Question about Luhr Jensen Little Chief 9800
Owners manual -download
I lost my owners manual for my recently purchashed little chief and i need a manual,where do i go to down load the manual? i have no clue on how long or how many times to change the chips or any time frames for smoking things so they are fully cooked email me back at splashit@lycos.com thanks splash
    President:
  • 1,734 Answers
You can get this with google.
Otherwise ask manualfox.com - this is the hazzle-less way to get it.
Posted on Sep 02, 2009
2014 Indian Chief Classic cuts out while riding
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery must have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Engine cutting out on the move
Engine Cutting out misfires
Indian Motorcycle Chief Classic Service Manual
Motorcycle Service Parts Part Finder Indian Motorcycle Store
Indian Motorcycle Chief Classic Rider Manual
Aug 12, 2017 | 2014 Indian Chief Classic
Need wire diagram for roadmaster 1000
Hi, Jeromy for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Indian, despair not, for a mere $12 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Indian roadmaster 1000 wiring diagram Google Search
INDIAN MOTORCYCLE CHIEF ROADMASTER SERVICE REPAIR PDF MANUAL DOWNLOAD 2009...
http://polaris.hs.llnwd.net/o40/ind/2017/documents/manuals/9926788r01_lo_res.pdf
Indian Motorcycle Chief Classic Service Manual FREE
Oct 06, 2016 | Motorcycles
I want to down load a owners manual
Since you declined to specify the model of your Uniden phone, I can only direct you to select the type and then the model from the list beginning here to download a copy of the manual.
Feb 11, 2012 | Uniden Lands Phones
Bushnell Sky Chief II telescope model # 78-5700, D=60mm, F=910mm I need an owners manual!
Here is the Warranty/Customer Service and the Manual web site.
Look down the page for a manual and or call customer service: http://www.opticsplanet.net/bushnell-warranty.html
Dec 07, 2009 | Bushnell Optics
I have a little chief 9800 top load smoker and lost the heating element in a move. There are two elements available, a 7.5" and an 8.5", but I'm not sure which size my smoker takes. Is there any way to...
The #4 Little Chief element is 7 inches and more importantly is 250 watts, this is the correct wattage for ALL Little Chief Smokers newer than about 15 - 20 years old.
The #5 Little Chief element is 8.5 inches and is also 250W but is for newer models before 2006.
Look at www.smokehouseproducts.com for clarification & best fit.
For very, very old models (20+) there is a ceramic disk (175W) that heats the chip pan and is hard to find and expensive, a person would be better off finding a new one on sale at the big box boys store
Jul 07, 2009 | Luhr Jensen Little Chief 9800
Otherwise ask manualfox.com - this is the hassle-less way to get it.
Jun 02, 2009 | Luhr Jensen Little Chief 9800
Need to download a copy of the owners manual
http://www.fixya.com/search.aspx?_s=hitachi+57s500+manuals
May 11, 2009 | Hitachi 57S500 57" Rear Projection...
Lost cookbook for Little Chief smoker
Check here, they will get the manual for you.
Nov 21, 2008 | Reebok RL1500 Elliptical
De500p lost owners book
http://www.manualnguide.com/download/manual-guide/
delonghi-de500p-dehumidifier-owners-manual.html
This should solve your problem.
May 05, 2008 | DeLonghi DE500P Dehumidifier
Need to download owners manual lost mine
hi okeypay
can you post back make and model of mp3 so some can post some help for you ?
riz.
Mar 24, 2008 | RCA TH1602 MP3 Player
Grilling Logo
1,516 people viewed this question
Top Luhr Jensen Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Luhr Jensen Grilling Expert? Answer questions, earn points and help others
