Question about Sharp XG-PH50X Multimedia Projector
Sharp xg-ph50x projector overheating
We just added a new lamp (number 2 right side) and ever since then it has started to overheat and switch itself off. we have cleaned all the air vents but it still does it. Please help we have a show tonight! :(
  • John Snow
    John Snow May 11, 2010
    It is possible that the new lamp is running hotter. It is not a repair, but you can try to leave the filters out for a test to see if the air flow is blocked somehow, even though they are clean.
    Just a thought.
    Genius:
  • 1,447 Answers
Hi
is the projector enclosed in a cabinet, hanging on the ceiling or on top of a table? needs more ventilation for it not to overheat. you can reseat the lamp, re-clean the filter. Hope this helps.
If issue persist, look for a backup projector so it won't spoil the show. Thanks for using Fixya
Posted on May 10, 2009
Color Wheel Motor
replace the color wheel,USD100
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Mar 02, 2014 | Sharp XG-PH50X Multimedia Projector
Picture shows up side down
If the picture shows upside down with the projector sitting on its feet projecting forward, then it is in ceiling mount projection mode. Page 58/84 of the User Manual explains how to change: Menu; Options(2); PRJ Mode; Front; Enter
Jan 18, 2013 | Sharp XG-PH50X Multimedia Projector
I have a sharp xg-c55x. I put a brand new lamp. It worked once for about 20mins. Since then it starts warming up & then it turns off. How do i fix or reset? Thank you
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary.
Jul 07, 2011 | Sharp XG-C55X Multimedia Projector
Replaced both bulbs with brand-new bulbs. Now all
Verify that the lamp doors are securely closed. The blinking red lights indicate a lamp problem. In this case, both appear to be defective. I doubt that the lamps are the problem. double chack all connections and doors for proper seating. Update this if the problem remains.
Thanks,
Dan
Apr 16, 2010 | Sharp XG-PH50X Multimedia Projector
Infocus X10 projector overheating.
okay most people think well its not hot up there but truely it is hot toward the cealing. If its overheating on the roof mount try to use a wall mount instead.. If they have it running for 5 days streight then is something your not oding right here and that might be the mount.
Nov 10, 2009 | Sharp XG-PH50X Multimedia Projector
The projector is starting up but after warming up it shuts itself off. It is not the a problem with the filter, lamp seating or an overheating issue.
Does the lamp actually light up and project? If not, it's probably a dead bulb. Are there any flashing lights that might be displaying an error code? How dow you know it's not overheating? Remove the filter and give it a good cleaning. Some projectors measure airflow and, even though the heat hasn't built up, the projector shuts down because it predicts overheating will occur due to insufficient airflow.
Aug 04, 2009 | Sharp Notevision XG-P20XU Multimedia...
My xg-e650ub also shut down while in use, and won't power up.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Jul 24, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
I have a Sharp LCD Projector, Model #XG-E650UB & it won't power up.
are there any leds lit? if not, it may be the bimetal circuit breaker. if the unit overheats, the breaker trips to cut the heat source, and needs to be reset manually. unfortunately, the top needs to be removed. it's located on top of the lamp housing (red button). if it's not tripped and still no power, you need to replace the power supply.
Jun 09, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Sharp Notevision XG-NV6XU
Looks like the wrong lamp was installed, or the cooling fan is not working. Careful - it may be permanently damaged, as the LCD inside can be hurt by high temperatures.
Sep 05, 2008 | Sharp Notevision XG-NV6XU Multimedia...
Sharp XG-PH50X Multimedia Projector Logo
460 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
