Question about Panasonic PT-61HX41 61" Rear Projection Television
Picture unstable I have a PT-61HX41 rear projection Panasonic TV. Recently the picture started jumping and 2" black horizontal lines appear at the top and bottom of the screen. The picture will return to normal and within minutes become unstable again. Does anyone have an idea of what the problem is and what parts need replacing?
  • carwash king Dec 30, 2007
    same type problem here. sometimes looks like the tv is zoomed in
  • 81 Answers
Vertical ic
Posted on Oct 12, 2007
SOURCE:
I have a panasonic pt-53wx54 picture went black with a view vertical color lines then they went and it's now just black. sound is good no picture.. what do i need to do? thanks so much
This is one of several models that had a common problem.
If set comes on with sound and you after a minute or two see a faint odd band of noise top to bottom on the screen to the right side C509 which is a .047 cap at 200 volts is bad.
Cap is seen in attached photo(location marked and cap here gone).
The cap when you locate it from the C509 number which is on top and bottom of board may have a crack or not---it is the cause of this problem.
There is a hard way and a easy way to get at it--let me know and I will explain.
3.00 part....................
Pencil is point to location on Right side board seen from right side.
There are several brown caps here and some plugs here are removed.
I would not try operation of the set in this condition too long.
Apr 20, 2012 | Panasonic PT-53WX54 53" Rear Projection...
My Panosonic TV Model# PT-47WX53g has sound but no picture
Part is C509 located on D board:
It is a .47 @ 200 volts and the location is marked top and bottom on the board.
Examine the attached photos (cap has been removed but you will see exactly where it is located).
Let me know if you have questions
Jan 17, 2012 | Panasonic PT-47WX53 47" Rear Projection...
There is a yellow, and blue line going across the bottom of the screen, and it creates a double picture on the TV.
It sounds like the typical convergence failure. Two IC's will need replaced and look for any open resistors in the proximity of those chips. Part# stk392-110 for IC's
Bill W
integrityhomeworx.com
Mar 08, 2011 | Panasonic PT-61HX41 61" Rear Projection...
My panasonic PT-51SX60A has a 2 inch picture loss
tv looks fine then I get just a line in middle and nothing else
Jul 24, 2010 | Panasonic PT-51SX60 51" Rear Projection...
Picture goes away on my DLP TV
that is an overheating problem. With the TV unpluged clean and or vacuum the internal tubes. Not the lamp though. Do not touch the lamp as any oils on your hands will cause a hot spot and the expensive lamp will fail.
Dec 08, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Horizontal Green Convergence line on PT-47WX49 is offset to the left 1-2" and can not be ajusted back. The center of the TV viewing picture is the only portion that appears normal.
you will need to replace the convergence ICs and feed resistors. You can get the convergence repair kit for your model at the following link. The kit contains the parts and a CD with the instructions on how to do the repair.
http://www.tvrepairkits.net/
Jul 10, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Used TV; new to me
type in PT-47WX51 manual in your search bar and there is an online manual from fixya. It will take you through setting up your tv.
Nov 06, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Wavy horizontal picture
the vertical IC outpt needs to be replace
Dec 29, 2006 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-61HX41 61" Rear Projection Television Logo
182 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
