elite front load washer. thanks, Adriana
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
Cheers,
John C
Mar 16, 2011 | Kenmore Elite 45986 Front Load Washer
Hey, in which dispenser number do you put washing powder and fabric softer 1 or 2? Thanks
1 is usually for pre-wash, 2 for washing powder and fabric softner goes into the section with the level indicator should be small square section with removable top.
Feb 28, 2011 | Hotpoint Ariston AW125 Front Load Washer
My fabric softener compartment won't drain properley and always has water left at the end of the cycle - any ideas to clean?
yes this cleaning should be carried out on a regular basics,remove the compartment/drawer give it a small pull and it will come out easly.clean with warm soapy water once replaced put a [dishwasher] tablet into drawer and run a normal wash,done once a month this will keep you free from problems.adrian,,,,,,,,
Aug 19, 2010 | Asko W6461 Front Load Washer
How do I get the tray out to clean it?
pull tray until it stops then in back middle of tray push on plastic button and pull tray out
Apr 18, 2010 | LG WM-2277HW Front Load Washer
WASHING MACHINE WILL NOT START
check motor it may need cleaned and oiled, or it might be bad.
Apr 04, 2010 | Asko W6021 Front Load Washer
Maytag 7500 Water in cups for bleach & softener
you should have a small amount of water in the resivoir this is part of the siphon system
but you do want to keep it clean every 4-5 loads put it through the dish washer
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Asko Front Load Washer major water overflow from powder dispenser
You may have the hose between the dispenser and bowl blocked
Feb 14, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
